[MOD] RRT01 (slo-mo progression)
88 posts / 0 new
clemence
clemence's picture
Last seen: 1 year 3 weeks ago
Jetbeam RRT01 is one nice flashlight with very intuitive UI. The concept is great, the look is OK (most, including me prefer older styling), butt…as there’s always reasons for BLF people to mod anything. For RRT01 it’s a big BUTT:
Dangerous no LVP, thermal limiter nor output step down.
Melted wrapper, tripped internal protection, bulged bottom
Hole drilled to relieve the safety switch. Usable but no protection anymore. I resealed the hole with two components potting silicone.
Stock pill machining is bad, very loose rattling tolerance (for the rotary ring). Uneven, eccentric milling, too many unused holes (recycled leftover surplus pill for various MCPCB model). I over saturated the picture to show the machining marks better.
In my opinion, this one is the worst from engineering POV practice. To accommodate new MCPCB screw hole location, Jetbeam drilled and tapped new pair halfway over existing holes. Facepalm
Stock copper MCPCB isn’t any better.
Definitely rough and not flat. This MCPCB was punched with dies instead of routed. Note how the rounded base edges eats up the precious mating surface area. A solder blob made things worse preventing flat contact between the pill and the MCPCB. Mind the low quality phone picture
Recycled MCPCB designed for Eye10 dated back to 2012 February 11th. The time when Sunwayman V11R was a big hit.
For me, stock RRT01 is potentially dangerous and definitely has to be modified to keep up with current flashlight standards. It has lots of potential and also lots of works.
I know I’m very slow but at least, this is what I made so far…
Pic taken fresh from the machine, there are still flares and chips
all three in the left are modified brass and copper version. Note extra O-ring groove for a complete waterproofnes. Also tighter shaft to rotary knob clearance for smooth rotation
Left: modified, Right: stock OEM
UPDATE 190724: Aluminum pill progress
http://budgetlightforum.com/comment/1533522#comment-1533522
Optic update and beamshots:
http://budgetlightforum.com/comment/1544168#comment-1544168
http://budgetlightforum.com/comment/1544657#comment-1544657
[Clemence]
Edited by: clemence on 09/20/2019 - 04:16
rahdi
Last seen: 4 days 7 hours ago
Great works Clemence
contactcr
Last seen: 1 day 12 hours ago
So any preview of what we can expect to fit in this custom pill? Smile
clemence
clemence's picture
Any MCPCB/PCB with 13mm diameter. Mine will use quadtrix E17A
[Clemence]
acab
acab's picture
those look nice.
djozz
djozz's picture
Last seen: 2 hours 32 min ago
That is a lot of effort! I hope that many people want one with your modifications. At least I like my (stock, with swapped led) RRT-01 very much Smile
contactcr
[Clemence]
With reflector or TIR?
Scallywag
Scallywag's picture
Last seen: 7 hours 19 min ago
That's no simple mod you're doing. Impressive.
As for my RRT-01, I just plan to LED swap it. I like the rest of it well enough stock. I was sorely tempted by another thread's listing of 18650 tubes that LEGO with it, but I think the head is large enough that I wouldn't want to carry it at with the added length.
Geuzzz
Geuzzz's picture
Last seen: 1 hour 17 min ago
Nice. My rrt is waiting.
clemence
clemence's picture
As usual, I love TIR optics and already prepared several choices. I don’t want to use stock pill, it’s a failed recycled design. Note those multiple holes made for several Jetbeam models. The driver also another recycled component from Niteye TCR1, with higher output.
EDIT: the funniest failure was how Jetbeam made thread offset from the original holes. And unused big hole in the center completely covered by the MCPCB. The latter is actually a good thing if there’s a triple 13mm MCPCB available
I’m very disappointed to see how the stock rotary dial is not even dustproof. It has one O-ring on top but nothing at the bottom. With the thick sticky grease behind it and excessively large clearance, a dunk on a sandy beach will ruin it. I prefer lower sensible output like the older design.
[Clemence]
g_damian
g_damian's picture
Last seen: 4 hours 53 min ago
Will moded rrts be available to order? Love
clemence
clemence's picture
This is why I couldn’t resist to make a new pill
Yes, but very very later I guess
[Clemence]
Gunga
Gunga's picture
Last seen: 3 hours 6 min ago
Looking forward to seeing your mod!
Tixx
Last seen: 8 months 1 week ago
This would be a nice upgrade for my RRT-01s. I would love a few if they become available in copper
CRX
CRX's picture
Nice Thumbs Up
SKV89
Last seen: 7 hours 12 min ago
I am so excited to see this! Clemence work is always top quality! Hope they will be in copper instead of brass…
moderator007
moderator007's picture
Last seen: 6 days 17 hours ago
Nice work Clemence Thumbs Up .
I’ll take a copper pill with no wire holes drilled if you ever wanna sell one.
pinkpanda3310
pinkpanda3310's picture
Last seen: 12 hours 35 min ago
That’s a lot of work replicating those pills. Nice job Thumbs Up
xevious
xevious's picture
Last seen: 4 hours 46 min ago
Excellent work, Clemence! Thumbs Up Great to see all this, keeping the RRT-01 as relevant as can be. Smile
clemence
clemence's picture
Thanks for all those supportive comments above Smile
In my opinion, pure copper (I used 99,95% copper) is not the best material for RRT01 for below reasons:
- too soft, dent easily
- copper thread tend to be weaker than 2024 aluminum or any brass thread.
- hard to machine
- expensive
- too heavy for EDC. Stock brass pill weights 17,08gr, modified brass (high copper) 23,26gr, copper (99,95%) 23,92gr
- also, aesthetically non visible
For RRT01, modified pill made from 2024 aluminum weights approximately only 7,42gr. More than half stock pill with thicker LED base and more material overall. Although copper has roughly triple the thermal conductivity of stock brass pill, with aluminum its already doubled. What do you guys think?
[Clemence]
Geuzzz
Geuzzz's picture
I say go for alu. Maybe this light will be ok for edcing afterall with the weight reduction.
djozz
djozz's picture
I had already been thinking why Jetbeam chose brass for the pill. One reason could be that the pill is the guidance for the ball bearing, the metals on both sides of the ball, SS (the ring) and brass (the pill) are slippery and wear resistant, while aluminium (and copper) is non-slipping and wears easy.
The question is if this is relevant for a simple low-tolerance magnetic ring construction or would greased aluminium work just as well, even over time ?
For all other reasons, I fully vote for aluminium, the best flashlight material in the world.
SKV89
Personally, I don’t mind the weight because the light is so small anyways. I vote copper.
Geuzzz
Geuzzz's picture
You have a point with the wear Djozz, but soft copper is certainly not a good option than.
Maybe an alu pill and a brass ring for the ball slot.
Or maybe a more wear proof alu like 6082 or something.
Although I think it would take quite some time to wear out soft alu.
clemence
clemence's picture
Brass = the golden standard for metal machining. Any hard/easy to machine standards always compared to brass.
Brass has the best dry lubricity for metal to metal contact, superior galling resistant. Even against it own
Aluminum can be anodized or greased for better wear resistance. But seriously, a true 20xx aluminum is very strong. I don’t think all those manufacturers with “aerospace aluminum material” really use 20xx or 70xx aluminum. These aero grade aluminum can also heat treated for even better strength. I will check local supply for used 7068 scraps. IMO, 7068 Al is the ultimate flashlight material.
[Clemence]
shirnask
shirnask's picture
Last seen: 9 hours 9 min ago
/\ Thumbs Up
contactcr
I think Alu is fine
clemence
clemence's picture
I have a box full of damaged Vertex dirt bike cast racing pistons, they have very high silicone content (some as high as 20% for 2000 model). The Si content is so high they are brittle yet very hard, perfect for high revving low torque 2 strokes. Tried to cast them but unusable other than for their specific purpose. Tapping a thread on it was useless.
I heard Oveready use superior ultra strong aluminum billet alloy for their lights. It’s doesn’t really requires anodization.
[Clemence]
malkoff junkie
malkoff junkie's picture
Last seen: 2 days 21 min ago
ALU 7068 voted.
Malkoff !
Gunga
Gunga's picture
I say aluminum. The light is too head heavy. I have had other lights with ball bearing and magnetic ring in aluminum without issue.
I also well grease all my ring lights.
electricjelly
electricjelly's picture
Last seen: 1 week 5 days ago
I like copper mcpcb and aluminum pills. Uses the superior thermal properties of copper where its most important. Moves the heat quickly to the aluminum and keeps the flashlight nice and light.
