【New】The Next Generation Of 18650 li-ion Rechargeable Battery?
18650 only suit for the original cell ? :person_facepalming:
Nah
18 mm diameter
65 length
0 shape
The Panasonic protected cells and many others are longer and a tad thicker
But the general consensus seems to be anything from
18 - 19 mm diameter
65 - 71 mm length
Round cells
Are named 18650 since people would probably get confused and well I really like being able to explain to people “Tesla uses these 18650 cells, they pack quite the punch” since people get it then. And I like doing this even while holding a protected cell :wink: so just stick with it lol
Since there is no standard for “common 18650 battery with protected circuit board” - could you tell us the exact total length of your cell?
The total length is 70.7mm ~
Pls check details here:http://www.lumintop.com/lm34c-usb-rechargeable-18650-li-ion-battery.html
And how much does the charging circuit add to the price? I doubt this is the next generation of liions….
I like the idea - they charge at the regular USB current? what if they get connected to USB 3? Can they go up to 900mAh or even 1.5A?
I don’t really see the point.
When you have the battery out, isn’t it easier to just put it in the charger, than fiddle with these tiny usb connectors that are not made to withstand hundreds of plugs/unplugs anyway?
No indication of charge and extra long battery that won’t fit anywhere as a “bonus”.
Useless gadget.
it might be useful for travel purposes, when the light you are traveling with doesn’t have a charging port and you don’t want to carry an additional charger or power supply unit.
The big plus (for me that is, ignorng Brinyte stating it should not be done) is the fact that I can charge them with 1000mA (a normal charger) AND 750mA (the build in charger) to have a total of 1750mA thus much faster charging.
Another really big plus is the fct that I do not need a charger in the car. I have a little car adapter for charging of phones and tablets and an inverter to charge notebooks and that too has a USB out.
These can be used with the USB cable already in the car, so as a matter of fact the Brinyte cells hav given me more spac in the glove compartment :+1:
But, when you wanna charge 4 batteries, you need 4 cables and someting with 4 usb ports, not very likely to be had by most users.
You would just use w regular charger of you had for to charge. You can use external and internal charging with them
Still, not worth the price difference.
We need standards.
A 18650 battery that is 70.7mm is or should not be labeled 18650.
Well people like higher numbers
So a flashlight labelled 18650/18700 capable and a cell labelled 18700 could seem better then that 18650 cell :smiley:
I fear it would be more confusing for the general public but I think that the first who offers 18700 flashlights and cells could also sell more just because it had higher numbers on it.
But who would take the gamble?
No, no, no:
10mm diameter
650 1/10mm in length
IC*R*18650, IM*R*18650, IN*R*18650 : The R means round
PS: Why do I have the line with Bold, Italic, etc. when it do not work!
Ah OK
(The _ & * do not like numbers)
I understand your comment and reasoning, but it assumes the buyer or consumer is not smart enough to comprehend the dynamics of the batteries being used.
If the amount of profit made by selling ‘protected batteries’ to an unsophisticated public is a guide, then who knows what other great ‘new’ batteries will be released.
The ‘lowest common denominator’ is not a principal I would like to see in innovative flashlight or battery design.
+1
The main reason I favor single cell flashlights is the ease of carrying a spare battery to change in the field if needed.
In this case a battery with a built in terminal for charging would also need a power-bank or charger; I would not find this a convenience.
The numbering is intentionally ‘nominal’ to allow for slight variations from different manufacturers, but IMHO a 5mm or more difference isn’t nominal and should be noted through use of a different number. Had they started with different more true descriptions (which they should have done) it would work, but now it would just confuse the average person even more. At least we’re smart enough to check for the length before buying :wink:
Phil
