P.S. — if anyone wants everyone to have access to a big block of material in a signature, without having it appear full text with every comment you make, there is a way.
Notice mine? I found that cute phrase in someone’s very technical query here long ago.
So I attached the URL link to the comment behind the words, so the signature is one clickable line of text there.
If anyone wants to know more about that signature line, clicking it takes them to the source. You can link whatever volume of text you want that way.
Hypertext — it’s a good idea.
I don’t know where or on what forum I read it, but many years ago it was said that a members sig should always contain less lines than their shortest posts. Therefore if someone’s sig contained 7 lines, their posts must contain at least 7 lines of text, but it had to be quality text.
I guess (hope) I would be safe if this was a BLF rule, no lines of sig means my posts don’t have to contain quality text, right?
so, I made my signature point to the comment above about why it doesn’t work any more, hmmm, I wonder if Google or the Internet Archive has a cached copy of that missing post ….
You can do it with a CSS override, same as the site theme I made. However, it’s all very manual and can’t be triggered on a “sig too long” condition. Instead, you can hide signatures on a per-user basis or a per-content-type basis. If three people’s sigs bother you, you can hide only theirs. Or if you want to block all images in signatures, you can do that. Or perhaps all tables in signatures.
TK, I understand the CS for blocking images in signatures (thank you)
What I’d still like to do is block text in signatures (selectively if possible, and blocking multiline/verbose specifically if possible)
I know at some point I just teach myself what to ignore. But if there’s a tool, that frees up a few brain cells otherwise used just to filter my own visual input
EDIT — tk’s code for that works fine, and is posted in the BLF After Dark thread
