Kerui Electronic Industrial DTP copper mcpcb
Hi
We currently make DTP copper mcpcb many,any size have,We customize and design MCPCB according to customer requirements.
Sometimes,we made some standard DTP copper mcpcb,such as 10mm,16mm ,20mm,31.6mm with cree xml and xhp50 xhp 70.
Thank you
Sundy
leo ou
It would be great for you/and us if you consider producing a NON DTP( thats a must) copper XBD 16mm copper pcb- there isnt such pcb awailable at the market and those IR Oslons badly need one :wink:
yes,if you need,we can make copper mcpcb for you.
Thanks
Sundy
Hey all,
If anyone is curious here are the results I got from purchasing from this company :slight_smile:
Thank you for making this possible Sundy.
Well, at least with regards to those leds with a lack of thermal pad, no one wanting to ask for an orders of magnitude improved thermal conduction dielectric?
Cheers ^:)
Today I received an order of ledboards that I had made by Shenzhen Kerui Electric Industry. It is 128 pieces of Nichia 119 16mm diameter non-DTP boards, but I tried to maximise the heat path of the boards. For several leds without central thermal pad I would have liked this type of board but I could not find it: Nichia 119, Nichia 276A UV, LuxeonZ will fit too, and the new large Nichia’s (if available at some point) will work too by scraping off some solder mask. The costs for the 128 boards (I ordered 100 and they made 128) were, including shipping and taxes from dutch customs, 258 dollar, so about 2 dollar per board. I’m going to test these boards against a ‘standard’ alumnium Nichia 119 board (came with my Convoy S2+ 276A UV light) to see if they really do a bit better (but I do not expect DTP performance).
I’m going to sell these here on BLF for 2 dollar each plus shipping, so cost price. I have no idea how many people are interested, and it may depend on how well they test :slight_smile:
Details:
–16mm diameter, 1mm thickness to support many common flashlights
-core = copper
-the two electric led-pads widen in a as large as possible pour to help the heat to go sideways and then pass the dielectric layer over a larger surface area.
Thanks for letting us know djozz
With the Nichia119 board order I received a couple of their XM-L/XHP50 DTP boards for free, which is a nice gesture. I believe these are the same that vestureofblood sells at the moment. They look good and I checked how flat the pads are with a razor (good!) and also sawed one in half to check the DTP pad (good too!). I see no reason yet why these boards would not perform very well. Here’s some pictures:
Sweet. SO the pad is actually raised up in the center above the dielectric layer. It looks like only the thickness of the solder mask layer is counter sunk.
EDIT: If you dont mind can you post that picture of the cut away in my thread here also?
Yes sure, I posted them there too :slight_smile:
Nice!
Now, where are those beryllium oxide and/or synthetic diamond dielectric MCPCBs?
Cheers ^:)
[quote=djozz]
Thanks for doing those, djozz. I’ll be in for a few.
Not for me djozz but love the hacksaw work. Thanks for taking up the initiative for others here. :beer:
Hi Jos
Thank you for your post,But I did something wrong about the express and got you into complicated custom duty trouble later.
This time I got a lot of lessons.
Sundy
Two Side direct thermal path copper mcpcb use for headlight.
Wow! Who are those for?
Hi
It mainly use for automobile headlight,as this product
But This design is two side derect thermal path copper mcpcb,there is two sides have circuit.
This design is in order to better solve the heat dissipation problem.
Sundy
Nowadays,direct thermal path mcpcb not only use flashlight,but also other area.
For example automobile headlight also have thermal request.
UV source
High power Stage light
Friend,
This is flashlight forum. There are lot of diy flashlight modders here.
So I bet any kind of flashlight dtp MCPCB’s (small, medium large, triple) will be appreciated here, and of course please put more nicer pictures of them.
