The Panasonic protected cells and many others are longer and a tad thicker
But the general consensus seems to be anything from
18 - 19 mm diameter
65 - 71 mm length
Round cells
Are named 18650 since people would probably get confused and well I really like being able to explain to people “Tesla uses these 18650 cells, they pack quite the punch” since people get it then. And I like doing this even while holding a protected cell so just stick with it lol
I don’t really see the point.
When you have the battery out, isn’t it easier to just put it in the charger, than fiddle with these tiny usb connectors that are not made to withstand hundreds of plugs/unplugs anyway?
No indication of charge and extra long battery that won’t fit anywhere as a “bonus”.
Useless gadget.
it might be useful for travel purposes, when the light you are traveling with doesn’t have a charging port and you don’t want to carry an additional charger or power supply unit.
The big plus (for me that is, ignorng Brinyte stating it should not be done) is the fact that I can charge them with 1000mA (a normal charger) AND 750mA (the build in charger) to have a total of 1750mA thus much faster charging.
Another really big plus is the fct that I do not need a charger in the car. I have a little car adapter for charging of phones and tablets and an inverter to charge notebooks and that too has a USB out.
These can be used with the USB cable already in the car, so as a matter of fact the Brinyte cells hav given me more spac in the glove compartment :+1:
Well people like higher numbers
So a flashlight labelled 18650/18700 capable and a cell labelled 18700 could seem better then that 18650 cell
I fear it would be more confusing for the general public but I think that the first who offers 18700 flashlights and cells could also sell more just because it had higher numbers on it.
But who would take the gamble?
I understand your comment and reasoning, but it assumes the buyer or consumer is not smart enough to comprehend the dynamics of the batteries being used.
If the amount of profit made by selling ‘protected batteries’ to an unsophisticated public is a guide, then who knows what other great ‘new’ batteries will be released.
The ‘lowest common denominator’ is not a principal I would like to see in innovative flashlight or battery design.
The numbering is intentionally ‘nominal’ to allow for slight variations from different manufacturers, but IMHO a 5mm or more difference isn’t nominal and should be noted through use of a different number. Had they started with different more true descriptions (which they should have done) it would work, but now it would just confuse the average person even more. At least we’re smart enough to check for the length before buying
