TK - Since I do not write code I myself would be at a loss to make this happen. That is why I want the end user to have the ability to change if they can or desire. Now...if any of the other three testers are up to it and it fits on a Tiny13 I do not mind (to avoid changing specs). The code would need to be furnished to EE for implementation. You write code don't you..at least for this purpose of firmware?
You’re saying that a reverse clicky, a mechanical switch, can be used like an e-switch for short or long presses? By delaying the off with the reverse switch mechanism? Finesse it, as it were? Interesting!
Edit: It was explained to me that the mechanical switch interrupts power while the e-switch only interrupts signal to the MCU. With an e-switch there is power on at all times (sleep modes power down but it’s still there and ready) So I am not getting how the power interrupt could act in the same way. Of course, there’s a lot I don’t understand. The female half of the Worlds population for starters.
Sort of, yes. It can sense approximately how long it was off, and react in different ways depending on that.
If you’d like to try it, grab ToyKeeper/cypreus/cypreus.* from my firmware repo. It uses a short press (< 0.5s) to go to the next mode, a medium press (0.5s to ~1.5s) to go to the previous mode, and a long press (> ~1.5s) to reset back to the first mode. If you go backward from the first mode, it’ll access some semi-hidden modes — turbo, strobe, and battcheck.
The first mode is moon, and it attempts to compensate for low cell voltage by ramping up the pulse frequency. Try it with a half-empty cell to see it work.
In any case, I’d like to know what you think about it.
Those numbers look promising! The light looks very nice in your video. The video makes it look much bigger than it is, I think this will be a nice little pocket rocket.
By the way, this A17DD-SO8 driver looks so freakin nice, I totally must have one of these, I guess living in Europe doesn’t make it easier…
When you try some low resistance mods later on, it would be very interesting if you had some copper beryllium springs to test also
I know it is not likely we will get EE to go that far, but if we know what it would give, we could know how hard to push for it if not on this then maybe next GB.
