Iām in thank you.
What Iām saying is that you can buy stock, single emitter lights right now that do 4000lumens, all be it maybe not soda can style.
A BLF special with input from plenty of modders should maybe aim for more? Runtime is a mute point as this would probably be a 1 minute step down turbo and at the other end we can have a nice moon that runs for the 500hrs.
A BLF SRK would be nice, but it would be nicer if it genuinely was special.
Maybe a poll, would you prefer:
A. 4000lumens constant max
B. 10000lumens turbo with step down to 4000constant high
Iād like a high mode that would allow for the highest brightness that could be run continuously (until the cells start to run out of juice) without causing thermal issues. Turbo could of course go much higher.
With 6V emitters we have to use a battery-carryer like the TN36 or similar. And a mod to 12V would be easy.
I would prefer higher lumens. But the price would be more than the actual planing with 3V emitters.
My 3 emitter SRK has XHP50 with 4.3 Amps for each emitter and a thick chopper heatsink.
4000 lumens out of a soupcan is only achieved with modding or spending a lot.
That there are stock lights using series configuration and do 4000+ lumens is not really relevant here.
Show me a stock parallel configuration light doing 4K and one that does 10K and we will look at them with interest and in awe.
This is a hard one to judge, will it be for use in this great land where evening temps are often in the mid 20c or in one of the northern states of the USA or northern Europe where they are often below freezing ?
I have one light, an XPH50 at 5A, that is a pain to hold when ambient is around 25c but real nice hand warmer when its down to less than 10c
Cheers David
I realize that a super low mode could run for hundreds of hours, but I would like see a medium-ish mode that allows for significant run time and also plenty of light.
Iām wondering if any of you gurus can guesstimate the most efficient medium/high lumen output with extended runtime for this type of SRK setup.
Cheers!
The settings allow a range of modes
So indeed using a mode suitable should not be a problem
Right, I get thatā¦ but I am wondering if based on the LEDs/Driver combination there would be a sweet spot of greatest output for lowest power expenditure. And if so, then what that output might be.
Thanks again
Iād have 3500-4500lm in turbo for 1 minute or less. Then step down to max mode with 2000-2500lm
We canāt have more with SRK soupcan body.
Roche m170 is bigger and has more weight for his ~2600lm max mode
Caleb, Tom will probably shed some light on this
What I do know is that we aim at a ramping mode to choose besides the normal modes. And in my typical use I mainly set a light to a brightness I need (outside max, inside med for example) so the ramping would allow for minimum needed brightness in any situation thus prolonging use.
To get a feeling and gaining knowledge for this group buy, I just finished a 9xXP-L Hi SRK-clone mod that draws 24A (see the what did you mod today thread). It has warm white emitters so the (continuous) output is āonlyā 4500 lumen (5600lm at start-up), but the power consumption is 90W. It is too hot to hold in (just measured) exactly two minutes (room temperature without air flow). Too hot to hold for a light with a good thermal path in my experience is the correct moment for a stepdown (a safe distance from damage). At the same current, with cool white or neutral XP-L emitters, this light would put out well over 6000 lumen, with added DTP-boards 7000. It feels that the body can handle that, but for a stock light to handle these amps and heat it requires a good design with no mistakes. We are aiming for that of course. And weāre making a 4 emitter light, not 9, so if we really want 6000 lumen OTF that requires very hard driven XP-L leds.
A stable continuous output (room temperature, no airflow) for a host like this appears 6A/2000 lumen to me, with airflow at least double that.
If I were to run a customer BG light, I would want the light to be running above 10000 lumens to make it extremely unique
This group buy is for a 4x parallel battery, 4 led light. You can not get 2500 lumen OTF out of any 3V type led.
Sounds great! Canāt wait to see what specs/price it will have.
Iāve seen the 10K mark mentioned before so surely there will be interest!
I have a UltraFire 7XML SRK clone that puts out more then 3000 lumen stock - guestimate from ceiling bounce with a lux meter. It is 5-8% dimmer then the massive TR-S700 that has been reviewed here at 3500 lumen.
I would love this BLF SRK to go up to more then 5k lumen on turbo and 3k+ on high. More then that would require 6V/12V and a more complicated battery setup which will raise the cost. That would be for a future 12V edition you can start your car withā¦
Well, 4x XP-L V6 @3A each will make ~5000 lumens at start. I think Iād be happy enough with that output. It would be ~41.5 watts to the four emitters. Can the host take that? I donāt know. Iāve never owned a SRK. I seriously donāt want it pushed so hard that reliability becomes an issue. And I donāt want any ~6V or ~12V emitters in this light! Maybe we can work out ~6V emitters in V2.
1 xpl nw for me plz
Yes I think maybe you guys are right, the 10k+ lumens obviously needs the series cell setup and so is out of the scope of this.
Maybe a different thread for a totally separate light with series cells and XHP, obviously we would be looking at a $150+ light. Maybe not so much interest on BLF
Iām still looking forward to this light, shaping up well for the original design plan :sunglasses:
I might re-sub to the thread in 6 months or so and let the wizards do their thing, no way we will have this for Christmas is my guess
No point getting excited at the ideas just yet, just torturing myself!!!
