Hello my dear friends!
i got a new groupbuy for you!
just ask me for "the password"
Specifications:
| Brand |
JETBEAM |
| Model |
Mini One |
| Main light |
1 * XP-G3 LED. |
| Auxiliary lights |
RGB LED, UV light. |
| Max. Output |
500 Lumens |
| Max. beam distance |
85 meters |
| Charging Port |
Type-C |
| Material |
Stainless steel |
| Sidelight |
Red, green, blue, UV light. |
| Waterproof |
IPX8 |
| Weight |
29g |
| Dimensions |
54.3mm(length)*14.6mm(head diameter)*13.2mm(body) |
Description:
– Red Green Blue multipurpose: Red light safety warning, green light view map, blue identification of blood stains, identification.
– Side lights, ergonomic and simple one-hand operation. Main light/White light: Short press ON/Off. When the light is on, A long press of the power button changes the various brightness modes from Eco-low-middle-high. When the light is off, press and hold the power button to access the Turbo(shutdown over 30s). Release to turn it off.
– Side Lights: Double press to turn on, press again to turn off. When the sidelight is on, A long press of the power button changes side lights from red-green-bule-red flash-Flowing light-beacon.
– UV Light: Triple press to turn on, press again to turn off. All mode have memory function.
Features:
– Use one XP-G3 LED.
– Fluorescent whitening agent detection 365nm UV.
– Max. Output to 500 Lumens driven by built-in Li-ion battery pack.
– Max beam distance up to 85 meters.
– Ergonomic design, small for everyday carry.
– Conveniently USB TYPE-C rechargeable.
– Can fit in pocket or hand on keyring.
– Constructed from stainless steel.
– Impact resistance of 1.5 meters
Package included:
1 x JETBEAM Mini One EDC Flashlight
