【Brass on Sale】Wurkkos TS10 "slender waist" 14500 triple LEDs Light with Anduril 2.0
1370 posts / 0 new
mattlward
mattlward's picture
Last seen: 1 day 29 min ago
gchart wrote:
BTW, I made a fresh compile today. You can find the hex file here. Highlights of the changes:
  • Uses Dynamic PWM for smoother bottom of the ramp (thanks SammysHP!)
  • Lower lows in Advanced UI
  • Slightly reduced ceiling for Simple UI
  • No blink at the top of the ramp
  • That should need it, maybe some other minor tweaks though
Well, downloaded and flashed new versions again on both lights. I was hoping that low power blink was in your option list for auxes, no luck. But, OMG the lows are really low now! Great work! Thanks a bunch.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
SammysHP
SammysHP's picture
Last seen: 6 hours 8 min ago
You can find it in my fork of Anduril: https://budgetlightforum.com/comment/1871607#comment-1871607
mattlward
mattlward's picture
SammysHP wrote:
It’s not perfect, but comes without the jumps.
Level 1 uses clock/4 and pulses at 611 Hz for reduced power consumption. All other levels are at 2.9 kHz or above (up to 19.6 kHz at level >64).
The first 25-30 levels are in the non-linear region, but seem to ramp quite OK. I also tried to go even lower and got about 0.001 lm or less, but I don’t think it would be reliable enough (temperature, battery voltage etc). Even with this configuration the ramp shape might change depending on the environment.
Anyway, here you go:
Configuration: https://gist.github.com/SammysHP/5acd7390cba7d252bd304d0cba1e1ea5
Hex: https://cloud.finf.uni-hannover.de/s/YDBbZak4P3oMs2i
The hex comes with some additional features:
  • Two more aux LED patterns: off / low / high / fancy blink / blink low / blink high
  • Aux LED low voltage protection
  • Smoother sunset timer
  • Allow turbo in momentary mode (go to turbo, then to momentary via 5C)
  • PocketUI: Shifts some button mappings from off to make lockout obsolete. Can be enabled via the misc options menu (from off 9H, then 1C to enable or nothing to disable).
Sammy, are all the traditional elements of Anduril 2 still in this version? Specifically the ramp speed adjustments? Nice button mode, but I have so many Anduril lights that I am not interested in learning a new interface. BTW, I am still using your Anduril 1 fork in all of my FW lights that allows for 5C while locked to set an autolock timer. Love it, thanks for all of your work.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
SammysHP
SammysHP's picture
Yes, all original features are present and unaffected.
Glad you like my autolock feature. It was included in Anduril 2 and presumably saved many pockets. Smile
mattlward
mattlward's picture
It has saved my pockets a few times, only have cooked on pair of Carhart jeans.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
carsknivesbeer
carsknivesbeer's picture
Last seen: 1 day 3 hours ago
gchart and SammysHP: the new hex is great. The low is close to the SP10Pro now and will work better than the high AUX.
Thanks for your work!
RichH
Last seen: 1 week 1 day ago
Thumbs Up
Worth me posting my thanks to Wurkkos for an instant full refund without the hassle of returning the faulty light. Good work Wurkkos.
South Saxon
mattlward
mattlward's picture
SammyHP, got your fork flashed on both of my TS10’s and love the low blink for lockout! Also the refactored low end ramp smoothness is awesome.
Thanks to both of you for your hard work on this firmware.
EDC rotation:
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
m47mu74nt
Last seen: 4 days 13 hours ago
I’d say “half good” : it is both very good and not much Sick
It has really cool things going for it, but the clip is awful, it scratched the surface of the flashlight at first try.
I would have loved a deep-carry : so I made kind of one using old Wenger chained o-ring and modified original clip, but it scratches the body even worse than stock clip.
Anduril 2 is quite fun, but its one more UI to remember… I’d prefer it if there were two channels
jon_slider
jon_slider's picture
Last seen: 34 min 45 sec ago
I also succeeded in reflashing a TS10.. Thanks to all
the lowest mode, in advanced, is now 0.02 instead of 0.2.. YAY
aux lights are off when main LEDs are On… YAY!!!
defaults:
94 lumens memory at turn on, in Simple Mode, floor 0.2 lumens, ceiling 804 lumens. Aux on Low when Off. Aux on High Blink when locked.
advanced mode 2H from off gives ceiling 367 lumens, 2H again gives turbo 955 Lumens, floor is 0.02 lumens.
fwiw, I increased thermal step down to 50C, the light now sustains 300 lumens. In stock thermal config, the light steps down to 88 lumens in less than 10 seconds.
Firelight2
Firelight2's picture
Last seen: 4 hours 21 min ago
Where do I get the hardware to reflash the TS10?
jon_slider
I got it from gchart: (ignore the green circles)
https://budgetlightforum.com/comment/1871229#comment-1871229
the TS10 has no pin holes in the pads, so you need to clamp the pins to the head something like this:
thats actually a pic of an SP10 Pro, it has holes in the flashing pads, and does not need to be clamped, but I did anyway
the programmer also works for the SC21 Pro, with a separate harness…
I did not have pogo pins, I soldered the wires to the flashing pads on the driver. The wire harness I used for the SC21 Pro, came from a separate purchase on aliex..
all this thanks to Adair21’s post,
https://budgetlightforum.com/comment/1861493#comment-1861493
plus lots of help from several kind people who coached me privately to install all the software and driver, on my iMac.
Zephon
Zephon's picture
Last seen: 11 hours 12 min ago
If I purchase a TS10 say today, I wonder if these changes would or can be requested to be flashed to my unit? Not sure how it works between you guys….
SammysHP
SammysHP's picture
Usually pogo pins are pointy enough to not slip away. You can hold it in place with one hand and use the other one to start flashing. Using a clamp makes it slower, but helps positioning if it is difficult for you to see the tiny pads or if you can’t hold still enough.
Jan910
Last seen: 4 hours 42 min ago
jon_slider wrote:
I got it from gchart: (ignore the green circles) https://budgetlightforum.com/comment/1871229#comment-1871229 !{width:80%}https://i.imgur.com/RERUD6y.jpg! !{width:80%}https://i.imgur.com/wr0dl7R.jpg! the TS10 has no pin holes in the pads, so you need to clamp the pins to the head something like this: !{width:80%}https://i.imgur.com/bi1Racw.jpg! thats actually a pic of an SP10 Pro, it has holes in the flashing pads, and does not need to be clamped, but I did anyway =========== the programmer also works for the SC21 Pro, with a separate harness... !{width:80%}https://i.imgur.com/ZOJzqFQ.jpg! I did not have pogo pins, I soldered the wires to the flashing pads on the driver. The wire harness I used for the SC21 Pro, came from a separate purchase on aliex.. !{width:80%}https://i.imgur.com/DhBNp76.jpg! . all this thanks to Adair21's post, https://budgetlightforum.com/comment/1861493#comment-1861493 plus lots of help from several kind people who coached me privately to install all the software and driver, on my iMac.
https://intl-outdoor.com/reflashing-kits.html.
Will this adapter work with ts10?
Wurkkos ts10 Black + silver 5800k
Wizard pro xp-l
Kd8.2 xhp50.2 2700k
Fw3a xpl hi 5000k
S2+ lh351d 5000k
S2+ x-pl 6500k
S2+ sst10 UV 365nm
S2+ xp-e2 620nm
Sofirn d25LR
Wurkkos ts21 219 Red
SammysHP
SammysHP's picture
No, that one will not work. This post explains what you will need: https://budgetlightforum.com/comment/1871229#comment-1871229
jon_slider
I want to thank all the people, named and unnamed, that have helped me learn how to reflash Anduril 2 onto my TS10, SP10 Pro, and SC21 pro, including but not limited to: gchart, SammysHP, Adair21, zumlin, and BruisedMonkey.
album w more flashing photos https://imgur.com/a/TGeVkk2
SammysHP wrote:
the lowest level can be really low. I mean, ZebraLight low.
I applaud you for bringing Lower Lows to my Anduril lights
my SC21 Pro, and TS10 now have lows of 0.02 lumens, 10x lower than before.
That change has Transformed my nightstand light options. Now I can use lights that were too bright, thanks to the Lower Lows you have created for us, and that gchart has incorporated into these Hex files that I used to reflash my SC21 Pro, SP10 Pro, and TS10.
hex file sources:
major thanks to the_gchart and SammysHP
TS10 https://www.ghart.com/blf/firmware/hex_files/sofirn_anduril2/anduril.202...
turns off aux lights when main leds are on, adds LVP to aux light circuit, AND makes the lowest mode 0.02 instead of 0.2 lumens
SP10 Pro https://www.ghart.com/blf/firmware/hex_files/sofirn_anduril2/anduril.202...
eliminates the blink at top of ramp.
SC21 Pro http://www.ghart.com/blf/firmware/hex_files/sofirn_anduril2/anduril.2022...
converts from Anduril 1 to Anduril 2, adds LVP to button lights, plus makes the lowest mode 0.02 instead of 0.2
Thank You All! Beer
SammysHP
SammysHP's picture
Thanks!
Oh, that’s not the “ZebraLight low”. It can go much lower, but I don’t know how reliable it would be.
jon_slider
It is 10x lower than before, Im very happy.
fwiw, the lowest low on a zebra SC64c LE specs is 0.05 Lm, and Im getting 0.02 Lm from the TS10 and SC21 Pro. The SP10 Pro is 0.01 Lm, on my meter..
Jan910
SammysHP wrote:
Jan910 wrote:
https://intl-outdoor.com/reflashing-kits.html Will this adapter work with ts10?
No, that one will not work. This post explains what you will need: https://budgetlightforum.com/comment/1871229#comment-1871229[/quote]
Thank you. i thought i would buy the complete adapter
Wizard pro xp-l
Kd8.2 xhp50.2 2700k
Fw3a xpl hi 5000k
S2+ lh351d 5000k
S2+ x-pl 6500k
S2+ sst10 UV 365nm
S2+ xp-e2 620nm
Sofirn d25LR
jon_slider
contact thefreeman
Jan910
jon_slider wrote:
contact thefreeman
I was writing. He has no time now.
Wizard pro xp-l
Kd8.2 xhp50.2 2700k
Fw3a xpl hi 5000k
S2+ lh351d 5000k
S2+ x-pl 6500k
S2+ sst10 UV 365nm
S2+ xp-e2 620nm
Sofirn d25LR
Champfc3000
Last seen: 4 min 6 sec ago
Anyone sell the complete adapter in u.s.
gchart
gchart's picture
Last seen: 9 hours 24 min ago
Yes, I have adapters. PM me, please.
Hopefully we can get a manufacturer for these soon.
fogofwar
fogofwar's picture
Last seen: 3 days 2 min ago
I’m quite late to the TS10 party as Wurkkos doesn’t sell it in China yet. I had to get it through some back channels Big Smile
I will test the TS10 Aux lights but the drain claimed in this thread seems too high.
I’ve tested my D4v2 with cyan Aux on high for 2 months and it drained my Samsung 30Q from 4.18V down to 3.81V so it would take 7 months to fully drain the battery. The drain actually tends to slow over time because the Aux lights lose some brightness as voltage drops.
By the way, I found the best way to use a USB ASP is with jumper cables. https://ja.m.wikipedia.org/wiki/%E3%83%95%E3%82%A1%E3%82%A4%E3%83%AB:A_f...
You don’t need to solder wires or use pogo pins. You can just electrical tape the end together to the right configuration and then put enough pressure to make contact with the electrical pads.
fogofwar
fogofwar's picture
Has anyone tested the max current the light can put out, especially with high drain 14500s? Testing current draw for tail E-switch lights is always tricky and I’ve given up on it.
I suspect the light can get up to 2000 lumens at turn on with high drain 14500s.
Wurkkos
Wurkkos's picture
Last seen: 2 days 18 hours ago
Copper flashlight, whether there are oxidation spots on the surface of the light, when received?
Brass not have this problem?
Wurkkos Terry
Wurkkos Terry's picture
Last seen: 2 days 15 hours ago
Hi Wurkkos fans and friends,
The third batch of TS10 are being emergency producing now( shipping within month end).
In order to fulfill the previous commitment and support the sales on other platforms.
Wurkkos office website will only retain 100 pieces in this batch, all of others will be sent to Amazon and Walmart.
According to the current shipping situation, these goods can reach the local warehouse about 7-14 days.
————————-The assignment result——————
Amazon US,
TS10-Black body-4000k-Red Aux 50 pieces
TS10-Black body-4000k-Ice blue Aux 100 pieces
TS10-Black body-6000k-Ice blue Aux 80 pieces
Amazon EU,
Walmart US,
Aliexpress, Lazada&Shopee
TS10-Black body-4000k-Red Aux 43 pieces
TS10-Black body-4000k-Ice blue Aux 109 pieces
TS10-Black body-6000k-Ice blue Aux 56 pieces
Gunga
Gunga's picture
Last seen: 52 min 39 sec ago
Need Canada!
Zephon
Zephon's picture
All of them are black body only — Any news on the other body colors?
