MRsDNF's 2018 Old Lumens comp build. Finished.
62 posts / 0 new
MRsDNF
MRsDNF's picture
Due to time constraints and a busy schedule this years torch build will be short and sweet.
Basically it will be a triple, not sure on leds yet, possible de domed XPG 2 leds or XPL HI, BLF A6 driver, 18350 battery and a Convoy S2+ metal switch.
The components from the S2+ switch along with a new threaded adaptor. The spring on the switch will be replaced by a Blue spring. I love utilising items created by other users on this forum into builds or mods.
The tailcap. This has three threads rather than the normal two threads. The third thread being the smallest here is for the S2+ switch to screw into.
This picture shows the switch assembled into the tailcap. If you haven’t guessed l love these metal capped switches.
The switch retainer is recessed on one side to centralise the switch board into the tailcap. This threaded collar is held in the chuck in a split bush to allow the recess to be machined.
After awhile lots of split bushes are collected. Its usual to not have one in the size you need.
And the switch sitting in its new home.
Threaded mandrels are also made up to hold the torch components, battery tube, head and tailcap, in the lathe chuck so they are not damaged by the jaws and also if the item is tapered on the outside still allows it to be securely held.
Update 14.11.18.
We start of today with the pill and driver retainer. The diameter is turned to size, The grooves cut are for the lead in and out of the thread. The small section is the the driver retainer. the pill itself has an overall length of 10mm.
The driver retainer has already been parted off here. The machined recess is for the MCPCB to sit in.
The tool here is called a centre drill. This is used to drill a taper in the end of the work piece so when a hole is drilled it starts on centre. A hole is then drilled for the wiring to go through.
The pill was then parted off and placed in a split bush so the driver pocket could be machined.
The battery tube outside dimensions were then turned to size. The grooves are for the threading tool to run into.
The threads were then cut for the head and tailcap to screw onto.
Update 18.11.18.
Today was a good day and a bad day.
I was not sure on a pattern for the light so played around with a design on a test piece.
The head and tailcap had 12 flats machined on the largest diameter. These flats were machined .3mm deep. This is the head here.
I had not realised I hadn’t taken any pictures of the head while I was machining the grooves. Possibly because on the angle’s first cut I wound the work piece the wrong way, winding the head into the tool instead of away from it making the groove a lot deeper than planned. Not having time to make a new head I decided to work with what I had. When it came time to machine the grooves opposite the first lot I could not remember the measurement I took as a reference point so took a guess. I’d say the second lot of grooves are about 2mm lower than the first set of grooves. Facepalm
Anyway here is the tailcap after it had been finished being machined.
And finally a couple of pictures showing a couple of tools used on testing and reflowing.
Firstly is the reflow setup. I have been using this set up for a few years now.
And secondly the battery setup used for testing reflows. It consists of a AA battery holder with a AA LiPo battery with a couple of home made prongs that are placed on the + and – on the MCPCB.
Edited by: MRsDNF on 11/20/2018 - 04:13
MRsDNF
MRsDNF's picture
Time for the bling shots.
Firstly the assembled pill and switch ass. The switch is the standard convoy assembly except for the small bluey spring. The Mountain Electronics A6 DD driver also has a small bluey spring attached.
The leds are all XPG2 S42B dedomed.
The battery tube.
Tailcap.
Head.
And finally all the components in the torch. Assembly and lots of fingerprints has not happened at this point in time.
Update and finish 20.11.18.
With the light assembled and up and running it was time to take some fingerprint pictures.
This is always a good sign.
Thanks all for the kind comments and inspiration.
One last picture.
An Old Lumens Comp torch with an Old Lumens tribute torch.
everydaysurvivalgear
everydaysurvivalgear's picture
Last seen: 55 min 3 sec ago
Hey mate HTML should work. I think the side button are animated cause its asking me to run flash.
Working perfect Big Smile
MRsDNF
MRsDNF's picture
I haven’t used Photostuffit for along time and decided to give it ago. This is a paid account but alas no good.
Flashy Mike
Flashy Mike's picture
Last seen: 17 hours 40 min ago
Looking forward to your build, good luck!
DavidEF
DavidEF's picture
Last seen: 8 months 3 weeks ago
I see pics! Looking good so far!
- The YKK Philosophy
nottawhackjob
Last seen: 7 months 2 weeks ago
Outstanding how ya did it. Nuthin like great pics to show it.
“In many things in order to truly understand the small picture you have to understand the big picture first.”
True Color Rendition (TCR)/Simplified Definition: “On a scale of 1 to 10, with 10 being the highest rating, a TCR will equate to what true colors you see in sunlight vs the same object’s colors you see when illuminated with a flashlight. The closer the two are, the higher the TCR rating will be.”
The TCR Reference Standard is the Walmart Ozark Trail OT 50L , Model No. 6103.
It has a TCR rating of ‘10’. $1.00 including batteries.
CRX
CRX's picture
Last seen: 8 months 2 days ago
Cool Thumbs Up
pinkpanda3310
pinkpanda3310's picture
Last seen: 2 weeks 3 days ago
Nice! I like metal switches Davie
FmC
FmC's picture
It’s great that you are doing a build this year Thumbs Up
Pictures are visible to me.
electricjelly
electricjelly's picture
That switch looks like it would survive a tank running over it. Love it.
Short and sweet is better than nothing. Glad to see you didn’t miss this years build.
gchart
gchart's picture
Last seen: 3 hours 26 min ago
Great to see more folks joining the fun. Welcome aboard MRsDNF!
Jerommel
Jerommel's picture
Last seen: 2 years 4 months ago
Good luck with the build !
MtnDon
MtnDon's picture
Last seen: 1 hour 26 min ago
Thumbs Up Love the switch.
A nice box full of split bushings.
nottawhackjob
If I had MrsDNF as a next door neighbor I’d buy him roses every week and set them on the box of lights I’d like him to work on. LOL
Hoop
Hoop's picture
Last seen: 6 hours 14 min ago
Nice work so far! Excited to see what this turns into.
djozz
djozz's picture
Last seen: 3 days 17 hours ago
Nice! It has been too long since the last Moose build! Thumbs Up
MRsDNF
MRsDNF's picture
Updated the first post 14.11.18.
All the components have been machined and now to work out what to make the outside look like.
CRX
CRX's picture
Progress looking good Thumbs Up
DavidEF
DavidEF's picture
What? No square threads? I bet the ano isn’t even HAIII Military Grade Hard Anodize. Facepalm
Nice machine work, though. Innocent
MascaratumB
MascaratumB's picture
Last seen: 16 min 17 sec ago
Looking good for sure! It must be a nice sensation to be able to build / machine your own light Cool
MRsDNF
MRsDNF's picture
I’ll leave the square threads to lostheplot. Blushing
Hoop
Hoop's picture
Triangular threads are soooo equilateral… Big Smile
FmC
FmC's picture
Good to see some more progress Thumbs Up
MRsDNF
MRsDNF's picture
Update in the first post. 18.11.18
pinkpanda3310
Cool! Awesome looking pattern. Shame you forgot the measurements.
MtnDon
MtnDon's picture
Good to see Thumbs Up
FmC
FmC's picture
Looks good – like the design Beer
MRsDNF
MRsDNF's picture
pinkpanda3310
Damn your machining skills are good, very neat.
FmC
FmC's picture
Looks great all polished up Thumbs Up
Have you tested out the triple LED’s? It looks as though the one in the top right has a busted bond wire…
