Orange AA host?
23 posts / 0 new
Mr. Nobody
Mr. Nobody's picture
Last seen: 1 day 33 min ago
Orange AA host?
Where can I get a Orange AA host and parts kit to build a light ?
Street-Light
Last seen: 9 months 4 weeks ago
You can bake just about any black body and it turns burnt orange. I did it with a propane torch a few years back. Don’t have it anymore, so no pix. There were several posts last year on baking the hosts to change the anodized color. Hope this helps.
Formerly known as “cscosx”
Mr. Nobody
Hmm, ok well I would like to build some light that uses 1 AA battery for my girlfriend. She doesn’t know much about batteries and I figure a AA light would be perfect the only thing is the host needs to be orange. So for now the focus can be on a AA host. I could buy the nitecore z1 but would rather use my mad skills and build her one Smile
saypat
saypat's picture
Last seen: 2 weeks 3 days ago
djozz
djozz's picture
Last seen: 41 min 43 sec ago
A baked flashlight can be made out of any black anodised flashlight of which the body parts can be singled out and baked in a very hot oven, or using a propane torch. The colour comes out in this range, so no bright orange:
Mr. Nobody
How hot and how long till it starts to change color on ha3 inside oven
cicciopanzarotto
cicciopanzarotto's picture
I’ve just “cooked” a Convoy C8 and a Convoy S2, timing and temperature are different for every torch, time depends mainly by the weight of the torch beacuse it have to became the same temperature, cook the flashlight assembled for a better thermal diffusione and for have better resoults.
However the S2 start toi change color after 3 minutes on the fire of the smallest cooker
Mr. Nobody
Does that change the color evenly? Or must it be cooked like a hot dog on grill, moving it in circle for best color look etc
cicciopanzarotto
Just leave on the dire, if you see different colours is for a bad heat diffusion
Mr. Nobody
grazie amico
pilotdog68
pilotdog68's picture
Last seen: 9 months 5 days ago
I’m interested to see what color the S2 turned out since it started Gray instead of black
Mr. Nobody
Look it turned tan
Mr. Nobody
Its even tanner now after 4 min. It’s not going orange tho….
cicciopanzarotto
Will post photo ASAP
Mr. Nobody
pilotdog68
wow, is that as white as it looks? Is that a solarforce tube? does it feel different?
Somebody should try it with a new Red S2+ to see what that does.
Mr. Nobody
Yea solarforce extension tube
Just did a cheap solarforce host
Gold!!!
keltex78
keltex78's picture
Older posts on the subject:
Orange DRY - http://budgetlightforum.com/node/7417
Dry Orange - http://budgetlightforum.com/node/7814
Baked Ultrafire - http://budgetlightforum.com/node/25265
I've done a few cheap hosts like this and got good results using the broiler setting on a toaster oven. Various shades of copper/bronze. I attempted this using a light blue anodized host (the S-R6 host Manafont sold) and it didn't change much. The color lightened slightly but that was all.
I've also used this technique to color-code the bezel ring on a 501b to differentiate between hosts.
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
cicciopanzarotto
from left “cooked” C8 body with black bezel, cooked bezel and black C8 and cooked S2
the S2 is a kind of very light gold
Mr. Nobody
Is that a gray s2? Still looks gray…
cicciopanzarotto
Yes, it is still gray but a very different one. Previously it seems to be a bit of purple insidie the gray bit now the purple turned gold. If I didn’t explain well just tell me Smile
Mr. Nobody
So I would like to find a AA Host to turn orange that I can Build off of…
Boaz
Boaz's picture
Last seen: 8 hours 36 min ago
You need to moderate how hot they get  if you want a specific color ..
 Seemed to me that the end of most baked lights ends up a brass color with thin cheaper lights ..thicker heavier lights turn out darker brown .
 i've been on a  cheap clip cooking craze .
 the S series convoy clips are fun too bake .they come out really nicely and can always be sanded back down and re-done
