Making a 12-Up out of Mini-Mags and Nichias. It's Finished and BEAM SHOTS are up now!!
118 posts / 0 new
Rufusbduck
Rufusbduck's picture
Pushing the envelope… aggressively.
I did locate 4 matched 14500’s so if no one in TGST can help, pm me and I’ll pop them in the mail. eBay Paisen cells but 3.7V Liion.
Scott
Old-Lumens
Old-Lumens's picture
Last seen: 4 years 4 weeks ago
The light is done!
@RBD - Thank you, but I want to use IMR. I do not think anything else will give me 3 amps per battery. If worse comes to worse, I will buy four of the Efest, but I will wait to see what everyone says. I think they will have to be IMR, to give the full potential to the light.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
MRsDNF
MRsDNF's picture
Last seen: 3 weeks 2 days ago
That second last shot came as a bit of a surprise. In my deference I have never had anything to do with Mag lights. How small are they. I’m looking forward to your beam shots. Did you think of maybe putting a handle on it. This may help to prevent it rolling as well as something to hold the torch(s) with. Again you have raised the bar in my book with your own ingenious style. Thanks.
Rufusbduck
Old-Lumens wrote:
The light is done!
@RBD – Thank you, but I want to use IMR. I do not think anything else will give me 3 amps per battery. If worse comes to worse, I will buy four of the Efest, but I will wait to see what everyone says. I think they will have to be IMR, to give the full potential to the light.
I think you are right as icr cells are limited to ~2C. This seller is pretty fast and very reasonable. Some one near you might be able to charge them as they usually ship with half charge.
Scott
Old-Lumens
Rufusbduck wrote:
I think you are right as icr cells are limited to ~2C. "This seller":http://item.mobileweb.ebay.com/viewitem?itemId=230910998203&index=2&nav=... is pretty fast and very reasonable. Some one near you might be able to charge them as they usually ship with half charge.
That was the seller I was thinking of. If I do it, I will have to get a charger. I don't know that I will though. There's already about $150 tied up in this build if I consider everything involved, so I'm not really enthusiastic about throwing $50+ more into batteries and a charger.
This light really has turned out to be a one of a kind hopeless case. It looks great and I know it works, but it is a real ornery light when it's time to change batteries. It's just not made right for battery changes and the cut down thing was a mistake. I should have left the bodies 2AA and made a totally different way to hold the tail ends together. This one ends up being just a shelf queen, for if anyone has to change batteries more than once, they will want to leave it on the shelf. They are just not all winners, when it comes to mods. I may have to just tear it down to try and save what I can in the way of components, but I hate to do that.
Actually, I probably need to rework the tail end. The bodies need to have something that surrounds the tail ends and holds them without moving. I probably could figure out something, but I don't know yet.
skyrider1
Last seen: 1 year 6 months ago
Wow! This is probably the coolest build I’ve seen yet. You have a little sun in the palm of your hands. Can’t wait for the beamshots
Rufusbduck
It looks pretty damn cool to me and I’m sure something could ease the battery changes, maybe a screwdriver slot in each cap with a bit of your file work to dress it up. I have 2 efest 14500’s and could order two more, charge the bunch and ship them. They’d be ok for testing/beamshots but I would be reluctant to use them as a set for run time testing even though the two I already have have only been cycled a few times.
Scott
Old-Lumens
Rufusbduck wrote:
It looks pretty damn cool to me and I'm sure something could ease the battery changes, maybe a screwdriver slot in each cap with a bit of your file work to dress it up. I have 2 efest 14500's and could order two more, charge the bunch and ship them. They'd be ok for testing/beamshots but I would be reluctant to use them as a set for run time testing even though the two I already have have only been cycled a few times.
Thanks, but don't go buy anything. I would feel bad about that. I have to figure out something with the tail end, that's for sure. If I don't buy batteries, I will most likely come up with a way to use 12 eneloops for testing and beam shots.
I like the screwdriver slot idea!!  The tail caps aren't really that bad, but it's the fact that the bodies can "wiggle" and misalign that is the real problem. I think that the copper plate needs to actually fit around each body, so that it does not move at all. That is what I am going to look at. I will also look at some kind of a slot.
Old-Lumens
Well, if r-sales can charge them for me, I will get four of their Efest batteries. If not, I will use eneloops somehow. I tore down the light tonight to make changes to the copper end plate. I am making it so the bodies are captured in the plate so they can't shift. Maybe tomorrow or Saturday I will have revision 1 done.
JamesB
Last seen: 10 hours 4 min ago
Badass and elegant, fantastic.
Hill
Hill's picture
Last seen: 1 year 11 months ago
O-L
Great job.  Another one-of-a-kind O-L specialty!  You HAVE to give us more glamor shots of that beauty.  So much time and effort put into it, let's see that bad boy (or girl?) from every possible angle.
Congrats!!
My lights here and here
RaceR86
RaceR86's picture
Last seen: 4 years 10 months ago
As always, love following your projects!
This one was very unique and original. Well done! Smile
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Old-Lumens
Hill wrote:
O-L
Congrats!!
She must be a female, since she's fought me every step of the way. Tongue Out
I guess I will have to take a few more shots of her, including beam shots. I am ordering the batteries today, so sometime next week for the beam shots and the glamour (sales thread shots) too.Wink
Slim Pickens
Slim Pickens's picture
Last seen: 1 week 4 days ago
Old-Lumens, this looks fantastic! Bravo. I’m sure you can work out the kinks.
Hopefully someone can charge those 14500s for you. Heck I’d be more than happy to charge them for you. It might be a good opportunity for you to try out Li-Ion and see what you think, especially since IMR/LMR cells aren’t made from explodium like the more-common LiCo cells Silly
DB Custom
DB Custom's picture
Last seen: 2 weeks 15 hours ago
As you know, I’m only a couple of hours away. I can easily send you a charger to use, wish I had 4 cells I could then just bring em over. I have to drive up to Cleburne tomorrow anyway. I only have AAA Efests though. Could you make those work for testing purposes? I’ve got 4 of em that all came together.
Rufusbduck
The efest 10440’s I bought only pushed 2.4 A direct drive through an xre. I don’t think they can supply 3A each which is about 8C. An AW AAA might.
Scott
Old-Lumens
Rufusbduck wrote:
The efest 10440's I bought only pushed 2.4 A direct drive through an xre. I don't think they can supply 3A each which is about 8C. An AW AAA might.
Well, hell. I just bought 4 of them and the Nitecore I2 charger. Guess they will have to do for now.
Nope, I don't plan on keeping them. I will sell them after the testing and beam shots. I can't check amps, so what I get, is what I get.
Probably Wednesday of next week when the stuff comes in.
Old-Lumens
Ok, Glamour Shots in Post #1.
Beam shots next week when the batteries come in.
Thanks everyone for watching this thread. It's been an interesting light to make.
DB Custom
DB Custom's picture
Hey Justin, Rbd was talking about 10440’s, not the 14500’s you ordered.
The 10440 is fully capable of pulling over 3A…they just don’t hold up for very long at all when pushed that hard as you might can imagine.
http://lygte-info.dk/review/batteries2012/Efest%20IMR10440%20V1%20350mAh%20(Black)%20UK.html
The 14500’s should give plenty of amperage to run this bad boy, don’t know if there’s anything else out there that will pull as hard as the small Efest cells. And I’ll buy those off of you Justin when you’re done testing.
Just let me know if you need a charger, I can send you one in a day most likely if you need it.
texaspyro
Welcome to the Lithium side of the Force, Old One.
MRsDNF
MRsDNF's picture
Yes its me again. Dont shoot me. Just a thought that may gain a little rigidity. On the tailcap end how hard would it be to peen the copper over so it wraps around the battery tube. I’m not sure if you’d gain much, just thinking out aloud.
Rufusbduck
Sorry, didn’t mean to confuse things, just wanted to prevent a delay from using an inadequate cell. I had read that 8-10C was near the limit for good imr’s and that efest cells were not as good as some others at very high current draws. They do seem very good for the price which is why I use them and my experience was that 3A was too much to ask from the efest 10440. Way better than protected TF 10440 but not as good as AW.
Scott
Rufusbduck
I can’t believe you said that. I hide my hammers when I’m modding lights. Lol. Good idea though as long as you don’t miss. Oops!
Scott
MRsDNF
MRsDNF's picture
I would trust Mr Lumens skill with a hammer any day. For the work off the devil or an angel. There is no other that has this special talent with hand tools. Smile Well there maybe, but OL is good.
Old-Lumens
Rufusbduck wrote:
Sorry, didn't mean to confuse things, just wanted to prevent a delay from using an inadequate cell. I had read that 8-10C was near the limit for good imr's and that efest cells were not as good as some others at very high current draws. They do seem very good for the price which is why I use them and my experience was that 3A was too much to ask from the efest 10440. Way better than protected TF 10440 but not as good as AW.
I see that the Efest claim 6C, but that's asking a lot. I don't expect to get the full amperage with them, but I would not fork over the bucks for AW cells. Maybe if I was a Li guy, but it hurt just to buy these.
If I had done the lights as 3AA they would get 3 amps off the Eneloops with no problems at all.
Old-Lumens
MRsDNF wrote:
Yes its me again. Dont shoot me. Just a thought that may gain a little rigidity. On the tailcap end how hard would it be to peen the copper over so it wraps around the battery tube. I'm not sure if you'd gain much, just thinking out aloud.
That's why I added the copper collars. Now the tubes are held in place. I've never shot a Moose and my days of that kind of thing are long gone. I might still bite your leg though, or at least growl a little.Wink
Rufusbduck
The 14500’s are 700 mAh so 6C for them is 4.2A, plenty. Always a trade off size vs capacity. I went to the 14650 size for that and for being the right size to fit my hand and grip.
Scott
nitro
nitro's picture
Last seen: 3 years 1 day ago
are u working on a handle design ?
TexasLumens
TexasLumens's picture
Now thats imagination and craftsmanship for real and at its best!!! Wink
Nice work Justin!!!    Dan.
Texas Lumens Website… http://www.texaslumens.com
WE LIVE IN THE LAND OF THE FREE ONLY BECAUSE OF THE BRAVE!
Old-Lumens
Nope. I think it's so light and so small it's like holding a King, so I don't plan on a handle for it.
