New Fireflies T1R Mini Thrower-- Release date 25th Jan
132 posts / 0 new
Jasetaylor
Jasetaylor's picture
I won’t be buying any more Fireflies flashlights if this is the standard to expect as below. I was looking forward to trying Fireflies products but sadly a very sour experience.
https://budgetlightforum.com/node/75242
Still waiting for any resolution with this, at the moment I’m facing selling it and taking a hit on the condition.
SKV89
Last seen: 1 week 1 hour ago
I bought over a dozen Fireflies light direct from the Fireflies website and never saw anything like that. Yours look like a used product. You need to inquire with the dealer where you bought it from.
Pip
Last seen: 7 hours 15 min ago
I’ll second that. My fireflies bought direct have been flawless. The marking around the lanyard hole is a giveaway that yours was at a customer before you. There is no reason that fireflies would try to put a keyring on it.
I think your resolution should be through Neal
MSQRD
Last seen: 2 weeks 4 days ago
Interested!
ArtieT59
ArtieT59's picture
Last seen: 4 hours 22 min ago
Im glad to hear both sides of the above issue, because although i’ve had no problems with Neal, I haven’t ordered form him in awhile (for unrelated reasons) and dont want to take the gamble, i know where Ill be buying my upcoming new FF from..
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
oeL
Last seen: 7 months 4 weeks ago
Sounds extremely interesting, especially the combination of the new CULNM1.TG LED, TIR optics, and a high efficient driver.
I’m still missing a combined buck/boost driver for flat regulation, but a buck/FET is already much better than a simple FET – especially because the Osrams are having a quite low Vf.
May I propose a voltage indicator feature using a RGB LED in the switch? Would allow to constantly read the voltage, while charging, while in use, and also while on standby (Andúril supports this).
MSQRD
I would probably get one depending on price.
Gerrit
Last seen: 17 hours 13 min ago
Interested!
Agro
Agro's picture
Last seen: 3 weeks 5 days ago
22430 is an interesting choice. I’ll be happy to see how does it work.
oeL
I can see the new lights appear in the shop one by one, highly appreciated!
Do you think the T1R will make it before New Year’s holidays?
darosk
darosk's picture
Last seen: 7 hours 1 min ago
Verily, I am interested
My Lights (Updated: June 20, 2021)
Gerrit
Interested, I would also like to see one with the green – KP CSLNM1.F1 – 3030 (1mm²) or the green KP CSLPM1.F1 – 3030 (2mm²)
Kona G
Last seen: 3 weeks 2 days ago
Appears FF has T9R on website. Is this for presales or available now?
CULPM1 6a cc buck no fet, prices approx $100 to $150 for SBT90
klrman
klrman's picture
Last seen: 2 hours 45 min ago
In this size, is there a protected battery available?  I would like a couple of these lights to send my friends for gifts.
Mark M
Mark M's picture
I have to say, I love the different battery tubes and tritium slots so very well done Fireflies! This model is a good size! Looking forward to it launching.
clientequator
clientequator's picture
Last seen: 1 month 1 week ago
This is very interesting flashlight. I thought it will use reflector, but it look like Fireflies has release new video of it:
https://www.facebook.com/groups/594119030988280/permalink/1255668698166640/
Do anyone know what optics is used? It look like some special TIR optics instead of reflector. Do you know how it compare to reflector? It look like there is aux RGB led under the optics which is probably the reason why alumium reflector is not used.
Tom E
Tom E's picture
Last seen: 5 hours 1 min ago
Specs in OP say: High efficient 3.6 Degree TRI Optics; Up to 138cd/LM
I assume typo: TRI should be TIR. Maybe it's like the E01 optic, but I see the E01 is spec'd at 6 degree TIR.
The head diam of this mini light is wider than the E01: 36 mm vs. 34 mm
atobe
Last seen: 3 hours 52 min ago
I NEED IT!!!!!
SKV89
I assume typo: TRI should be TIR. Maybe it’s like the E01 optic, but I see the E01 is spec’d at 6 degree TIR.
Are you referring to Acebeam E10, which uses the same optic as the Manker MC13? I don’t see an E01 thrower. Specs on the FF mini thrower is superior to that of the E10 and the light looks much smaller. I’ll see how it compares when I get it.
onehundredballs
Looks awesome i’m interested
Chicken Drumstick
Interested.
Has there been more info on price/availability? Seems there has been no updates.
Based on the info in the op.
1. This needs a deep carry pocket clip option
2. The switch needs to be suitably designed (recessed) to avoid accidental activation when in your pocket
Tom E
Tom E's picture
Are you referring to Acebeam E10, which uses the same optic as the Manker MC13? I don't see an E01 thrower. Specs on the FF mini thrower is superior to that of the E10 and the light looks much smaller. I'll see how it compares when I get it.
E01: https://www.ff-light.com/index.php?route=product/product&product_id=58, 34 mmm diam head
trakcon
trakcon's picture
Last seen: 3 hours 4 min ago
I’m VERY interested in this. Small TIR thrower with cc driver and aux LEDs? Yes, please!
SKV89
Oh yea I forgot about that light. This optic is going to be waaaayyyy better than the E01 optic. The E01 optic creates a lot of artifacts. The beam on this new light looks much cleaner and more focused.
Tom E
Tom E's picture
Interesting... I assume you are judging the beam from the posted vid? It does look pretty good compared to my E01. I flashed the E01 with Anduril2 smile
So between an improved optic and better throwy LED, should do wayy better than an E01 - I measured 32 kcd on the stock E01 on a 30T cell, which is probably close to blowing/blueing a SST-40.
SKV89
Yea judging from the video. The E01 was the only FF light that I didn’t like. This light however looks amazing
blueb8llz
Last seen: 2 hours 23 min ago
That’s quite large if this head is similiar to the ec01. I wish they made this light the same size as the nano gt but with the 16340 cell.
SKV89
We’re talking about the E01 not EC01
clientequator
I make fast comparison with T1R (left) and GT nano (right)
Led: same CULNM1TG
Lumens: 1000 vs 450
Candelas: 125000 vs 23400
Thorow: 700m vs 300m
Battery: 22430/18350 vs 10180
UI: Anduril 2 vs Narsil
Size: 79 × 37 × 26.5mm vs 24 × 52.5mm (head size much bigger)
Dirver: 6A buck vs 2.5A TA FET
Charging: 2A USBC vs (no detail but can charge)
Weight: 78g vs 17g
The gt nano is much smaller but T1R should last much longer and brighter.
Tom E
Tom E's picture
This light is much closer in size to the GT Micro. Micro is 36 mm head x 105 mm length.
