$37.99 for Opus BT-C3100 V2.1 with OP3100 ( clearance) & $38.99 for Opus2.2 without using the coupon @GearBest
It took me a while to find the BC-3100, and then even longer to find who sold v2, then I finally found Gearbest and this site, and found out v2.1 existed. Can’t wait to get mine.
As for tagging the unit for reflashing(if possible?) the main chip, sounds like a fun task. I wonder if someone can actually find out what chip it is under the hard black goop to be able to facilitate such a task. I would love to know what all the IC chips are.
As for changing out the main chip, I’ve never been able to remove the hard black goop on anything without a whole lot of destruction. I guess one day I should see if there is a way.
As for the internal switch, I was thinking if when a further hardware revision is done, the bottom could be retooled, to have a recessed switch or dips and one shunt to select the max cell voltage. I know the bottom panel just can’t be changed now, due to the battery slide being too close to the switch. If I needed to use that switch now, I’d just make a hole and use a tweezers to change it.
This is my first post, where’s my prize :party:
Anyone get passed the “pre-advised” shipping stage yet?
Been that way for some time now…
Yeah mine already arrived in my local post. I ordered some time ago though…
Mine became “Received from customer” today. Pre-ordered and “shipped” on 8/26
yes, DanielM is the first one who ordered when the coupon published :bigsmile:
Hope you will get it soon H)
I’m not sure if meti is the second one order, but I’m sure that you ordered on Aug 22th, the coupon published date :bigsmile:
Hi HKJ.
Will the 2.0 and 2.1 versions work properly and charge 1-2 AA neneloops if connected to a 12VDC power bank rated at 2A only?
The default charge is 500ma and with NiMh batteries you’ll only need it’s low voltage, which will be auto-detected due to the cell being less than 2v. I don’t think you have anything to worry about unless you want to try four 4.2v cells at 1A each, just to stay on the safe side.
If voltage goes down, amps should go up, so that 2A@12V has more amps as voltage is stepped down. If this was not the case, other people would need a power supply over 4A, thank goodness for Ohm’s law.
I would guess yes.
With four batteries it uses a peak current of about 3A.
Just ordered one today after reading reviews from HKJ and Chloe . Thanks
Minimoke
Thanks HKJ for the quick reply.
Did some quick tests using this power bank as the power source 12V 3A power bank and my Opus v2 and see if it will work. I put 4 fully charged Sanyo UR18650ZYs to ensure I have enough juice to do the test. I was only successful in charging 1 AA envelop max of 1A. When I tried 2 AAs, the power bank started acting strangely though my Opus charger seems to work properly. It seems my power bank cannot provide consistent 12VDC at the right current needed by my Opus charger. Not wanting to damage my power bank and charger, I stopped the tests.
I really need some decent AA/AAA charger that can run on AC and 12VDC. Can you recommend one that can complement my Opus charger?
another opus charger :smiley:
:smiley:
If I will, then for sure it will be the v2.1.
No, really. For AA/AAA I have the Opus BM100, a small, dead quiet unit which can charge/analyze/discharge/refresh cells. It has it’s own power adapter for 3v though, so no 12v input.
I wonder if the problem is more because of the current pulses, instead of just the current.
A good charger is the Xtar XP4c. It can both handle NiMH and LiIon.
Or for a cheap solution the Nitecore i4 (It charges a bit slower).
I thought you were suggesting the v2.1 model. Yes the BM100 looks nice but as you said it can’t be powered by 12VDC.
Thanks anyways DanielM.
Will check on that Xtar HKJ. The i4 is on my radar too. Am also looking at the Soshine SC-F3. It may not run on 12VDC but runs on USB 5V. I have 6 power bank including 3 with replaceable batteries and lots of 18650 batteries to power those power banks.
Is the price coming down soon?
We have sold the 100th unit :smiley: . As promised, a $2 coupon would be sent for each unit bought, but to show our sincere gratitude, a $3 coupon is now posted in the buyer’s GB account to all those who bought in the first 100 units!! (Any one who bought in $45 but not get the $3 coupon, please kindly PM CSgearbest)
New coupon: OP3100
Price: $42
Thanks for your all SUPPORT! :beer: :beer: :beer:
got my coupon thanks GB
