Convoy S2+ - thread is different now
50 posts / 0 new
LamontGrady
About a month ago I got a couple remote switches for S2+. They wouldn’t thread on any of my existing S2+
Simon said there was a bad batch with wrong threads and refunded.
Then I ordered three sst20 ×6 biscotti. I asked for short tubes instead of large tubes as I have a pile of extra large tubes, but short 18350 tubes (ideally uniquely colored so I can keep track of led/drivers) and a magnnet are what I usually use on these. He didn’t send the short tubes like he has in the past. So I try to put a short tube on one, and the threads don’t match! Head or tail!
When I asked about these new ones, he say
id, “I’m sorry, The thread is changed.” The new ones fit the remote switches that didn’t fit any of my other S2+.
So beware, evidently there is a change in the threads on some Convoy flashlights now, so not everything will fit everything else any more.
LamontGrady
Actually I went back to see exactly what he said about the remote switches. He did not say there was anything wrong with them, he said, “oh ,sorry ,it’s a new batch,the thread is different.
I didn’t realize this before shipping,
it’s my fault ,you can ask refund”
d_t_a
Last seen: 2 hours 53 min ago
I can confirm this on a new Convoy S2+ SST40 that I got – its head or tailcap won’t screw with my previous Convoy S2+ (XM-L2, XPL-Hi) body tubes.
Whereas the older Convoy S2+ battery tubes can ‘lego’ with each other, but not this new one.
I also got a Convoy remote switch for S2+ — it doesn’t screw properly on my previous Convoy S2+; I had not tried it on the “newer” S2+ SST40, but now that you mentioned it — I just tried it, and it’s as you mentioned — the S2+ remote switch screws properly on the newer Convoy S2+.
What I also noticed is that the pill installed inside a “new” S2+ body will not lego with the older S2+ head (the screw threads are different).
Nooner
Last seen: 12 hours 6 min ago
This is unfortunate news.
LamontGrady
Thanks for confirming! And that’s bad news – the very next thing I was going to do is move these sst20/biscotti into older heads to I can use the short tubes with them!
I asked for short tubes that match the new threads, I’ll report back when he replies. If someone else could ask too that would be great. He’s kind of brief in the amount of information he provides.
Yokiamy
Yokiamy's picture
Last seen: 34 min 48 sec ago
Thats sad, that was exactly Convoy’s strong point, everything LEGO’d with eachother unlike other chinese brands with varying material quality and different assemblies, threads and so on.
Hopefully Simon will get rid of that bad batch and go back to his old good quality and interchangeable parts.
@Simon Mao, are you listening?
treellama
Last seen: 10 hours 35 min ago
Uh oh first the proprietary drivers, now this.
Henk4U2
Henk4U2's picture
Last seen: 10 hours 17 min ago
Any idea this was done intentionally? Or was it accidental and now Simon is forced to fill up a hole with another hole (Dutch expression).
If the threads on the tube are wrong, you need a head, and a tailcap with the same (new) threads.
And because the pill screws into the head like the tube does, also a new pill with the same threads.
I remember something similar. Parts of the new BLF A6 were intended to lego with the BLF EE X6.
It was said that a first batch of a certain part was made with wrong dimensions, and the production of the other part were re-designed to fit that first batch.
You are a flashaholic if you are forced to come out of the closet, to make room for more flashlights.
power911
power911's picture
Last seen: 1 day 19 hours ago
Was it due to some machining that require a new tool or am I spewing nonsense?
I know how some knurling was different because they replaced a new wheel but then again I know nothing about aluminium machinery and how they make threads
“Have you forgotten about all those who called you a Bringer of Woe and hunted you like an animal?”
“Normal humans don’t go around killing people and burning towns!”
“Don’t worry. I’ll go with you! So you just follow me and no arguing, okay?”
Sari33
Last seen: 4 hours 34 min ago
Does Alu S2+ have now threads of current copper model?
Yokiamy
Yokiamy's picture
It depends on the batch, there were 2 copper batches where one was identical to aluminium and the other wasn’t
Henk4U2
Henk4U2's picture
I’ve bought the last piece of the first Cu batch. Threads are fully identical to the existing Alu ones.
Does NOT mean threads of the second Cu batch is identical to those of the “new” aluminum S2+.
BLF-L
BLF-L's picture
Last seen: 4 weeks 16 hours ago
I ordered two S2+ on 2020-08-09, nit arrived yet. One is with XPL HI 8*7135 Biscotti. The other is SST40.
It’ll be “interesting” to see the threads of both !
I assume the XPL HI has old threads and the SST40 has new threads?
So they won’t LEGO with each other? Sad
Or they both have new threads?
Then they certainly won’t LEGO with my old S2+ Sad Sick
btw, My old S2+ are from 2017 and 2018 .
Simon Mao
Simon Mao's picture
Last seen: 17 hours 25 min ago
I’m very sorry, because we need to use a standardized mold, all the threads have to be changed. The molds used before are all hand-polished.
Before that, I also realized that there would be many problems,
NeutralFan
NeutralFan's picture
Last seen: 5 hours 6 min ago
It’s great that Simon continues to take responsibility for any Convoy mishaps that come along! He’s an honest and reputable seller. Thumbs Up
I’d rather use my flashlight around the house than turn on the lights.
BLF-L
BLF-L's picture
Simon Mao wrote:
I’m very sorry, because we need to use a standardized mold, all the threads have to be changed. The molds used before are all hand-polished. Before that, I also realized that there would be many problems,
Thanks for the info Simon.
So basically this change of threads specification is due to new production/manufacturing process which is more efficient, and not caused by some random mistakes in the machining department?
If that’s the case here, then I’m personally OK with that, as long as each flashlight is fit properly and works well, and this change is as planned and designed, therefore it is consistent for current and future batches . More efficient production process is good.
Sari33
Please can you measure new thread size diameter and pass of body tube?
Simon Mao
Simon Mao's picture
Any buyer who has purchased 18350 tube and S2+ remote switch, and there is a mismatch, can ask me to apply for a refund.
Nooner
Simon. Do you still have old stock of original thread? What colours?
Simon Mao
Simon Mao's picture
red blue green S2+ ,old thread But they will be changed in the future.
Nooner
Thank you for answering.
So all other colours are the new thread.
Barkuti
Barkuti's picture
Last seen: 3 hours 12 min ago
LoL! And just half a day ago or so a friend of mine was asking me about a 18350 tube for some Convoy S2. Question
My guess is I'd need to take some careful inspection to them, I think his (2x?) S2s were built with hosts from FastTech long ago.
Standardization is a boon, let me say.
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
Chatika vas Paus
Chatika vas Paus's picture
Last seen: 3 hours 21 sec ago
Let us know. OR make a note in the description.
Zerosvn
Zerosvn's picture
Dang. I was looking forward to putting my brass 18350 tube on the new s2+ with sst40 emitter. Time to order an old s2+ I guess.
Sari33
Would be nice if Copper S2+ and new Alu S2+ had the same threads.
Copper S2+ Head can match with S2+ body tube?
Simon Mao
Simon Mao's picture
The old thread is a trapezoidal thread, the new thread is a rectangular thread,
Simon Mao
Simon Mao's picture
The new copper S2+ uses rectangular threads,
it matches with S2+ body with new thread now
Nooner
Hi Simon.
Do you still have 18350 tubes in stock of the old style? I’d be looking to grab some before they are gone. Violet, desert tan, etc.
Sari33
These are threads of my copper S2+ Ordered on december 2019
Will match with new S2+ Alu parts?
I assume also that the Pills are the same too
mr_magoo
Last seen: 6 days 3 hours ago
Im really suprized to hear that these are cast. They look machined to me. In fact, it’s pretty much impossible to get a quality cnc machined type finish using a mold with aluminum.
pennzy
pennzy's picture
Last seen: 6 hours 11 min ago
Probably are machined. Translation thing.
