So I'm considering replacing the emitter in mine to a new U3 1 C from I/O (not sure, but it appears my original emitter is burned out). Should I buy a 20mm star and file it down slightly? Or should I stick with the 16mm? What would you do?
My unbranded HD2010 only pulled 1A with the stock driver for some reason, and was a big disappointment.
Within minutes I was disassembling it and replacing the LED with a U3 on copper and a 9x7135 Nanjg. MUCH better now.
Later I discovered a broken solder joint on the tailswitch, and I chalked up the initial low readings up to thatā¦ but reading your comment makes me wonder.
For as good as an HD2010 could be there's no match with the TN31!
I have both. The Ultrafire branded HD2010 from Tmart and is a good one, measured mine at 3,4A high with a 26650, nice tight hotspot with lot of throw. But Crelant 7G5 throws better, with a smaller brighter hotspot. And TN31 throws better than the Crelant, with an even brighter hotspot. HD2010 Vs TN31 is no match, it's plain unfair. That's in stock form, at least.
I read that you dedomed it. Reading other thread here on BLF, some have better results than others. Myself not tried dedoming yet. Curious but not to the point of ruining a perfectly good light...
Dear MarioSS,
Do you have order the item (HD2010) on our website before ? If yes,could you please offer me your order number? You can inform me the issue in details,then I can handle it for you as soon as possible.
Thanks for your support and patience in advance.
If you have any question, please feel free to contact us.
Thanks for your interest Sherry! Really appreciate it
Well I contacted Tmart customer representatives 3 times and they did point out the HD2010 you have in stock is unbranded. I guess you ran out of stock of UltraFire HD2010.
Dear MarioSS,I am writing to tell you that the HD2010 which in stock is unbranded.The one we have brand isTangsFire-HD2010. You can check the detail on this link:http://www.tmart.com/search.html?typeid=3330&q=TangsFire-HD2010
Just received my gray color unbranded from Tmart today. I have a black branded one from Tmart as well. The gray ones are just as good as the black branded ones.
I got my gray HD20120 from tmart today. Out-of-package i droppped 26650 in it and everything worked great. Then i cleaned threads and added silicon to o-rings. After this light only worked at HIGH STROBO SOS modes. Really wierdā¦
Oh well, my plan was to replace the driver, so i did that. I replaced old driver with NANJG 105c driver from intl-outdoor.com . To that driver I also soldered two extra ā7135ās. With new driver mode changing is working again and got rid of those flashy-blingbling-modes ( Yea, I hate those ). Current reading from tail-cap is 3.5A now with new driver.
This light really gives some good throw!! wowā¦
I have two u3-ic leds laying un-used, so maybe iāll swap one of those in this light ācause this reflector really hungers for more lumensā¦ >)
So i swaped that led to U3 1C and driver is that AMC7135*10.
Hereās a little comparison between this and stock Trustfire A8 from keygos.com
Distance about 80m to that tree. I posted this also here , but wanted to share it here also.
Mine has perhaps a bug in the software. If the light is turned off at any other mode than high, it wonāt turn on after waiting a while. After the first firm click it needs a soft press like changing modes to turn it on at high.
I have an unbranded gray HD2010 from Tmart that just arrived. Iām happy with the light. Draws about 3,2-3,4A from a 18650 (more if I compress the spring) and throws well. Threads are smooth and the quality is very good. (o-rings needed changing to a bit larger and some grease was needes for the o-rings and threads)
