Black XIAOZHI CREE XM-L T6 LED 1x18650 Two Group mode Flashlight
I Got this a week ago from CN Quality goods and have been edc ing it.
like it very much. its not a high end but does welll. have droped it at work.been abused by workmates
and its going strong so far…
here a little review with some pictures…
CREE XM-L T6 LED nw (im starting to like the nw colour now)
Material: Aluminum Alloy
Reflector: Aluminum Alloy OP Reflector
Lumen: 800lumens
Current:2.3A
Mode:
Two group: Runing 5 seconds on Low mode, wait till the light will flashes once,then a quick half-press changes to second group 11 .
Group I:5>15>>100%
Group II: 5>15>>100%>>Strobe>>SOS
Battery Type:1*18650 (not include)
Switch: Tail cap reverse click switch
Size: 114mm(Length)*24mm(Tube diameter)
Waterproof: IPX7
Weight:75g(not include battery)
conclusion…
Not bad for $17 …
I dont have time for making readins and runtimes but…i did manage to to do a tail cap and it read 2.7 amps so this thing probably puts out the claimed light
the Op reflector is 10/10!!! uses the nanjg 17mm driver, so little bit noisy due to pwm but tightening the pill reduces somewhat…. so easily and cheaply replacable. was greased and has twin o rings
Reverse clicky not the best but works ok after some slight udustments
and yes it does heat up when run for longer on high !!! as would be expected from such a small body running a t6 at 2.8 amps :weary:
