freeme
(youtube.com/@1thedeals)
701
freeme
705
NEW KLARUS G20L XHP70.2 P2 3000lm Dual Switch Brightness USB Rechargeable LED Tactical Flashlight pre-order Starts / Proceed to Store
- CREE XHP70.2 P2 LED; 50,000 hours life.
- 4 lighting levels, 2 strobe modes.
- Battery: Li-ion 26650 Battery x 1 (Use only 26650 Li-ion batteries (included), Do not use 18650 /16340 / CR123A batteries).
- Working Voltage: 2.5V – 5.0V
- Dimension:(Head) 49mm (1.93") x (Body) 34.5mm (1.36") x (Length) 150mm(5.91").
- Weight:168g (5.93oz) (Without battery).
- Material:Aerospace Aluminum Alloy 6061-T6, Mil-Spec HAIII anodizing.
- Lens:Hardened Mineral Glass; AR coated; Scratch resistant.
- Reflector: Orange Peel.
- Body Color:Black.
- Switch: Side Switch + Tail Switch.
- Waterproof:IPX8 (underwater 2 meters).
- Accessories Included: 1 x Klarus Charging Cable, 1 x Klarus 26650 Battery, 1 x Spare O-Ring, 1 x Lanyard, 1 x Nylon Holster.
freeme
706
Fenix TK75 2018 Cree 4x XHP35 HI LED 4x 18650 5100lm USB Rechargeable Flashlight retail at $219.95 - PM for deal.
Features
- Cree XHP35 HI neutral white LED with lifespan of 50,000 hours
- Powered by 4*18650 rechargeable Li-ion batteries
- 152.5mm Length x 50.5mm Body diameter x 61mm Head diameter
- 431 grams (excluding batteries)
- Low and High separately controlled for powering on
- Momentary on SOS and Strobe
- Dual side switches for separate upward an downward output selection
- High efficient TIR optical focusing lens
- Fitted with 1/4’’ threaded interface (Standard tripod socket)
- Digitally regulated output maintain constant brightness
- Reverse polarity protection, to protect from improper battery insertion
- Intelligent overheat protection protects from high surface temperature
- Made of durable aircraft-grade aluminum
- Premium type III hard-anodized anti-abrasive finish
Itsme
(Itsme)
707
After the preorders are over, will there be a group buy code available?
Thanks
freeme
708
Who missed Skilhunt H03 at $24.11 deal?
freeme
710
For these countries: HK,US,CA,MY,TW,GB,IE,AU,NZ,IN,SG,ZA,MK,GR,NL,PL,HU,TR,SK,RO,CZ,HR,BG,SI,RS
Agro
(Agro)
711
A couple of hours ago I bought for 28.99….They are processing and I can’t cancel.
Well, happens.
Mindaugass
(Mindaugass)
712
The Code cannot be used for Orders to Lithuania.
freeme
714
It is not going to defer by much.
Itsme
(Itsme)
715
Already expired for Canada. Cost is 37.34 now. Too bad for me
freeme
716
It is back to flash sale $29.11.
hIKARInoob
(hIKARInoob)
718
Got two pieces of Nitecore NU05 for my back pack. Wonderful little lights! Thanks freeme! :+1:
