It sounds like you may have gotten the Astrolux A6 driver.
Try programming it using the A6 UI and see what happen.
Yeah! :+1: way to go BobbyMK!
Our motto is “we never give up, even if it kills us”…or takes a year or so to get around to it. Mod fails just eat away at your craw until you overcome them.
Nice job on the aluminum pill insert.
What exactly happens I don’t know, but I had that and it went away with a good highdrain battery.
Using a protected battery can sometimes cause misbehave like you have, so if you are using one i suggest to try it with unprotected high drain battery.
Thanks, Ouchyfoot.
I actually wanted to chop a noctigon XM board but then again i didn’t wanted to destroy it for this light, but now if i would knew that it will work this good i would probably fitted the noctigon
Make sure you have solid ground contacts, and a high drain cell. The ATTiny25 is sensitive to slight changes in current and exhibits this drop-out behavior if everything isn’t just right.
O yeah, I forgot to mention, I tried Panasonic 18650PF, Samsung 30Q, Samsung 25R, happens no matter the cell.
I have LG G2 cells that I didn’t try but somehow I doubt it will make a difference.
P.S. I also had it assembled with older Astrolux S1 A17DD-L FET+1 and it worked just fine…
That’s a very good looking mod, it looks like it was made that way. I did the same mod and it don’t look like that at all :weary:
Very nice work
That is one neat clean cut out for the volt meter.
You did a cleaner cut than the stock ones for USB ports
I do hereby put forth my nomination for zipelgas to modify a group buy set of this battery charger with voltage monitor. Do I hear a second?
I had the same behavior on a triple 219C with the same banggood driver you had (used the Kronos X6 driver).
I’m not an expert, but what I saw was that too many amps caused it to shut off in the highest modes. The low vf of the 219C means that it’ll suck up lots of amps. I think I read that XP-G3s also have a low vf. If I used a regular NCRB, I could go to the high mode no problem. High drain cells just made it blink and shut off. Strobe mode wouldn’t work either.
I swapped it to an A6 driver, and it works fine.
I reused the driver with a triple XP-L and it just barely is under the amp threshold to cause the high mode to function. If I try to take a tail reading with my clamp meter, high mode doesn’t work because the low resistance of wire. But high mode works with the tailcap due to the added resistance. I think 14+ amps causes that banggood X5/X6 driver to act funky.
RMM said his driver wouldn’t have that problem due to better parts and layout.
I’ve been working on a mod for a few days and it seems that it can’t decide wether it’s a success or a fail. Is it possible for a flashlight to contract the ZiK virus and shrink its brain?
It all started out to be an RGBA using a board with four Luxeon Z. Unfortunately, the board that came with the four coloured emitters was square, so I had to grind it to fit a Convoy S2+.
Ahhh. There goes that stupid ouchyfoot again, always trying to fit a square board into a round hole.
I figured I’d grind and drill blank board, and then reflow the emitters from one board to the other.
I won’t do that again!
These little Luxeon Zs only like to be mounted once, at least on a multi board. I’ve done these boards before using a new board and new emitters with solder paste and everything snaps nicely into place. Taking them off one board and transferring them to another is a horror. They only have two pads with a hair between them, that goes for the board as well. Removing them, some pads retain solder, some come up bare, so more paste must be used.
The old solder doesn’t want to flow, and excess just spreads to fill the gaps between the pads, or attaches itself onto the neighboring emitter. Trying to shift them around just makes matters worse. The next thing you know, all four emitters are attached to each other all cockeyed. The more you work to fix it, the worse it gets. Finally the emitter pads are all clarted up with solder in one big shorted mass. Not to mention the ones that get tipped ove into the hot solder.
After an hour of work and six ruined emitters I said “to hell with this”. I went from RGBA to RGBR/O to RGBW.
Three deep breaths. I heated the board for the hundredth time and wiped off all the solder with a damp Brillo pad. Fresh start. Four new emitters. RGBW. All working.
One of the main reasons I wanted to build this light was to test that waffled optic. One of the main faults with multi die emitters that work independently in a reflector light is that because they are all offset, the beam profile looks like a donut with a bight out of one side. I was hoping this type of optic would even that profile out, and it does. I just thought I’d mention that now in case I lose my train of thought with my woebegone whining.
Standard RGBW driver. I didn’t bother changing the wires because it’ll only be driving one emitter at a time @ 700mA
I sanded and glued down a plastic ring to keep the optic centered.
Sure, it looks sweet, but there’s something wrong with its brain and I can’t figure it out.
((more whining to come after these messages)
Now the problem is that it cycles through all the modes W-R-G-B-police strobes etc just fine. Once, sometimes twice. The next time it skips the strobes and goes to white. Then it goes from white to red to white, sometimes a green shows up, the back to white then only white.
If I set it down for five minutes it works fine, then gets all mixed up again until I only get white. I’ve resoldered all the wires. (Cheap melting Chinese wire), beefed up the ground, but nothing works. It’s sporadic.
I’m in.
I don’t know anything at all about this kind of driver, but it seems like the MCU is getting hot or one of the Capacitors is. The emitters are working, the chips are working, the problem only starts when it heats up, so there’s something in the voltage to the MCU or the heat, which might be coming from the chips getting hot reducing 4.2V to 350mA. Sink the chips, see if that does it…
I don’t know exactly Ouchy, I have done several mods with this driver, even experimented succesfully with different resistor values and FET’s, but they kept working fine. Two observations that do give a clue perhaps what is happening, but may not get you to a solution:
*the driver is very sensitive to a lighted tailcap I found: I even tried without bleeder and with several bleeder resistor values, it all messed up the UI. So what is happening in the tail easily influences the driver timing. Did you do a spring by-pass, then try the flashlight without it, it may just improve. Try a lower drain battery, or higher.
*when the light is off, it resets to ‘start with white’ . In this driver this reset is fast, like 0.5 seconds. It sounds like perhaps that has become shorter than 0.5 seconds in your case. Try very short taps to change modes to try this idea out.
I though about the tailcap, and swapped out the back end from different S2s. I don’t think it’s the driver. There’s something else going on here.
I reheated a wiped the board so many times trying to reflow, that perhaps I ruined the integrity of one or more pads and the solder adhesion is iffy. Also. I ground down this board and drilled holes through the traces. Something could be moving once it gets hot causing some kind of short. Although the board isn’t DTP, it’s pretty nice. The entire surface is copper that is divided into eighths from the center out.
Wires? Who knows. If gone around and resoldered everything until all the cheap casings are melting into blobs. Still can’t be sure about the integrity of the pads.
Who knows, maybe the the AA isn’t cured completely and is causing a short. I removed the centering ring because it was sliding around and not curing to the mask.
I tried it a few minutes ago and it went through 8-10 cycles before it started glitching. Maybe it’s getting better. What if I wake up tomorrow to find it was all a dream and it works fine.
If it doesn’t get fixed I won’t have much choice but to scrape the whole board off and replace it with a standard RGBW emitter and board.
Did I mention that the optic is really good for these emitters?
Nice mod Ouchy. I like how you used the red, green and blue body pieces to go with your RGB emitter.
Where’d you get the optic?
I had a triple with individually addressable leds (same RGBW driver as Ouchyfoot used above but modified, and not using RGB leds, link) with one of the leds a Pro-Light PC-amber one at ~5.5 lumen. On holidays when camping, or otherwise away from home with the family, I have used it as a night light for my son because he is afraid in total dark, it runs for 11 hours per night. But I like using it as my EDC as well, so it bothered me that I could not use it when he is asleep. So tonight I made a new flashlight with this led especially as his night light. The requirements: a ~5 lumen setting, safe, reliable, good runtime. I used:
*a Convoy S3 host I had around for ages and never felt much love for,
*a ProLight PK2N PC-amber led,
*a BLF-A6 driver (the led has such a high voltage that direct drive on a 18650 it still draws well under 2A),
*and did 2 spring bypasses to at least get some light out of it on high setting (for my own pleasure, the night light mode is only 30mA).
Because of the high voltage of the led, mode 4,5,6 and seven have close to the same output, but mode 2 is a nice 3 lumen setting for night light use (mode 3 is 30 lumen, a bit too much). I run it on a protected NCR18650B for good runtime, the 30mA/3lumen night light mode runs for 110 hours, with the light being on all night for eleven hours, this means 10 nights on a battery. The highest setting is 1.13A/190lumen.
edit: I pimped the light a bit with a red tail cap and a red o-ring, and I must admit that despite it being a Convoy S3 it looks alright now:
