I came across a picture that makes the point Halo explained in text above:
Note it’s a bell curve. Both the red and the violet-blue end of the curve are low — our visual receptors in our eyes are very insensitive to visible light at both ends of that curve.
But the blue-violet photons we barely see do pack enough energy to knock electrons out of their orbit (that’s what makes fluorescence work) and kill retinal cells photochemically, and the infrared photons we don’t see at all carry enough heat energy to burn.
“With great power goes great responsibility.”
Yeah, but you can buy great power for $10 on the Internet.
Responsibility? hmmmm ….
I got this laser last week from gearbest and am deeply disappointed with the performance. Compared to a 50mW green laser it is extremely weak, and it can’t be compared to my 2,000mW Wickedlaser arctic s2 (this laser burns skin). Even at pitch dark it is difficult to see the beam, and the dot has less reach than a cheap red laser pointer. At 50m the dot simply disappears.
Tried bypassing the tailswitch, tried several batteries with the same result. Direct exposure to a black sheet of paper makes a barely warm spot, it won’t burn anything. Also the color is more purple than blue.
I don’t know if GB changed the stock or if they sent the wrong Laser, but it is nothing like what you guys have described here.
I am trying to get info on some eye safe Astronomy Lasers which are not frequency doubled but use InGaN at 5 milliwatts with IR filter but they have a 515nm green and a 532 green and a Blue at about 450 which they say has a visible beam at night.
Could the Beams be more visible due to the direct drive tech…they are overpriced but will be eye safe…and used with care should not go
Too Far into the night sky…so no worry about
Planes 30,000 feet up that I don’t hear.
Is Blue true 5 milliwatt possible to have a visible beam…
473 probably will…but they don’t have that one.
If you do not want frequency doubled then you do not want any 532nm laser.
All 532nm lasers will be DPSS frequency doubled. It starts with a 808nm infrared laser, crystals first covert it to 1,064nm infrared then 532nm green. And in the final beam there is always some 808nm and 1,064nm, sometimes a lot. Like when the laser is manufactured quickly with poorly aligned crystals. So 532nm lasers should have an IR filter.
515nm (or 520nm or any green wavelength that isn’t 532) has zero infrared. So they do not need an IR filter.
515nm or 520 will be a bit brighter than 532 (at the same power) but only because those wavelengths are closer to the peak sensitivity of the human eye at night.
This is also the reason why blue (or red) lasers will be dimmer (at the same power). Their wavelengths are farther from peak sensitivity of the human eye.
So if you want the brightest 5mW beam you can get, go for 515nm green.
Can you give links to the stores that you are looking at?
There are a lot of bad laser sellers. They will say their lasers are “5mW” but in reality they are often 30mW to 80mW. They only say “5mW” because usa and other countries do not allow lasers over 5mW.
This company is in Oregon and their Lasers are made in “Taiwan and USA” according to a PDF on one of them.
On the Blue they specify Japan and USA ( possibly Nichia Diode ?)
Their Astrological Pointers are similar to the Galileo made in Canada
BUT Z- Bolt are in the Green 532 nm AND the wide temperature range 515nm [ Osram Diode ]and the Blue 450nm all 4.0 to 5.0 milliwatt range with IR Filters.
These are the ‘ruggedized’ versions using CR123 constant duty epoxy set waterproof ones.
The 515nm is the ‘wide temperature ’ version so Astronomers can go out in 5 degree weather lol.
The Blue has 2 mile visibilty at night and a visible beam .
Both Greens have a visible beam at night and 5 mile visibilty - great for 5 milliwatts - note they are NOT saying 5 mile beam.
One Astronomer said you can see the Blue beam about 1/2 to 1/3 brightness of the Green and harder to see off axis.
For ‘safe’ but fun lasers these are a bit overpriced but probably superior to the Galileo.
I am also going to find in their general specifications about how they do NOT use frequency doubling…these are
InGaN Transistor technology .NOTE: they say this regarding the Blue….but I can not find claims on the 515nm or the 532nm.
They also sell some Osram Diodes….
They seem to make some low powered similar spotter lasers for the Military.
You may have to forget the
“all 532nm lasers are frequency doubled with the crystal” thing.
These may all be direct diodes.
The advantage for me is relatively eye safe and the low power SHOULD I HOPE prevent over zealous Pilots who might even see a Beam on the ground or across the Horizon NOT in their direction or flight path from seeing the beam and “reporting” .
I of course will not ppint at ANY plane nor any vehicle nor person but I don’t want a Pilot 5 miles away and 4 miles UP even seeing the damn beam - off axis a 5 milliwatt is usually very hard to see ( I hope).
It’s REALLY hard to get a reliably under 5 milliwatt with IR Filter laser.
I was getting quotes from Laser Pen Shop on some builds using the JD 821 Host….but they contradicted themselves on the second email .
My first laser will probably be the Zbolt and probably too many legal issues to use a more powerful one…and I won’t need Goggles…just caution.
I ordered the blue version of this laser. Not sure if I got a faulty unit, but it’s far from being a fire starter. Touching the laser beam directly to the skin I barely could feel any heat, and at 200M the dot wasn’t visible anymore. With my 150mW green laser it would make an unpleasant sting and the range on that thing is amazing.
Robertkoa, I was thinking of asking before, why do you want to avoid DPSS (frequency doubled)? As long as you can be confident that it has an IR filter then DPSS is no problem.
All 532nm lasers really are DPSS. You will notice that all of their 532s mention an IR filter whereas their 515s don’t. About temperature ranges, the 532nm ones don’t work well in low temperatures because the crystals can’t produce 532 when too cold. If you warm up the whole laser, like by holding it against your body for awhile, you can get it to work. And once on, it may even remain working since it produces some heat. The way they are advertising the temperature ranges is a bit of marketing spin. Instead of “Extreme Temperature!” 515nm, it’s more correct to say that 532s are “limited temperature”. Any direct diode lasers should have a similar “Extreme Temperature!” range but they don’t label them all as extreme because it’s really just normal. See the 450nm blue same “extreme” temp range but no extreme label.
Imo only if you need it to work in lower temps. Or if the little bit of cool factor is worth it to you. Direct diode green is newer tech, simpler and more efficient.
I can’t say. I don’t have any first hand experience with low power blues around 5mW. So I can’t say how visible / useful the beam would be.
But I can link you to this Relative Perceived Brightness Calculator 532nm 5mW vs 440nm 5mW which says that 440nm blue will be only 10% as bright as green. The calculator is not 100% accurate but it can give you a good idea.
With budget lasers, you never know what you are going to get. It’s random luck. Unless you buy from a known good chinese laser seller.
Do you have safety glasses? You really need them when trying to burn things. Actually any indoor use of higher power lasers. Even if you just don’t want to spend much on glasses, there is still a decent option. Uvex SCT-orange glasses, only $7 and they tested out good by a couple members on LPF.
Robertkoa, you mentioned the Galileo, I presume you mean from laserglow? Galileo | 532 nm Green Laser Pointer | Laserglow Was there something you didn’t like about it? Because laserglow has been around for many years, always well known on LPF (laser pointer forum). And a good company from what I recall (I’m not active on LPF anymore). Whereas I haven’t heard of Z-bolt before.
Actually, none of those lasers are 5mW. The real power is actually way higher but due to regulations it’s a lot easier for them to sell and ship 5mW lasers, so since a couple years ago, most Chinese dealers only lists them as 5mW. High powered lasers need to comply with some technical and safety requirements.
The 301 laser I got is close to 50mW, and probably the earlier “fire starter” versions were even higher.
