trigger619
(trigger619)
December 12, 2015, 3:37am
13
This became my edc also. Very compact designed. Bought a few for my coworkers also.
I'm using the skill hunt head bands with it. I leave the headband on it the whole time now.
would like to see a group buy with these type of lights . looking for more similar lights.
great review
X31
(-X3-)
January 6, 2016, 5:41pm
14
Hi, I just swapped the stock reflector of my freshly unpacked HC30 with a 60 degrees TIR optic.
It’s now a useful headlamp for close up tasks !
bugsy36
(bugsy36)
January 6, 2016, 7:28pm
15
Where did you get that TIR?
X31
(-X3-)
January 6, 2016, 9:28pm
16
I bought it from FastTech, along with some 10, 25 and 45 degrees ones.
I’ve tested them in multiple lights and found that 45° is really useful indoor !
Jaza
(Jaza)
January 6, 2016, 9:32pm
17
can you direct link those?
X31
(-X3-)
January 6, 2016, 9:48pm
18
60 degree
45 degree
25 degree
10 degree
Oh, just for the info you have to slightly grind the outside of the optic to make it fit the HC30 bezel
Jaza
(Jaza)
January 6, 2016, 9:49pm
19
Is it just plug and play?
X31
(-X3-)
January 6, 2016, 10:31pm
20
Like I said, you just have to slightly grind the outside (less than a mm on the diameter)
interval
(interval)
January 8, 2016, 9:24pm
21
Congratulations, you can make a review of how you did with pictures and some beanshots?
thanks
greeting
X31
(-X3-)
January 8, 2016, 9:28pm
22
Yeah I may do that this week-end…I’ll make an update
X31
(-X3-)
January 10, 2016, 1:13pm
24
So, you just unscrew the bezel, then drop the o-ting, glass and reflector :
Stock reflector vs TIR :
You have to slightly areduce the TIR diamter by filing it :
You then just drop the TIR and put the o-ring, then the bezel :
Stock beam at 15cm and 1m :
bugsy36
(bugsy36)
January 10, 2016, 1:33pm
25
Now we are talking!! Thank you!!!
Jaza
(Jaza)
January 10, 2016, 2:44pm
26
Ordered 45 degree model thanks for the info
interval
(interval)
January 10, 2016, 3:13pm
27
Thank you
the higher degrees more open?
the spot fades with more or less degree?
X31
(-X3-)
January 10, 2016, 8:12pm
28
Yes, the higher degree provides the more spill (more opened beam).
The spot is quite inexistent with those type of optic
interval
(interval)
January 21, 2016, 3:25pm
29
anyone knows a 100 degrees TIR optic mod for the HC30?
Shop?
thanks.
polygon
(polygon)
January 24, 2016, 7:10am
30
I don’t think you can physically get a 100 degree TIR, the specs are for HALF the angle of spread (ie a 20 degree optic will give you a 40 degree cone).
Zanders
(Zanders)
January 24, 2016, 9:11am
31
djozz:
I bought a second-hand HC50 a while ago with the intention of swapping the led to a warm high CRI one, and I have not found a way to get into the ledboard part. My current idea is that the last part of the assembly is that the lens is glued in (with no option to get behind it to even start trying to pry it out)
I switch the led for a warmer last year, change it for a XM-L2 4D. This is how it looked inside. Maybe you have fixed it by now. There is more pics if some one needs.
Thanks for the review!
Jaza
(Jaza)
February 5, 2016, 2:18pm
32
how you did unscrew the bezel? i can’t get any grip on it.
