The FW1A reflector is actually a light orange peel, I have a FW1A with CULPM1 with the older style reflector.
Do you have a source for the older FW1A reflectors? I've wanted to get another FW1A with SST-20 or LH351D but the FW1A now uses the same reflector as the FW1A Pro.
Also have you by chance tried the TIR optics with SST-20 or other emitters besides the CULPM1?
Ok, time for some updates.
I have split the bottom piece of the double stacked mcpcb… Sorry guys i forgot to take a photo of that.
So there’s a channel for the wires now and the split mcpcb sits flat on the shelf with the led mcpcb right on top of if.
I also found the closest smooth reflector below.
Some mods needed on this reflector, need to shave about 0.5mm off the outside diameter.
This relector is 16.6mm height as opposed to original of 14mm.
So with the height savings I get by sitting the mcpcb flat on the shelf, there is still a 2mm gap.
You can see the photo of the reflector and the gap.
Still scratching my head on how to solve the gap but it’s fine for now.
Beam is more refined now with slightly more throw.
Got those TIRs in from AE. Sticking with my LEDIL for now. They need a small amount of filing/sanding of the flange diameter to fit in the bezel, but they fill the opening perfectly. Throw was 16kcd with a domed 4000k SST20 vs 20-21 with the LEDIL. Cleanest corona by far imo of all the clear spot optics I’ve tested. There was an odd non-uniform shadow in the center of the hotspot thought that put me off. The pebbled optic creates a beautifully smooth beam, but killed cd/lm too much for my needs.
I’ll tinker more with these another day but wanted to give some feedback for those waiting.
Overall, I’d recommend the LEDIL FA10661 with the holder removed and sitting on a standard XP 5mm butterfly gasket. Cd/lm is on point, beam is acceptable unless you obsessively hunt white walls.
Congrats!, that’s an awesome looking light. It’s too bad Lumintop didn’t have an Osram W1 or W2 option as those work really well in the fw1a host. Maybe they can make a Fw1a Pro 2.0 version Lots of other people, myself included, have wanted a bit more throw out of the fw1a, especially now that they are putting the pro model reflector in the regular fw1a. I did a similar mod with a new reflector and an Osram W1, & it makes a big difference over oem version. I’ll try to link to that thread. I’ve got several beamshots in it of how much difference those mods make. Yours turned out really nice.
Thanks!
FW1A is the ideal pocket size for me.
The old FW1A reflector is smooth or OP?
The reflector I have is the biggest around that will fit with slight mod to it.
I bought another grey FW1A and plan to mod the same with SFT40 led.
Will do it when I have the time and compare the throw.
Will post the pictures and results when it’s done.
Eagerly awaiting these results! I think the SFT40 might be too much wattage for the host if sustained throw is your goal, but a fat hotspot with tons of lumens it’ll surely deliver. I’m going to experiment with mine and a W1+TIRs to see what kind of throw is possible while keeping temps in check.
And I agree on the (properly modded) FW1A being the closest to ideal EDC that may exist.
JaredM, this sounds awesome. I now have 4 Fw3a's and would be very interested in converting one into a fw1a with an optic. And I know the LEDIL in the D4sV2 is awesome, so I like their work.
could you link the optic you used/bought that you referenced?
this is awesome information! Thank you so much for doing and sharing this testing! These numbers are really impressive! I have a couple questions, sorry for the ignorance, hopefully you can assist:
-where were you able to get a culnm1 emitter? I've never seen them for sale.
-which TIR did you use ? Could you supply a link where you bought it or anything really?
-Where were you able tk get the smooth reflector? Is that stock on the xpl-hi fw1a? I've only owned the pro with the op reflector, but interested in the smooth.
Ledil’s were bought from mouser. I’ll have to find the specific model PN, the Leila family has a ton of variants, often different part numbers use the same TIR, but a different holder. I once upon a time spent stupid amounts of time trying to sort it out. Visit their site to see what I’m talking about. It was a version optimized for XP-E and of the RS (real spot) type. Also had an RS2, but gains in throw were negligible and beam had more artifacts.
The optics he used were from AE yujiamei store (might’ve spelled that wrong) and I have a few I’m not using I could send. Perfect fit with a bit of filing and broad hotspot (reason why cd/lm isn’t maxed out). I linked them earlier in this thread btw.
The CULNM1 is a rare beast, I also have one I pulled from my X1L I’d be willing to let go for a special guy like you lol . There isn’t a place to buy them bare afaik since L4P ran through his one and only batch long ago. If you are using a light with an anodized shelf and that’s FET dd, I recommend using the HHL532.TK. much brighter than anything else I’ve measured. High VF so Turbo is not overdriving.
I believe the reflector he used is from KD and made for the DIY S3 21700. I’ll let them confirm. It too needs filing to fit inside the bezel, but seems well worth it.
TIR is from Aliexpress. This is a very high quality optic but need to cut off a small protruding notch on the side top edge and also the 3 mounting legs. Can be done easily with a flush cutter.
The smooth reflectors are from Kaidomain. Need to trim the diameter from 23.8mm to 23mm.
How did you manage to remove the bezel of X1L? I think mine is treadlocked. Not that I want to mod it but just curious
There is one from yiajiamei that is 23.4mm but i find that difficult to get a nice hotspot, maybe coz I didn’t have the correct gasket thickness. I believe that has an 8° beam angle.
I have also tried a few other TIR optics that fit but they just couldn’t focus the hotspot.
I prefer to use a reflector or optic that is at least 22mm diameter, that’s why I didn’t try the Ledil optic that you recommended
Btw, I’m not using any gasket on the current TIR. Might get a better throw with the right gasket thickness but I’m happy with the current result.
And I ended up using the TIR on the SFT40 for now coz I am too lazy to file another smooth reflector… Lol!
I hate the UI of the X1L, and now that I’ve destroyed the driver, I’m extra ready to mod it into the dream configuration. I was only getting about 110kcd, and since I have a Convoy M2 making 102kcd, it just couldn’t earn it’s keep. I’m going to machine a spacer and convert to an Angie quad with probably SST20s in 4000/2700 mix or maybe all 4000. We’ll see. Running 4 Osram’s is tempting too.
The bezel was tight. The o ring is dry and maybe oversized too. I broke it open with just my hands, YMMV.
EDIT: I forgot to ask, how do you like the TIR SFT combo? 41kcd sounds pretty nice with what is probably a huge hotspot. Artifacts? Tint variation? …… Beamshots?
Convoy M1 is even a better thrower than M2 with Osram leds.
Also you can checkout Sofirn IF22 with smooth reflector or IF22A with TIR. Both comes with SFT40 and throws very well.
