【New】The Next Generation Of 18650 li-ion Rechargeable Battery?
47 posts / 0 new
Lumintop
Lumintop's picture
Last seen: 5 days 13 min ago
Tell Me What’s your imagination of the next generation of 18650 battery? Big Smile
LUMINTOP Next Generation LM34 18650 li-ion additionally add a new function – micro-USB charging input port, it can be charged only by one USB cable anytime and anywhere when you have USB power device.
No need charger – LUMINTOP LM34C Micro-USB 18650 li-on battery – The subversion of charge mode
LUMINTOP – Reliable! Playable!
Edited by: Lumintop on 08/23/2016 - 03:54
Lumintop
Lumintop's picture
The Miller
The Miller's picture
Just did a little review on similar cells from Brinyte
HKJ has done a analysis of the Mecarmy version.
Like the idea!
Lumintop
Lumintop's picture
The Miller wrote:
Just did a little review on similar cells from Brinyte HKJ has done a analysis of the Mecarmy version. Like the idea!
Really? Already on the forum?
The Miller
Yes my Brinyte review
http://budgetlightforum.com/node/48699
In it a link to HKJs review
Can you comment on the possibility to use both a normal charger and tgr build in charger at the same time I experimented with?
What are your and your engineers opinions on that?
Flashy Mike
Flashy Mike's picture
Last seen: 2 weeks 3 hours ago
Sure that it’s not a 18_7_50 cell?
Lumintop
Lumintop's picture
Haha Big Smile , Actually it is only 1.9mm long than the common 18650 battery with protected circuit board~ It is Ok to suit most of 18650 flashlight~
The Miller
Heheh more a 19700 or 18700
But the protected 3400 Panasonic cells and many other longer and sightly thicker protected cells are called 18650 while indeed 18700 or 19700 would be a better name.
Lumintop
Lumintop's picture
The Miller wrote:
Heheh more a 19700 or 18700 But the protected 3400 Panasonic cells and many other longer and sightly thicker protected cells are called 18650 while indeed 18700 or 19700 would be a better name.
18650 only suit for the original cell ? Facepalm
The Miller
Nah
18 mm diameter
65 length
0 shape
The Panasonic protected cells and many others are longer and a tad thicker
But the general consensus seems to be anything from
18 – 19 mm diameter
65 – 71 mm length
Round cells
Are named 18650 since people would probably get confused and well I really like being able to explain to people “Tesla uses these 18650 cells, they pack quite the punch” since people get it then. And I like doing this even while holding a protected cell Wink so just stick with it lol
Flashy Mike
Since there is no standard for “common 18650 battery with protected circuit board” – could you tell us the exact total length of your cell?
Lumintop
Lumintop's picture
The total length is 70.7mm ~
Pls check details here:http://www.lumintop.com/lm34c-usb-rechargeable-18650-li-ion-battery.html
koyotee
koyotee's picture
Last seen: 9 hours 44 min ago
And how much does the charging circuit add to the price? I doubt this is the next generation of liions….
Finaly, proud owner of a Powerex Maha mh c-9000 for my Eneloops:)
tech
Last seen: 1 year 4 months ago
I like the idea – they charge at the regular USB current? what if they get connected to USB 3? Can they go up to 900mAh or even 1.5A?
Milan
Last seen: 6 days 19 hours ago
I don’t really see the point.
When you have the battery out, isn’t it easier to just put it in the charger, than fiddle with these tiny usb connectors that are not made to withstand hundreds of plugs/unplugs anyway?
No indication of charge and extra long battery that won’t fit anywhere as a “bonus”.
Useless gadget.
tech
it might be useful for travel purposes, when the light you are traveling with doesn’t have a charging port and you don’t want to carry an additional charger or power supply unit.
The Miller
The big plus (for me that is, ignorng Brinyte stating it should not be done) is the fact that I can charge them with 1000mA (a normal charger) AND 750mA (the build in charger) to have a total of 1750mA thus much faster charging.
Another really big plus is the fct that I do not need a charger in the car. I have a little car adapter for charging of phones and tablets and an inverter to charge notebooks and that too has a USB out.
These can be used with the USB cable already in the car, so as a matter of fact the Brinyte cells hav given me more spac in the glove compartment Thumbs Up
koyotee
koyotee's picture
But, when you wanna charge 4 batteries, you need 4 cables and someting with 4 usb ports, not very likely to be had by most users.
Speed4goal
Last seen: 2 years 2 weeks ago
You would just use w regular charger of you had for to charge. You can use external and internal charging with them
2/9 Fox Co (2009-2015) Semper Fi 0311/0331 Rifleman/Machine Gunner
Blf has changed a lot since I've been here. Lots of snow flakes and easily offended over nothing. When the forum use to be great and people joked around and could take a joke. It's a forum it's not that serious. Let's make BLF great again!
koyotee
koyotee's picture
Still, not worth the price difference.
sidecross
sidecross's picture
Last seen: 5 years 5 months ago
We need standards.
A 18650 battery that is 70.7mm is or should not be labeled 18650.
“You must have a plan, if you don’t have a plan, you will become part of someone else’s plan.” Terence McKenna
The Miller
Well people like higher numbers
So a flashlight labelled 18650/18700 capable and a cell labelled 18700 could seem better then that 18650 cell Big Smile
I fear it would be more confusing for the general public but I think that the first who offers 18700 flashlights and cells could also sell more just because it had higher numbers on it.
But who would take the gamble?
HKJ
HKJ's picture
Last seen: 1 week 4 days ago
The Miller wrote:
18 mm diameter 65 length 0 shape
No, no, no:
10mm diameter
650 1/10mm in length
IC*R*18650, IM*R*18650, IN*R*18650 : The R means round
PS: Why do I have the line with Bold, Italic, etc. when it do not work!
The Miller
Ah OK
(The _ & * do not like numbers)
sidecross
sidecross's picture
So a flashlight labelled 18650/18700 capable and a cell labelled 18700 could seem better then that 19650 cell Big Smile
I understand your comment and reasoning, but it assumes the buyer or consumer is not smart enough to comprehend the dynamics of the batteries being used.
If the amount of profit made by selling ‘protected batteries’ to an unsophisticated public is a guide, then who knows what other great ‘new’ batteries will be released.
The ‘lowest common denominator’ is not a principal I would like to see in innovative flashlight or battery design.
sidecross
sidecross's picture
HKJ wrote:
No, no, no:
10mm diameter
+1
sidecross
sidecross's picture
The main reason I favor single cell flashlights is the ease of carrying a spare battery to change in the field if needed.
In this case a battery with a built in terminal for charging would also need a power-bank or charger; I would not find this a convenience.
SawMaster
Last seen: 3 years 1 month ago
The numbering is intentionally ‘nominal’ to allow for slight variations from different manufacturers, but IMHO a 5mm or more difference isn’t nominal and should be noted through use of a different number. Had they started with different more true descriptions (which they should have done) it would work, but now it would just confuse the average person even more. At least we’re smart enough to check for the length before buying Wink
Phil
quetzalcoatl
quetzalcoatl's picture
I don’t need it either. A spare battery does the job for me! Steve
will34
will34's picture
Last seen: 9 hours 10 min ago
This could be useful for a trip when you don’t want to carry additional chargers, just the light and one battery. However it uses a panasonic NCR-B which is not good for high powered flashlights.
EyeballFryer
I like the concept of having the micro USB built into the battery. It adds portable micro USB rechargeability to flashlights that don’t have a built in micro USB port.
My main concern is length – 70.7 mm is a bit long for some flashlights. It’ll either really crunch down on the springs, or won’t fit at all.
I don’t really “need” micro USB rechargeability for my use cases, but I might pick up 1 or 2 of these just to try out.
