OK... here is the ending of this little scratch build saga. Its so old now it has moss growing on it but I wanted to get it finished up. You can look at the OP and refresh where we left off.... Enjoy... I REALLY kept this as short as I could... no, REALLY!
I added a little blue tape to avoid all the scratches I could.... All dressed up for the prom here.
This is why I won't build lights using this method too often... This shows the jaw depth of my lathe chuck... It can easily swallow the head of a D sized Mag light but as always, there is a trade off... The smaller lights are harder because ... well... let the image below this one explain.
As I was saying... because of that jaw depth, if the part has detail or a head on it like this light, the smaller lights make you work really really close to the chuck!! Not all that hard but nerve racking.
I used one of the high tech tools to remove the tape from the work area....
Turned the part down the Major thread size and then put a bevel on the front outer edge... this makes the threads "Glide" together when they start resulting in a nice feel. After this the threads were cut and that ended the work on this main body part.
Time for the end cap.... Always starts the same... with a center drill to keep the actual drilling started straight.
Then the Drilling...
Now the cap... or soon to be cap is bored to exact "Minor" thread size ID with a boring bar. This keeps everything close tolerance, straight and smooth. The surface here actually becomes the outermost portion of the inside thread... confusing but thats how it is so smooth is important.
We'll jump ahead here... The cap now has the inside threads cut...
The threads fit, I cut the cap off the stock, added a slight bevel... and the light is already trained for tail standing!!
Time now to punch a center hole in the end of the cap for the switch cover.... CENTER DRILL AGAIN!
Again... as the tool reaches into the part... things get close.
Drill Again....
Time to work now on the end & finally outside the cap... We're getting closer! The boring bar here is adding a little decoration.
Decoration added to match the bezel on the front and the switch cover hole bored to size. ... I hope!
It fit.
Nice snug... tight fit for the switch cover and the decoration looks better without that ugly hole showing.
I added just a line or two to the cap with a pointed tool , did a little cleanup on the outer edge of the end and added a touch more bevel.... Hit it with a scrubbie and there it is.
Business end.... Waiting on 1 O ring!
The light is nicely balanced and feels good when you hold it.
This was a fun little project and I have enjoyed sharing the build. As I said once before, documenting this really makes me have added respect for what Old Lumens ad some of the others here do. It easily triples the build time on each part of the light. I hope every member here that wants to do this gets a chance one day. THIS will hook you for life. I build quite a few lights and yes, I get tired...but I still like scratch building and enjoy the challenge! Sorry this was so long! Dan.
