TrustFire X9 - Thoughts and beamshots
It's here:
https://budgetlightforum.com/t/-/1022
You can leave the PCB connection of the leftmost star in place. The connection of any other star will take precedence.
Thanks
Has anyone measured 2.8A using the Nanjg 105c (8xAMC7135) driver?
I see someone got 2.7A.
I just tested to make sure, and yes, I get 2.805 amps.
Nice! Standard leads?
I was curious because some have got 2.6A from this driver.
But then everybody has all kind of DMMs and use standard or custom leads.
My lead aren't standard. I use leads that have banana clips on the ends. The wire isn't particularly thick (maybe 16-18ga.) and they are 1m long.
EDIT: I just measured with the stock leads and could barely hit 2.0A.
Further EDIT: I have 2 DMMs, and if I test the resistance of one DMM with the other I get between 0.0 and 0.1 ohm with the banana clip leads and 0.5 ohms with the stock leads.
Wow, that's one huge difference. From 2.805 to 2.0
Thanks for testing.
I tried my X9 with 2X16340 and burned both driver and led. So, because i couldn't find a replacemend led with 32mm board, i sticked an XML with smaller board to the back side of the original 32mm led board.
Also changed driver with KD driver:
Please forgive me due to bad pictures taken by my cell phone :) . Because i don't have a good camera, i couldn't put a picture of throw but, i will show you the picture taken from googleearth which shows the most far distance that my eyes can notice:
And this distance with demaged reflector surface. I dont know what happened to the surface. Is it possible because of too much heat dissipated from led?
How does this light compare to the fandyfire stl v6?
Can it use 1 18650 just like the trustfire x8? (EDITED: i wrote 18500)
if you are asking about X9, it takes 1X18650 already. 18500 is shorter around 17-20 mm then 18650 so, it does not work with X9. STL-V6 has a bigger head, that's why it should be a better thrower if its well driven. What i see about X9, it has different specs from different suppliers. Some can use 2Xcr123 some not(like mine), some well driven but, most not (like mine before changing driver). I hope this is usefull :)
OOps i meant 18650 batteries. I want to buy a good thrower that is still pocketable (16-17cm is about the max)
fandyfire is 24 and that's just too long but it looks so awesome https://budgetlightforum.com/t/-/4177#new beamshots in the middle of the page :o
I think you will find the Trustfire X9 is too large, it is only 40mm shorter (198mm total length) then the STL-V2/V6 (~240mm). Considering the STL-V2/V6s have 65mm's more space in the battery tube you may be better off looking for something shorter yet.
My Trustfire X9 arrived today! First impressions are very good, one thing I have noticed however is that it is well focused at about 2m but beyond that a hole starts to appear in the center of the hotspot. The further away it is aimed the worse it gets. Max I have been able to experience this is at about 7m (indoors) as it is too bright outside. I have found that if I unscrew the driver and emitter module a small amount it fixes it (however the hotspot is very slightly larger because of it). Just from a quick comparison of only the hotspot of the beam it appears about twice as bright as my p60 R5 drop-in (textured reflector) and slightly smaller (R5 at 1A). Outside at night this difference will probably shrink noticeably, but I have a KD 2.8A driver on hand waiting to be re-homed.
The white plastic spacer between LED star and reflector may have been mounted upside down. If correct, it should fit (engage with) the reflector bottom and its hole.
I hope this makes sense.
Tested my Modded X9(2.8A) with my friends ceto light meter.
37k lux @1 meter.
Yes it does thanks. I just tried turning it around (it is the correct way up already) and this fixes the problem somewhat however only because when the wrong way round it is thicker as it does not slot into the reflector. From some pictures off here it would appear my light has a smaller isolating ring then others. It also has thicker side walls below the LED board then what is pictured on Manafont and DX (much like the picture in Old4570's review).
My Trustfire X9 was purchased from DX ($44.40) and included 2x Trustfire "2500mAh" (blue) 18650s. They look unprotected to me.
Please, please, please if you are going to make conversation just so that you don't look like a scammer then do try to talk about things that exist.
I think you meant spammer but the again......
He/She/It is at least more entertaining than your average hit-and-run spammer. Not 419eater hilarious, but definitely better than nothing.
Yep, you're right.......
