Thank you RC, yes I am aware of that facility. But the R-Click context menu doesn't require you to move the mouse pointer from where you are to the top.
And it was available previously, & it is a normal feature on OSs & forums.
Oops, thanks a lot for letting me know. I originally had it configured that way, and then proceeded to break my own configuration. :D Should be fixed now. The browser's context spellchecker should also work now.
Oops. Iām afraid itās a bit difficult to add them back now. The configuration section of the Smiley module is refreshingly devoid of all semblance of design and usability.
Butā¦ when there is time, after other things, right? Rightā¦? :(( :((
By the way, have I told you what a wonderful Admin you are recently? Exceedingly kind, intelligent and handsome too. Not one to forsake even a poor little ghost.
At the risk of looking like Iām calling someone out (there are plenty of examples, this is just handy) is there any way to limit the amount of quoted text?
IMO while the number of quote levels was excessive in your example (fairly minor forum-etiquette issue), the real issue is simply that the forumās styles do not change at all on smaller screen sizes. The margins/spacing in use there exacerbate the issue greatly.
Some forums limit to the last quote, but i agree that its not an ideal solution. One thing i have noticed is some forums have the link to the quote
One could implement say last 5 quotes, every quote links to its source hence the first of the 5 link to the last one, which would show the previous 5, which links to the previous, so a few clicks can get you to the first post without having the crazy long quotes
Iām sure i am explaining this badly, trying my best
Ooooopssssss, I saw the <Mark Read> button at top left & I pressed it while in this sub-forum, BUT it marked the entire forum including all sub-forums as read.
I assumed it would Only mark the current sub-forum as read (as it did previously).
AFAIK, the only <Mark Read> button that marked the entire forum (including sub-forums) as read was in the "root" forum ie: http://budgetlightforum.com/forum
Iām for a reasonable limit on quotes. I donāt know what it would take to ātileā them in a stack (click on what you want to see) of to collapse them by default then add an āexpandā button to read them.
Thatās really been my biggest issue since I signed up here so Iād say youāre doing very well indeed SB.
I just did a quick test and found that itās fairly simple to hide any quotes deeper than N levels. I tried to put in a placeholder for ā(quote omitted)ā instead though, and it didnāt work. So itās easy to do if you donāt mind not knowing whether there are deeper quote levels.
I also made the dark theme use less padding around quotes, so it doesnāt turn into a vertical column so quickly.
With it set to N=3 (limit to three levels of quoting), the same post looks like this:
One big downside of doing this is that it might encourage people to quote even deeper, since they might not be able to see that theyāre including so many levels.
Edit: FWIW, this can be done as an independent stylesheet so you can get the same effect regardless of what theme youāre using. If you want, you can try it here.
For my part I do my very best to limit the amount of text I quote. When a heavily nested quote appears in my quote it is because I believe that the context is either very useful or entirely necessary for understanding what I am writing. Sometimes in busy/large threads with multiple conversations a big quote is easier for everyone.
I feel that an arbitrary limit on the number of quote levels is a bad thing.
I do think that Javascript could easily collapse some of the quoted posts in an expandable box. That would be worth investigating IMO. Iām not volunteering.
