Got mine today - nice quality host, which I was expecting, nice size and weighted head. Popped in 2 KP 3100's charged, and got a 2.03A tailcap reading, 4.06A effective... nice! Results with the light meter/PVC lightbox:
lumens: 1,003 at start, 962 at 30 secs (962 OTF rated)
throw: 98 kcd (measured at 5m)
As a comparison, just re-did my Crelant 7G9 (thrower, 3 parallel cells, slightly smaller diameter head than the 2X) and measured 4.02A at the tail:
lumens: 1,468 at start, 1,472 at 30 secs (1,472 OTF rated)
throw: 107 kcd (measured at 5m)
Several differences here -
7G9 specifics: Nanjg at 4.9A, springs copper braided, XM-L2 U2 1C on a SinkPAD, stock AR lens
I'm speculating there's a good deal of loss of that 4.06A (effective) before getting to the LED in the 2X, as is typical. The Nanjg setup in the 7G9 is more efficient though probably because of overall resistance, I can't achieve the amps I wanted (4.9A) in the 7G9.
Overall, impressed and glad I ordered this. The simple 3 modes and quality of the host, plus high amps for a stock light is great attributes for this price.
Cons:
- holster is a bit under-sized - can barely get it closed
- lumens is under-performing, though my PVC lightbox is general a little low
Comparing the beam pattern with the 7G9, the 2X has a wider flood area and wider beam pattern. This isn't surprising because the 7G9 has a very deep reflector. You can clearly notice the 7G9 is brighter side by side though. I'm still not quite sure I can explain the low lumens though, but between the lack of a good copper star, lack of an AR lens, and probably only 3.3A to the LED, it might explain most of it. They did rate it at 1,300 lumens max, whatever max means..., so can't be sure they made this up or attempted to calculate it, or what.
