Review: UniqueFire UF-F10 (Fenix TK35 clone)
38 posts / 0 new
JohnnyMac
JohnnyMac's picture
Last seen: 3 days 9 hours ago
UniqueFire UF-F10
Disclaimer: Light provided by Tmart.com for review
Specifications from site:
BrandUniqueFire
ModelUF-F10
Emitter TypeCREE T6
Lumens1000 Lumens
Power10W
Bulb Quantity1
Light ColorWhite
Lightbulb Lifespan100000 hours
Modes6
Mode ArrangementHi > Mid > Lo > Strobe > SOS
Lighting Distance100m
Battery Configuration2 x 18650 Batteries (not included)
Input Voltage7.4V-8.4V
Runtime3-4 hours
Switch TypeClicky
Switch LocationTail-cap
LensCoated Glass Lens
ReflectorAluminum Smooth / SMO Reflector
MaterialAerospace aluminum alloy
ColorBlack
Dimensions6.42" x 1.89" x 1.61" / (16.3 x 4.8 x 4.1) cm (L x Head Dia. x Body Dia.)
Weight259 g / 9.14 oz
WaterproofYes
My Specifications:
Dimensions
Lens:41.7mm x 1.66mm
Pill:45mm x 9.27mm
Reflector:42.78mm x 31.05mm
Emitter:Cree XM-L T6 1C
Modes
Group 1Low > Medium 1 > Medium 2 > High
Group 2Strobe > SOS
Memory:No
OTF Output
High544 OTF
Medium 2246.5 OTF
Medium 157.7 OTF
 Low17.31 OTF
Primary switch:Forward clicky (main power)
Secondary SwitchMomentary (mode selection)
Price:$26.63
Provided by: Tmart.com
PROS
  • Very nice build quality
  • Clean threads.  Most all are square and anodized.
  • Threads came extremely well lubed with grease.
  • For putting out only 544 lumens at what I'd figure to be 1.7A to LED, it is extremely bright looking.
  • Fantastic throw for the reflector size and being mildly driven.
  • Super smooth, ringless spill.
  • 4 very useful modes.
  • Great low mode.
  • PWM exists but is higher than most budget lights.  Not noticable at all to me.
  • Arrived in very good shape with no scratches or nicks.
  • Momentary on for signalling
  • Separate mode switch
  • Separate mode groups.  Strobe modes are available but not until you want them.
  • Strobe is a changing police style alternating between rapid and normal.  Very effective!
  • Flat body is easy to hold and comfortable.  Fine ribbing provides great grip.
  • Plenty of room in cell cartridge for all 18650 cells, even those 18700 Xtars.
  • Great runtime.
  • Entire head, including reflector, is a 114.6g heatsink.
  • The price! $26.63 for a TK35 clone?? I don't know how they do it but I'm not arguing.  If Tmart hadn't offered to provide this I would have bought it anyway.  I've been eyeing this one up for a long time.
CONS
  • Could easily handle more amperage.  Not as bright as the original TK35.
  • While the hot spot is very small, it does have a fairly large corona.
  • Always starts out on low and has no memory.  A negative for some and a plus for others.
  • Does have PWM in lower modes but is much better than most budget lights I have.
BUILD QUALITY
I expressed interest in this light to Louis Huang and he kindly offered me a coupon worth full value of the light in return for an honest review.  This was not a ringer light hand picked by Tmart for the review.  When this model finally hit the US warehouse I promptly ordered it from their site and received the light in the usual pre-popped bubble bag inside the standard crushed white box which, in turn, was in a non-padded plastic shipping bag.  Miraculously the light survived in perfect shape and working order.
Build quality of the light is really great.  All threads are square and anodized except for those on the actual pill and reflector.  Those are not anodized but are cleanly cut and glide smoothly into the square-cut anodized threads of the head.  Plenty of grease had been applied by the assembler and all o-rings are of the perfect diameter and thickness.  I will go into greater detail of the different areas as the pictures progress.
This light is a clone of the Fenix TK35 and does everything right to live up to that standard except that it could be driven a little stronger for higher output.  Dr. Jones did a comparison between another clone and the TK35 and the TK35 was a little bit brighter. I'd imagine the same would be found here.  Unlike the TK35's plastic body, the UF-F10 is machined from aluminum billet and does everything right.  All parts disassemble easily and fit tightly.  Machining on the parts is great.  The superfine ribbing on the body provides excellent grip inspite of the fact that it looks like it wouldn't.  All laser etching is clear and solid.
PERFORMANCE
In spite of the fact that it is way under driven, performance should be the UF-F10's middle name.  It throws like a light far larger, provides a creamy smooth beam even though it has a smooth reflector, and has 4 very useful output levels while providing hidden but easily accessed blinky modes.  Even the strobe is a debilitating alternating type that will mess you up if you leave it on too long.
As you will see in the pictures, it has a very small hotspot and would appear to be the equal of the 980L/KE-5/BT-950L variety of highly regarded compact throwers.  With more juice being applied to the emitter it would more than hold it's own against them all the while providing twice the runtime due to the parallel battery cartridge that runs the cells in series for 8.4 volts.
No green or purple tint from my example either.  While still a CW emitter, it must be a 1C tint due to the creamy white it puts out.  The 4 modes range from 17 easy lumens up to 544 OTF lumens on high.  It appears even brighter than that to the naked eye.  The only complaint I have about the beam profile itself is a rather large corona around the center hot spot.  The hot spot itself is as small as that on the HD2010 but on the HD2010 there is almost no corona, just a concentrated center spot.  You can see this later in the beam comparison photos.
Heat should be a non issue thanks to the huge pill and a massive reflector base that mates to the pill to create one gigantic heatsinking mass.  Combine that large mass with it's combined inch of threads into the all aluminum head and the entire thing becomes a massive heat sink.  Go further and combine that to the aluminum body and you really have a winner.  The cells are isolated in a polymer cartridge style holder to insulate the cells from any heat being transferred from the body.
Speaking of the battery cartridge, the cartridge on this light contains all switches and driver.  The very large driver is not easily swapped out for a different one.  I plan to attache a variable POT resistor to dial in extra current in mine bringing it up to 3+ amps to the emitter.  The light is just too good to not crank up the amount of light potential it holds.  Our good DrJones upgraded his clone with one of his custom Nanjg drivers reprogrammed for use with secondary electronic switches but that also requires rewiring the actual cartridge from series to parallel.  I think my way will be just as effective but far simpler.
PICTURES
They say a picture speaks a thousand words so I will let the light itself do all the talking except for a little side commentary by me.  Here we go...
A very compact design, the body has a large, heavy head with a flat, easily pocketable body.  Perfect for a jacket pocket or for those of you with carpenter pants or cargo pockets.
The main body is flat due to the parallel battery format.  All transitions are tapered allowing fairly snag free entry and removal from your holster or pockets.  The UniqueFire logo and model are cleanly laser etched onto one side of the body.
 The Cree log is etched into the opposite side of the body.
 Some very cleanly machined finning increases surface area for more cooling capability.
 Here you can easily see the flat body design and fine ribbing on the outer edges for grip.
 A closer look at the laser etching and the nice machining of the flat and recessed areas.
 The "Hot Surface" isn't really all that hot due to the shear mass of the head and mildly driven emitter.  I hope to change that once my new POT resistors arrive.  J)
 The indestructible dust in my house ruins what would be a great shot at a very clean, well designed reflector but still shows the perfectly centered Cree T6 emitter.
 A closer look at the finning and ribbing on the body.
 A good look at the excellent fine ribbing on the outer edges of the body.  They may not look it but they provide fantastic grip on the light while not being too rough like the knurling on some lights or too useless like the knurling on other lights.
 At the rear of the light we find the switches. On the left is the smaller mode changing button and on the right, the larger forward-clicky main power switch with momentary on.  Lanyard holes on either side are large enough to fit 550 paracord or large split rings.
 Here is a look at the torch opened in the middle with the cell cartridge out.
 Take note at the extremely well-lubed, square-cut anodized threads in the head.  These run almost to the very front of the light.  All head components are accessed through the rear of the head.  There is no removable bezel and therefore one less threaded joint to worry about leaking.
 Here is the contact PCB for the emitter.  There is no driver behind it.  The center spring is for the anode (+).  Note the even soldering nearly all around the base of the spring.  This tells me that care was taken by a skilled pro when being assembled.  The silver ring with the three raised prongs is for the cathode (-).  These 4 contact points mate with the rings on the actual driver PCB which is located in the battery cartridge.
 Under that PCB we have the rather heavy gauge wires going directly to the emitter PCB.  Heavy solder beads anchor the outer cathode ring to the PCB from behind.  You can see just how massive this pill is.
 Here is the pill removed from the head.  It contains the XM-L emitter on a 20mm star.  The centering insulator helps to perfectly center the reflector.
 Under the pill is the massive reflector base.  Lets unscrew that as well and have a closer look.
 Here is the reflector as seen from the rear.  The reflector and it's base are one solid piece of machined billet.  Threads are deep and clean.
 Here is a better look at the reflector from the side.
 Here is a front view of the reflector.
 When the reflector and pill are assembled in the head, they mate together as seen below and this allows the pill to conduct heat into the reflector, utilizing it's mass to keep things cool.
 A better look into the head.  Here you can see the square threads without all the grease.  You can also see the groove just behind the bezel lip where the o-ring sits.  The lens goes behind that then, of course the reflector and pill follow.
 Here are the head components all together.
 The lens is 1.66mm thick.  If the lens is AR coated I cannot see it.
 It is also 41.7mm in diameter.
 The pill and reflector base are both 45mm in diameter.
 The pill is 9.27mm thick.
 The reflector is 42.78mm across...
 And is 31mm deep.
 Here is the body with the cartridge removed.
 A look inside shows us how the outer buttons connect with the switches in the tail of the cartridge.  Note the notch in the left side of the body opening.  This accommodates a bumb in the side of the cartridge to ensure that the cartridge only goes in one way - the correct way.
 Here is a shot of the light disassembled and the button plate removed from the body.
 A closer look at the tail piece/plate.
 And the underside where extensions link the outer buttons to the actual switches in the cartridge.
 Rear of the body where the tail plate mounts via four screws.
 In this shot you can see how there is still plenty of room for even 18700 protected Xtar cells to fit.  Flat-topped and button-topped cells all work.
 With the white rear switch cap removed from the cartridge we can see the switches for power and modes.  Pressing on the power switch will only allow on/off and signalling.  Only the smaller momentary switch can change modes.  Long pressing the mode switch changes between mode groups.
 Here we see the contact side of the driver PCB.  It is held in the cartridge with 4 screws.  The inner dot is for the positive connection and the outer ring is the negative connection.
 Here is what you will find under all that.  It's a 2-part buck driver.
 These R1 & R2 pads have the resistors that set the output amperage.  This is where I will be attaching by adjustable POT resistor to pump up the output.
 Fully assembled the head weighs in at a hefty 114g.
BEAMSHOTS - Everybody loves beam shots!
Here you get a great idea of the beam profile and how nicely collumnated the beam is for great throwing.
Smooth, smooth, ringless spill!  In person the light is creamy white with no green or purple tint anywhere.
With the white balanced turned down a notch you can see the center spot and the corona.
Bumped down another notch...
And one more for good measure.
Here we have the UF-F10 next to the HD2010 to get a good idea of what to expect.  Keep in mind that the UF-F10 is only driven at around 1.7A.  The spill on the HD2010 obliterates the spill on the UF-F10.
Let's knock down the white balance so we can see what is happening in the pic above.  You can see how the corona was making the UF-F10 appear brighter in the pic above.  In reality, the hotspot on the HD2010 is much brighter but it should be at twice the driven amperage.
Instead of apples to oranges, let's compare apples to apples.  Here I am going to put the UF-F10 next to the KE-5/BT-950L light.  While still comparing 1.7A to 3A, the reflector and head sizes are pretty close this time and offer a more fair comparison.
In spite of the UF-F10 being driven little more than half as hard, it holds it's own against the KE-5.  That corona is the only annoyance.
Bumped down another notch you can see the tint difference even though the pic does not show what you actually see.  You can see that the KE-5/BT-950L is much colder but not a heck of a lot brighter.
With the white balance turned all the way down the coronas look pretty similar and the UF-F10 just might have a cleaner edge around the center hot spot.
CONCLUSION
This light gets an enthusiastic "JohnnyMac" thumbs up!
It has a couple flaws but none that can't be remedied by more power.  At just $26.63 for a TK35 clone, I believe it is the lowest priced clone of it's type available anywhere.  Build quality is great (as the pictures show) and performance is surprisingly good for how modestly it is driven.  Add in 4 great modes and hidden blinky modes and there is little to complain about.  It didn't come with a lanyard or extra o-rings but I really don't care.  If anything ever happens to this one I won't hesitate to buy another.  Everything that made the original Fenix TK35 great lives in this clone.  For the money I can't recommend it enough!
On a side note, since Tmart was gracious enough to send me this light and brave enough to let the chips fall where they may, I ask that you support them whenever possible.  If you are considering getting this light for yourself, please buy it from them.  Can't beat the shipping time (1 week for US residents) and the price (almost $10 cheaper than anywhere else I've seen).
This wraps up the review.  Feel free to comment and discuss.  Thanks for watching!
Johnny
Edited by: sb56637 on 08/26/2014 - 17:20
JohnnyMac
JohnnyMac's picture
Review complete and ready for your critique. Wink
CheapThrills
CheapThrills's picture
Last seen: 2 weeks 1 day ago
Very informative! I had no idea this pretty affordable look-alike had this MASSIVE heat sinking!!! Shocked
It really needs just a bit more current. What other lights there are in this price range, that have good, threaded pill AND threaded reflector made out of aluminum??
I just regretted my ZY-T08 purchase, I think this would have been even better option for the same price 8)
rikr
rikr's picture
Last seen: 5 months 4 days ago
Another Awesome review John!!! If I didn’t already have it I would be buying one… Great job!!
 New Collection / Old Collection
MarioSS
MarioSS's picture
Last seen: 6 years 10 months ago
Damn that was close call for me lol!
Was sooooooooo damn near buying a ZY-T08 but now Johnny made me think twice!
Which one would you choose Johnny if you dont mind me asking?
Thanks JohnnyMac for the great review! Glasses
Anyone can recommend any other place to get that baby from other than Tmart would prefer not to deal with them?
rikr
rikr's picture
The T08 out throws the UF-F10 easily…
MarioSS
MarioSS's picture
I just compared they reflector size and damn the T08 reflector is huge compared ot the F10!
Rikr may i ask what battaries you run in your T08? I am asking coz am not sure if my Keeppower 18650 3400’s will work purchased from Bob
JohnnyMac
JohnnyMac's picture
MarioSS wrote:
CheapThrills wrote:
Very informative! I had no idea this pretty affordable look-alike had this MASSIVE heat sinking!!! Shocked It really needs just a bit more current. What other lights there are in this price range, that have good, threaded pill AND threaded reflector made out of aluminum?? I just regretted my ZY-T08 purchase, I think this would have been even better option for the same price 8)
Damn that was close call for me lol! Was sooooooooo damn near buying a ZY-T08 but now Johnny made me think twice! Which one would you choose Johnny if you dont mind me asking? Thanks JohnnyMac for the great review! Glasses Anyone can recommend any other place to get that baby from other than Tmart would prefer not to deal with them?
I cannot give an honest answer to that question since I don't own a T08 yet.  Ironically, DX is sending me a T08 for review and it supposedly shipped out already.  Since I didn't order it I have no tracking information but as soon as it arrives it will get the same tear down treatment as the UF-F10.
Rikr does have both lights and one thing he said that I can guarantee is the T08 will out throw the UF-F10.  The F10 is not designed to be a dedicated thrower like the T08 is. It's more of an all purpose light that happens to have a wonderfully focused beam.  It depends on what your end goal is for the light.  From what I've read I can pretty much bet that the UF-F10 has a much higher build quality than the T08.
MarioSS
MarioSS's picture
Thanks bro for the honest reply Star
rikr
rikr's picture
I have HI-Max 18650’s in there and also have had no problems with TrustFire 3000, Xtar 3100
Chicago X
Chicago X's picture
Last seen: 9 years 2 months ago
Very nice review.
The threaded reflector is a nice touch !
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
rikr
rikr's picture
JohnnyMac wrote:
I cannot give an honest answer to that question since I don’t own a T08 yet.  Ironically, DX is sending me a T08 for review and it supposedly shipped out already.  Since I didn’t order it I have no tracking information but as soon as it arrives it will get the same tear down treatment as the UF-F10.
Rikr does have both lights and one thing he said that I can guarantee is the T08 will out throw the UF-F10.  The F10 is not designed to be a dedicated thrower like the T08 is. It’s more of an all purpose light that happens to have a wonderfully focused beam.  It depends on what your end goal is for the light.  From what I’ve read I can pretty much bet that the UF-F10 has a much higher build quality than the T08.
I agree that the beam on the UF-F10 is a all around more user friendly light, since the T08 is geared for throw.
MarioSS
MarioSS's picture
great thanks for the replies guys.
CheapThrills
If budget remains the same and you can sacrifice the parallel 18650 format, I would suggest ZY-T13 for better overall quality than ZY-T08.
Yet again, T13 also need more power by soldered resistor… But I´m pretty sure it is capable of similar throw as T08 when both driven at same current.
MarioSS
MarioSS's picture
I hate its size tho ><
rikr
rikr's picture
I like my T13 better than the T08, and they are really close in throw to each other.
jfalk1
Last seen: 2 weeks 2 days ago
your commentary and found myself nodding in agreement ….“Oh I see kind of moment”…and in addition just really presenting your product with the intent on educating those,including myself ,who is very much new at this and still looking to match up “flashlight terminology with pictures of said termins”!!Absolutely enjoyed it. jensen
CheapThrills
The form of T08 is nice, I can´t argue with that.
T13 just has so good UI. Instant HIGH always on tailcap and easy step-down with Side-Clicky and you don´t need to cycle through nasty disco-modes 8)
No loose driver PCB´s, no issues whatsoever.
I just wish I would soon get those resistors…
jacktheclipper
jacktheclipper's picture
Last seen: 12 hours 26 min ago
Excellent review , sir .
I will buy your modded version when you tire of it .
Laughing
What I do
gords1001
gords1001's picture
Last seen: 4 years 3 months ago
Given that most of the t-08’s are coming in driven at about 2a, if you want to make the most of it, your still either going to have to fit a .22ohm resistor or a pot. I’m waiting to see what the pot johnny’s ordered reads as mine is to high.
Another thing to note, I found my crap ultrafire cells gave 3a where other better cells only gave 2.34a. Viffer noted that the driver is odd in that its very responsive to resistance in circuit, unfortunately, I’ve not found any mods to the host that raised drive current.
Looking at this, I wish I’d sprung the extra few cents for the tk-35 clone.
Johnny, how were the tail cap screws? This is a real bug bear of mine with my zy-t08, their just crap quality. Great review, thanks for sharing.
JohnnyMac
JohnnyMac's picture
gords1001 wrote:
Given that most of the t-08's are coming in driven at about 2a, if you want to make the most of it, your still either going to have to fit a .22ohm resistor or a pot. I'm waiting to see what the pot johnny's ordered reads as mine is to high. Another thing to note, I found my crap ultrafire cells gave 3a where other better cells only gave 2.34a. Viffer noted that the driver is odd in that its very responsive to resistance in circuit, unfortunately, I've not found any mods to the host that raised drive current. Looking at this, I wish I'd sprung the extra few cents for the tk-35 clone. Johnny, how were the tail cap screws? This is a real bug bear of mine with my zy-t08, their just crap quality. Great review, thanks for sharing.
Gords, the tail piece screws in mine were fine.  None were stripped and are of decent quality.
As for the pots I ordered, I got the ones Viffer recommended from ebay.  Dirt cheap, too!
http://www.ebay.com/itm/250853024381?ssPageName=STRK:MEWNX:IT&_trksid=p3...
gords1001
gords1001's picture
Nice one, now I’m really thinking I need to buy this too…. I’ll just plump for it and order a few of those pots next week. Do us a favour, when you do the mod, could you take some macros and add them here?
I guess you know what I’m thinking….another damm good post and review for the mod reference guide. 8)
JohnnyMac
JohnnyMac's picture
gords1001 wrote:
Nice one, now I'm really thinking I need to buy this too.... I'll just plump for it and order a few of those pots next week. Do us a favour, when you do the mod, could you take some macros and add them here? I guess you know what I'm thinking....another damm good post and review for the mod reference guide. 8)
Soitenly. Wink
BetweenRides
BetweenRides's picture
Last seen: 4 years 1 month ago
Excellent review as always, JohnnyMac! I do like this light, looking toward to your power mod.
_the_
_the_'s picture
Great review! Very thorough with plenty of photos – hours and hours worth of hard work. Thanks for sharing! Smile
=the=
gords1001
gords1001's picture
I don’t care what anyone else says, you rock my man. Steve 8)
garrybunk
garrybunk's picture
Last seen: 2 days 23 hours ago
Thanks Johnny!  I really wish they made this light with batteries parallel.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
how2
Good review Johnnymac,seems like Tmart has the best price for the TK35 clone.
They are all the same you can only go on price and overall quality when deciding whom to buy it from.
sb56637
sb56637's picture
Last seen: 1 hour 3 min ago
Thanks very much for the review! Frontpage’d and Sticky’d.
bob_ninja
Last seen: 4 years 7 months ago
Since vast majority of XML lights are driven well over 2A, I am actually happy to find one that is below. I use recycled cells from laptop batteries and they don’t handle high 2+ amps well.
I thought there were many other 2×18650 lights at 3A and 4A. In fact I have one with 3 XMLs at 4A max mode. It gets very hot very fast and cells are working super hard. I don’t find it useful or safe. Even medium mode at 2A I use only for 5-10 min max.
Nice to have lower current choices Smile
No really I am not flashoholic! Really I am not Sad
agenthex
agenthex's picture
Last seen: 8 years 10 months ago
Seems same as all the other tk35 clones, but this one won the tint lottery since most are blue.
Reading this makes you smarter: http://lesswrong.com/
