I started out using lanyards, it just seemed smart as I often use lights and knives on or close to water. After some time decided them more of a hinder than a help so I removed the lot of them from lights and knives so now I don’t use them anymore and haven’t lost or dropped any so far.
Hmm. I voted “not know”, because I use the lanyard only if there is high risk of dropping the light or losing it in an unrecoverable situation.
Normally, it is too much of hassle to fiddle the hand through the lanyard and a light dangling around is too distracting or even dangerous.
Sometimes I have velcro attached to one IF25A to be able to fix it to the outside of a glove if needed. This gives free movement and keeps the light at hand.
I only use them on lights used outside, which isn’t many.
Agreed, the couple of times I dropped a light was fiddling around in gloves putting the lanyard on or off.
No, more often then not they’re just an extra nuisance for me. Either a pocket clip or a fob of some sort.
Dropping an expensive/pristine light is a heart-stopper. I use lanyards for the larger than EDCs (which usually are inexpensive lights).
Having said that, the many that have posted on their techniques got me thinking of better ways to harness these dangling reins.
Some of my lights (as 26650s) I don’t like the knot so I weld the ends butt joint. Using paracord, but not with inner strands. Don’t know how to describe but interwoven, not twisted.
The larger soda cans or throwers, using a lanyard w/ adjustment tension clip (someone might know their proper name).
Not fond of clips as they hinder the feel in my hand. However, the small 16340s I use for mounting on my cap.
I thought I could give the examples of….
flashlights with lanyards
lanyards without flashlights
Nope…. never liked them.
And I never dropped a flashlight while using it. However I did miss the holster once and it fell to the ground with no damage done! Thankfully a light that goes in butt end facing down……OSTS TN31mb
Lanyard is the first thing to come off if it’s pre installed. I save it, but never use it.
That’s a good one and made me laugh, cheers to you
i’ve never used a lanyard and didn’t use one when working on a car and trying to trace the wiring colors into a connector that was behind the motor and close to the firewall—and then the light slipped out of my hand while contorting and trying to see down into that space.
i should have used a headlamp to free up my hands, but didn’t realize it was gonna be such a pain to find the harness. So you can probably guess the ending—i had to go get the floor jack in order to remove the bottom splash shield under the motor in order to recover the light which was still burning bright.
If i have to do something like that again, well i learned the hard way and will be using a lanyard that is firmly secured to my limp wrist. :laughing:
Hate lanyards, hate clips, hate “tacticool rings”. Always take ’em off if at all possible.
I don’t like all that crap stuck to a light.
Nope, can’t use them. If it’s a everyday light, the lanyard hanging out of my pocket will snag on something and send it flying into an unknown realm of the universe. If it’s a big light It will get snagged on something and send it into a unknown realm of the universe. I rip every lanyard out of the box and throw it away, along with the box.
I dropped a new custom MTN flashlight way back when and put a nice ding on the tail. The flashlight survived no problem, but I sure was upset with myself.
Ever since then, all my flashlights have a lanyard. I personally prefer the style that comes with the Convoy flashlights.
When my kids were younger, I told them they need to use the lanyard when they borrowed my AA flashlights. None of them were ever dropped, surprisingly. The other cheapo ones sure got banged up.
And when I go jogging in these colder months after work when it’s dark, I put the lanyard around my glove so I don’t have to worry about the flashlight slipping and falling.
It’s about half and half but I like them for a few reasons:
I have a few by the back door on a hook so anyone can use them to let the dogs out or take a walk at night around the area.
Heavier lights can benefit from them.
Kids may be less apt to drop a light if I encourage using a lanyard.
In my bag, I have a lanyard clipped to an internal loop so it’s not always working its way to the bottom of the pouch.
On my keychain, it keeps a tiny light available at all times and quickly accessible.
That said, some lanyards that come with lights are kinda flimsy and I have a few that can’t even go around my wrist. Wonder who they made those ones for?
I’ll take them off your hands. I don’t use them all the time but I make sure all my lights have them especially since I almost dropped a custom s43 in a cave
I wonder this too. Some seem unsafe (quick release), some are too small, some have metal clasps, some don’t fit through the holes. …I’ve never searched for lanyards though
Quick release is safer for situations where the alternative would release (or injure) a portion of your body instead of the light.
I only use lanyards on lights I know will see heavy use on hikes. If I’m dangling an expensive light to look under a bridge or over water then I want more than a firm grip on it. It’s also nice to be able to let go of the light briefly to do something else with that hand.
First thing that goes to the trash, second is a belt clip, that scratches your case when you remove it…
Just never liked both of ’em
If I do I make my own out of paracord because I do not trust the strength of the stock ones. On the smaller flashlights I just remove the 7 inner strands so the lanyard isn’t so fat and it’s been working great for years.
And don’t forget that a lot of the milled holes for a lanyard can be sharp, and cut through the dinky little string that holds the lanyard, so when you most need it to keep your light, it might just snap off and there it goes…
