Got mine yesterday. Stuck 2 18650’s in it. Damn slow to charge. Forgot about it went to bed. -Woke up when smoke alarm went off. House on fire etc. Wonder if I will get a giftcard for 500K. (worse case scenario)
No fire. Both batts charged to 4.17v. I am gifting this one to a friend.
Did try a rechargeable 1.5 v battery. edit (AA VARTA NIMH 1.2V) Seemed to take hours. Pulled it out and it was 1.41 volt and very very hot. Is a versatile charger but I prefer others.
This is why I am asking, I also read HKJ's review, and if I understood correctly, putting 2 batteries on the same rail (#1 & #3), they each get 375mA. I would think that for 10440's 375mA would be ok...
So just to clarify this, charging one 10440 is obviously a no-go, but putting a pair on the same channel (#1 & #3) charges them @375mA each, and that's ok?
"Notice the bump in charge current just before the charger stops. This is because the second slot for that charge channel finished first and the full current is directed to the first slot where the measuring equipment is connected."
Its not an 10440 charger I guess. Unless both cells are pretty similar, then the current would only be (maybe) to high in the CV phase. HKJ said it has a termination current of 44mA. That should be ok, but you might lose some capacity.
Depending on the difference in initial charge, you might have reached the CV phase, where the current is lower, but if not, you will get 750mA.
You will also see in my review that I do not recommend using 10440 batteries in the charger and has marked them in red in the "supported battery sizes" list.
Just to clarify it one more time, if I charge two cells (2x 18650 eg) at the same time, it would be better to put them in slot 1&3, right?
So it is actually better to charge the cells in pairs of two, instead of 4 at the same time?
C9000 is a slow charger? :bigsmile: You must be kidding, right? My BC700 can charge @.7A max, but C9000 can charge up to 2A! My old Varta charger IS slow - 16 h.! :bigsmile:
On topic: I think this Intellicharger is an awesome charger, especially for 20 bucks. One charger to rule them all
Usually I use slot 1 and 3 when I am doing a pair of 26650 or a pair of 18650s. Also, I have put a 26650 cell 1, 18650 cell 2, aaa cell 3, and aa in cell 4. I wait for all the light to go to 3 non blinking. Everything works. I have noticed that if a cell is not fully discharged, it will take less time to charge…
