Wurkkos FC12: Why It Will Replace My Olight M2R Pro On Duty:
34 posts / 0 new
story
Last seen: 4 hours 12 min ago
Markus wrote:
Lightbringer wrote:
CollectEverything wrote:
Sooo….it is a gimmick? You said it was a hoot not that it was useful! Silly
Naw, it’s really handy. Normal creamy-white light, handy-dandy red to not get et by bugs when going outside, UV to make opossums fluoresce red.
It is hard to overstate how awesome the WK30 is: The primary light is creamy neutral white perfect for close-up and midrange. Floody, good color rendition. Perfect to explore stuff and take pics, make a movie. The UV (now 365NM!) and redlight are very powerful and with a good, floody beam each. All of that is powered from a 26650 cell giving long runtimes. All of it in a very compact and super robust package. And there is a red/white strobe for the child in each of us with the UI as perfect as it gets with a single electronic switch.
The WK30 has a slot in my EDC-backpack and it will go with me everywhere there might be something to discover. The best light for the money, more or less a true must-have.
I added a 2mm ZWB2 filter and it fits in the hole.
https://a.aliexpress.com/_mNYvsZY
story
Markus wrote:
Here is my 3D printed tactical ring for the FC 12:
The ring is designed so you first pull it into the clip and then move it over the battery tube. Screw on the tailcap. If someone would like the stl-file I can share it.
Hey can I have the file? Thanks.
story
Markus wrote:
UPDATE Here are a few pics showing how my FC12 looks like after many drops to the hard floor and more than a dozen shifts. It has run now for many hours, mostly on medium settings. I also had to use it as searchlight on runaway folks. The range of the light made a difference in the effort. 100% reliable and pleasant to work: It just works, a great tool. BTW: It greatly benefits from the tactical ring at least the way I use it. To my surprise the PLA (+) print does not even break Wink
!20210922-082326!
!20210922-082343!
!20210922-082353!
!20210922-082335!
Thank you. I printed one with your file and it’s solid.
