Lumintop GT Mini (Thower) Beam shots and more!
151 posts / 0 new
JasonWW
JasonWW's picture
Last seen: 1 hour 27 min ago
sbslider wrote:
JasonWW wrote:
sbslider wrote:
How does the throw and such compare with a Thrunite TN4A? I know the TN4A is bigger/heavier, but I have it and wondering if the GT mini significantly out performs.
Which version, Xml2, xpl or xpl hi?
Xpl hi
In that case the difference is not going to be huge. It’s hard to find specs for it but I did find some for a neutral white version with the xpl hi. Peak Beam Intensity: 52,340cd.
Max beam distance: 457m. It’s got a 46mm head compared to the GT Mini’s 50mm.
So the Mini still beats it. Plus the mini has a few more hundred lumens. I measured around 1200, but others have measured around 1400. My guess is that it’s not going to be as big a difference as with my C8, but still pretty noticeable.
JasonWW
JasonWW's picture
toobadorz wrote:
JasonWW wrote:
UPDATE TO MANUAL
After trying mode 4 and mode 10 it appears that the groups are reversed.
Modes 1-6 use full turbo as 100% (5A)
Modes 7-12 use the top of the ramp as 100% (2.5A)
We definitely need an updated manual to reflect this.
Edit: And here it is.
GT Mini User Manaual
Thanks. And more to be corrected:
Quote:
…If [temperature] is selected for auto step-down, the GTmini goes to 100% output. Leave the GT to heat to the desired limit, and then click to set that temperature as the trip point (the GTmini is huge, so this can take 20 minutes or longer, use fresh cells for this). Or click within 5 s to keep previous setting.
GTmini is not huge and it doesn’t take 20 mins to get hot. So this statement looks weird, probably caused by a simple replacement (GT to GTmini?)
Quote:
The strobes are deactivated by default.
Strobes are all enabled by default, at least on my GTmini.
Yeah, it also says it takes 16 seconds to enter the menu, but it only seems to take about 8 Seconds.
Another error is where it says it requires button top cells. Since the GT mini has a spring on the driver it will work fine with flat top as well.
I notice it says it’s using NarsilM v1.3 instead of v1.2. All previous reports showed it was using v1.2.
sbslider
sbslider's picture
Last seen: 1 week 3 days ago
Thanks for the comparison, I appreciate it.
PocketSammich wrote: I don’t need this, but I want it. Please sign me up.
sbslider
sbslider's picture
JasonWW wrote:
toobadorz wrote:
JasonWW wrote:
UPDATE TO MANUAL
Thanks for the clarification about the cells, that was a reason imo for looking elsewhere. Not a huge deal, but I prefer flat top cells in general, and think double springs are a plus also.
Tom E
Tom E's picture
Last seen: 36 min 36 sec ago
The Mini does use V1.3 by virtue of it blinking out 1.3. Not sure where it came from, guessing TA. Dunno, maybe I provided it wayyy back?
toobadorz
toobadorz's picture
Last seen: 17 hours 34 min ago
Nice catch! Wink
joechina
Tom
Texas Ace used a NarsilM 1.3 Beta
I think you did provide it.
Maybe to Dell?
Tom E
Tom E's picture
joechina wrote:
Tom Texas Ace used a NarsilM 1.3 Beta I think you did provide it. Maybe to Dell?
Ok, probably posted the v1.3 BETA for him to use on Nov 16th, then on Jan 28th posted a v1.3 with the "new" S42 support, but nothing seemed to come out of that, least not so far.
joechina
Tom E
you have a PM
Texas_Ace
Texas_Ace's picture
Last seen: 3 days 22 hours ago
Ok, these issues I think are explained by them using a different firmware revision then I planned on. The final firmware I sent them should be as the manual states but I sent then an earlier version that is closer to what it sounds like ya’ll are seeing. They were supposed to of used the latest version but it looks like it didn’t make it into production.
IIRC these are about the limit of the changes + some minor changes to the ramp / mode spacing between the revisions.
Texas_Ace
Texas_Ace's picture
Yes, it was from me, although it looks like they used the prototype firmware I made for testing it instead of the final firmware with the refined ramp / mode groups and other settings. Not a big deal but the things mentioned above are a little different.
mulletbay1
Last seen: 3 years 3 months ago
Hi, I hv a mod Acebeam l16, love it. How does the lumintop gt mini’s beam patter n throw compare?
d_t_a
Last seen: 1 day 17 hours ago
Would it be alright to ask, what are the differences between the "proposed" final firmware you intended, compared to what is actually installed on the GT Mini?
Sharing a video beamshot of the GT Mini neutral-white:
(building on the other side is about 160 meters or 400 feet away from the flashlight)
compare to an Astrolux C8 (XPL-Hi 3A NW, 1300 lumens)
Texas_Ace
Texas_Ace's picture
d_t_a wrote:
Would it be OK to ask, what are the differences between the “proposed” final firmware you intended, compared to what is actually installed on the GT Mini?
Basically what I said in the quote, I don’t remember all the changes but the biggest change was an improved ramp that was smoother, better mode groups and a few minor tweaks to some other settings that were really just from my drive for the best I can do.
A few of those changes were noted earlier, the menu timing was extended to 16 seconds instead of 8 seconds ect.
Overall most will not notice the difference, the base firmware I used was basically the GT firmware so it still works fine, it was just not optimized for this driver and light.
toobadorz
toobadorz's picture
Yeah. So far the most noticeable part is, when stepping down from FET to 7135 due to low battery, the light is actually becoming brighter. This is because the firmware avoids activating two channels at once, and when the battery voltage is low, the FET can be darker than the 7135, thus “stepping-down to a brighter level” can happen. This can certainly be fixed by tuning the voltage that triggers this.
Texas_Ace
Texas_Ace's picture
Yes, that is a possible issue with how it is setup now. A minor but notable issues.
This firmware was just meant for prototyping, it was never intended to be used in the final driver.
Niko
i have booth, gt is slighty longer but better lies in hand. emisar is more powerfull. booth are great
Newlumen
Newlumen's picture
Last seen: 1 year 8 months ago
[quote=Niko]i have booth, gt is slighty longer but better lies in hand. emisar is more powerfull. booth are great
you might be right about the d1s. I dont have a mini gt or calibrated lights for the tube.. i measured d1s cool white @ 1400 lumen using Sony vtc6…
mortuus
mortuus's picture
Last seen: 14 hours 34 min ago
emisar is not more powerful, i think the beam on gt mini is slightly sharper.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
Niko
i have booth light, have you too?
my emisar is more powerfull
JasonWW
JasonWW's picture
Niko wrote:
I have both light, have you too?
My emisar is more powerful
Why is it?
They are both FET drivers and the same emitter. Maybe one has a better battery? Have you checked their amp draw?
mortuus
mortuus's picture
well no but i want to believe so Smile
              つ ◕_◕ ༽つ
Newlumen
Newlumen's picture
I have a d1s.. the beam is tight and intense.. can’t say about mini gt yet.. hopefully it will be good.
d_t_a
Not an apples-to-apples comparison, but here I got some images of GT Mini CW vs GT Mini NW and also Emisar D1 V2-3A
GT Mini CW (left) vs GT Mini NW (right)
(building is about 125 meters or 400 feet distance)
The second pic has the D1S (3A) on the left and GT Mini (NW) on the right.
For some reason, the GT Mini (CW) looks a bit less bright or focused than the GT Mini NW or the D1S 3A. Maybe it's just the more neutral tints look better at night?
Distance according to Google maps: ~126 meters or ~400 feet (actual distance is a bit more, because that is ground-to-ground-distance, the actual is from a lower ground level pointing several stories upwards to the opposite building at a slight angle)
Texas_Ace
Texas_Ace's picture
This is what should happen actually, given equal outputs the neutral white will throw better. The warmer wavelengths are less prone to refraction in the atmosphere and thus travel further.
Agro
Agro's picture
Last seen: 1 min 35 sec ago
I think someone tested it at long distance with GT and the test result did not match that theory….
I guess we need more data to draw conclusions.
Texas_Ace
Texas_Ace's picture
Agro wrote:
I think someone tested it at long distance with GT and the test result did not match that theory…. I guess we need more data to draw conclusions.
That was because the CW LED was a higher bin and thus had more lumens then the NW LED.
Naturally higher output will throw further.
If they are the same output the warmer tint throws further. The same reason sunsets are orange and the sky is blue.
mortuus
mortuus's picture
so warmer tint regardless how warm it is will always go further then cw light? wow i didnt know that..
              つ ◕_◕ ༽つ
Texas_Ace
Texas_Ace's picture
If everything else is equal, yes, warmer wavelengths of light travel further.
This is the same reason NASA wanted a 2700k warm white LED in the GT they got.
komeko
komeko's picture
Today I picked up my GTMini.
Charged to full 30Q and such results:
5.8A on the back of the cap
23 micro Amper drainage (backlight off)
1392 lumen
118kcd
color in turbo 4430K BBL 4D (almost identically as UT02)
Now I have virtually identical performance as my modified UT02 with 1510 lumens. The same range, color, beam … only in a smaller and lighter package. In conclusion, a very nice flashlight.
Click on:        ANSI WHITE
Click on:        MY COLLECTION
Click on:        Q8, D4, D4S, D18, K1, FW3A, SDmini, Mini AAA, TIP, M43, H1, H03, TC20, TN40S, TN42, V6, H600Fw, SC600w, SC64w
