✌ FREEME- ASTROLUX MF01 Mini 7*SST20 CRI95 26650 ANDÚRIL Flashlight Group Buy - $45.99
1582 posts / 0 new
JordanZHP
ver_ivanz007 wrote:
And here is the view of the AUX LEDs. I increased the brightness of Blue and Purple to make it more prominent. There are 4 trimmer resistors one for each color (red, blue, green and purple).
!{width:50%}https://i.imgur.com/bN3e3yt.jpg!
Is it easy to figure out which trimmer resistor adjust each color? Do you just use a screwdriver?
ver_ivanz007
Last seen: 10 months 3 weeks ago
Yes, it is easy. I used a small flat head screw driver. First you enable the high settings for the AUX LED, then turn clockwise to increase the brightness.
  • My current lights: Astrolux MF01 - Astrolux S43 - Astrolux FT03 - Convoy L6 - Nitecore MH20 - Nitecore TIP - Nitecore TUP - Convoy M3 - Convoy C8+ - Astrolux C8 - Astrolux MF01 Mini - Full Copper - Acebeam K30GT SBT90.2 - Massdrop tool AAA Copper and Brass - Nitecore Tip2
ver_ivanz007
Here are some pictures with other items/flashlight so you can visualize the size.
Astrolux S43, MF01 Mini, Flipside Wallet, Leatherman Wave
Nitecore TUP, Convoy M3, Astrolux S43, MF01 Mini, Astrolux MF01, Convoy L6, Astrolux FT03
alkiax
Last seen: 11 months 2 weeks ago
I’m new so I’m curious what is the point of changing the aux leds. I don’t even know what they are supposed to do. Has anyone that received theirs taken any outdoor pictures?
ver_ivanz007
Aside from serving as an eye candy, they can serve as an indicator if you are in lock out mode or normal mode since you can set it differently. I have mine in blinking mode in normal mode and in low mode in lockout mode.
As for adjusting the brightness of individual AUX LEDs, out of the box, they seem too dim for me, so I adjusted it according to my preference.
alkiax
ok. That makes sense. For a second I was thinking they were being used to tune the temperature of the main light or something. Thanks
Wieselflinkpro
Wieselflinkpro's picture
Please note what Lexel wrote:
https://www.taschenlampen-forum.de/threads/astrolux-mf01-mini-mateminco-...
Translated with google:
Quote:
The Aux LEDs can be made a lot brighter by trimmers, but somebody in China has messed up the values of my calculation table
End of song LED resistance 1kOhm poti 100kOhm, poti to 50kOhm as it comes out of the band
95% of the poti almost does not happen, then it gets incredibly fast bright up to 10mA alone in green
because the driver Bauer said that only this combination in low mode lights up all 3 colors instead of simply turning the green potentiometer a bit (to equalize the falling voltage across the combined series resistor of the 3 colors) and forwarding the pot position to the production
JasonWW
JasonWW's picture
Last seen: 7 hours 21 min ago
Everything is explained here.
Loneman
Loneman's picture
Last seen: 1 month 1 week ago
Mine has arrived and it's fantastic.  I double-clicked my D4S to turbo, shone it on the ceiling  then did the same with the Mini.  I was a little disappointed that the Mini looked to be the same brightness but guessed it was due to the wider hot-spot, then something told me to double-click again and BAM!  Even brighter!  I'm using Milicel P42a 21700's and Keeppower 5200mah 26650's in the C4s, btw.
I went with the 5000k tint, but to my eyes it has a green tinge when compared to the XPL-HI V2 3A 5000k's in my D4S, I'm sure that I'll get used to it in time.
Now, I'm off to fiddle with the Aux LED pots now, wish me luck. cool
SKV89
Last seen: 6 hours 26 min ago
I do not see those color options in that link.
Skylight wrote:
Mateminco is offering the last pieces of the Mateminco MT07 in purple, pink and orange. If you like these colors and can order on Taobao you should get them now as they are a limited edition / custom colors and Mateminco won’t make any more once they are sold out.
The link is: https://item.taobao.com/item.htm?spm=a230r.1.14.4.b2a84f31VAn3Ji&id=6014...
Here is a picture of them, taken from the reviews on Taobao.
!{width:50%}[img]https://i.imgur.com/B0j4AfL.jpg[/img]!
Wieselflinkpro
No, thats the “Mini”-Thread.
Look at the markings on the board.
Low is red
high is green
D1 blue
D2 Pink
(as Lexel wrote: https://www.taschenlampen-forum.de/threads/astrolux-mf01-mini-mateminco-...)
Skylight
Skylight's picture
Last seen: 1 day 19 hours ago
Skylight wrote:
Mateminco is offering the last pieces of the Mateminco MT07 in purple, pink and orange. If you like these colors and can order on Taobao you should get them now as they are a limited edition / custom colors and Mateminco won’t make any more once they are sold out. The link is: https://item.taobao.com/item.htm?spm=a230r.1.14.4.b2a84f31VAn3Ji&id=6014...
They don’t write the colors but it’s the third option from below ‘custom colors note color’. You would need to contact them, ask what they still have and order with this option then. There are no pictures from the seller just customer reviews.
Tubercle
Last seen: 1 day 11 hours ago
So, is it brighter than the d4s for those that have both? Based on the video I posted earlier, it wasn’t.
SKV89
Oh I see. Thanks for the tips. I’ll see how much I like the light when I receive mine. If it is good, I might by one of those special colors. I really like my purple MF01S. I might buy a purple or pink MT07 for my daughter if the quality is good like the MF01s.
Loneman
Loneman's picture
I've just seen this by ToyKeeper "Since this light uses SST-20 emitters, the tint varies from green-ish to pink-ish as the power level changes. Lower levels are more green, higher levels are more pink."  So that explains the green tinge I'm seeing which goes as I up the powah.
I've tweaked the pots on the Aux LED's. excuse the crappy phone shots:
Before:
After:
Tubercle wrote:
So, is it brighter than the d4s for those that have both? Based on the video I posted earlier, it wasn't.
I'd say so, yes.
JasonWW
JasonWW's picture
Low is red
high is green
D1 blue
D2 Pink
No, it’s the MF01S thread. It explains how the voltage levels turn on and off as well as what trimmer goes to what led (same as on the mini version).
JasonWW
JasonWW's picture
Loneman wrote:
Mine has arrived and it’s fantastic.  I double-clicked my D4S to turbo, shone it on the ceiling  then did the same with the Mini.  I was a little disappointed that the Mini looked to be the same brightness but guessed it was due to the wider hot-spot, then something told me to double-click again and BAM!  Even brighter!  I’m using Milicel P42a 21700’s and Keeppower 5200mah 26650’s in the D4S, btw.
Molicel P42A is a high drain cell, KP 5200 is a low drain. Very different cells. You need to use the same battery for comparisons.
ver_ivanz007
And here are the other colors. Just arrived today. Gun Gray and Sand Color…
riffraff
riffraff's picture
Very pretty. Thumbs Up Waiting for my sand-colored one. Facepalm
Loneman
Loneman's picture
JasonWW wrote:
Loneman wrote:
Mine has arrived and it's fantastic.  I double-clicked my D4S to turbo, shone it on the ceiling  then did the same with the Mini.  I was a little disappointed that the Mini looked to be the same brightness but guessed it was due to the wider hot-spot, then something told me to double-click again and BAM!  Even brighter!  I'm using Milicel P42a 21700's and Keeppower 5200mah 26650's in the D4S, btw.
I know, it's apples to oranges, that's why I stated which batteries I was using, my point was the fact that the Mini requires two double-clicks from off to hit turbo, the D4S doesn't (and doesn't take a 21700) and I wasn't aware of that fact.
JasonWW
JasonWW's picture
Loneman wrote:
I know, it’s apples to oranges, that’s why I stated which batteries I was using, my point was the fact that the Mini requires two double-clicks from off to hit turbo, the D4S doesn’t (and doesn’t take a 21700) and I wasn’t aware of that fact.
Yeah, the mini uses Anduril. From off, a double click goes to top of the ramp and then you do another double click to get Turbo. If the light is on, a double click will go to Turbo. This is one of the small quirks that I don’t like.
The D4S uses RampingIOS. I don’t think it makes a difference whether the light is on or off, a double click will always go to the highest output.
BurningPlayd0h
BurningPlayd0h's picture
Last seen: 2 weeks 2 days ago
I can’t believe this is still still listed as a “con” for Anduril lights, just set your “ramp ceiling” to 1 click and you have full turbo from on or off with a single double click.
JasonWW
JasonWW's picture
I can only say this is my opinion. I don’t know about anybody else. I also prefer instant on and off and a triple click always being battery check. What can I say, I’m more of a narsil kind of guy.
brenden23
Last seen: 1 year 8 months ago
Can you send me code for Olive Green please.
freeme
freeme's picture
Last seen: 18 min 31 sec ago
Sent.
1thedeals.comyoutubeAstroluxNealsgadgetsolight
mortuus
mortuus's picture
Last seen: 6 hours 35 min ago
can i also get a code please.
...where Frugal meets with Flashlight!
              つ ◕_◕ ༽つ
freeme
freeme's picture
Your request in is the second part of the PM.
d_t_a
Last seen: 6 days 12 hours ago
Dr.Phillip wrote:
ver_ivanz007 wrote:
I already received my Olive Green MF01 Mini 6500K. I really love the light and Anduril firmware. I will post pictures as soon as I can.
Do you own a BLF Q8 or any other well recognizable flashlight? Could do a side by side photo comparison?
MF01-Mini (7x SST20 6500k cool-white) vs Sofirn Q8 (4x XPL-Hi cool-white)
(flashlight distance to wall is approximately 18 meters or 60 feet)
(left = MF01 Mini ; right = Sofirn Q8)
d_t_a
Nice!
Are you able to take power consumption (current) measurements for the aux-LED? I’m wondering how high the “parasitic drain” of the aux-LEDs would be when at max brightness.
giorgoskok
giorgoskok's picture
Last seen: 9 months 2 weeks ago
Interested , thanks !
