We need a new “light programming” section, as these complicated UIs are for the dogs. I cannot adjust the 12 modes of my new L21A with these instructions…
Specific Gear: 12 groups
- Click the switch to turn on/off the flashlight, half-press the switch to select the mode
- If the flashlight is turned on, quickly half-press the switch 20 times to enter the configuration mode. (On a visual interface (such as a mobile phone), as long as you click on an option, it means that the option is selected. The flashlight has no visual interface, it uses flashing to indicate an option, and “half-press the switch during flashing” means Select this option.)
● Option 1 (normal flashing once + buzzing flashing): half-press the switch to enter the sub-options and start to select the gear group. If the user does not operate, the configuration mode enters option 2.
Sub-option 1.1 (normal flashing once): Touch the switch to select gear group 1 (0.1, 1, 10, 35, 100%, flashing, beacon, battery detection)
Sub-option 1.2 (normal flashes twice): Touch the switch to select gear group 2 (0.1, 1, 10, 35, 100%)
Sub-option 1.3 (normal flashing 3 times): Touch the switch to select gear group 3 (100, 35, 10, 1, 0.1%)
Sub-option 1.4 (normal flashing 4 times): Touch the switch to select gear group 4 (1, 20, 100%, strobe, flash, beacon, battery detection, SOS)
Sub-option 1.5 (normal flashes 5 times): Touch the switch to select gear group 5 (1, 20, 100%)
Sub-option 1.6 (regulation flashes 6 times): Touch the switch to select gear group 6 (100, 20, 1%)
Sub-option 1.7 (normal flashing 7 times): touch the switch to select gear group 7 (0.1, 1, 10, 50, flashing, beacon, battery detection, SOS)
Sub-option 1.8 (normal flashes 8 times): Touch the switch to select gear group 8 (0.1, 1, 10, 50)
Sub-option 1.9 (Normal flashing 9 times): Touch the switch to select gear group 9 (50, 10, 1, 0.1)
Sub-option 1.10 (normal flashing 10 times): Touch the switch to select gear group 10 (1, 10, 35, 100)
Sub-option 1.11 (normal flashing 11 times): touch the switch to select gear group 11 (100, 20, flashing)
Sub-option 1.12 (normal flashing 12 times): touch the switch to select gear group 12 (100% single gear)
● Option 2 (normal flashing twice + buzzing flashing): half-press the switch to activate or deactivate the gear memory. If the user does not perform any operation, the flashlight will enter the last gear.
It just seems to start in option one. No amount of flashing adjusts anything.
