Just got a Romisen/CREE model RC-R5, XP-G AA/14500. I see these are not held in particularly high regard, and there are certainly better pocket rockets, but it seems reasonably bright and generally OK if it were not for an occasionally finicky switch. Time will tell for a final verdict, though. At $12.80 shipped, I don't feel like a got scalped too badly.
I got a Keygos KE-5 and another KE-2 and the KE-2 is brighter. The Trustfire Z1 is not very bright at all and very disappointed for $31.00 and bummed about the KE-5 I've read so many good things about it.
I've read good & bad, so the first thing I will do is strip it down and look everything over for bad soldering or errors, before I ever power it up. I hope it's one of the ones they actually put together correctly from the chinese factory. I've never had a variable gun due to cost, but I will take a chance. Worst case I can always send it back.
Looks just like my Weller 100 soldering station except for the color. Mine ran me $50 for the original. If that one works as well then you got a bargain. Enjoy!
I'm sure you already know this, but make sure you stop all fans from moving before you blow air through them. I've destroyed quite a few fans that way - their bearings really don't like doing 100,000 rpm.
Got a charger I ordered for someone, some lube, a BLF lanyard and another T6 drop-in. I can't find that "what you did today" thread so I'll post what I did this evening:
Finally found my orbital from the move so, got caught up making some to replace the few that have found new homes and new flashlights to make pretty.
Hey Don thanks! This is why I set my regulator to 50 working lbs and hold the fan blades in place while cleaning them. One thing I forgot to mention I use dual water/oil filters to keep excessive moisture and residual oil from contaminating the parts. I've been repairing electrical equipment most of my adult life so I do have a bit of experience :)
