I just got a UniqueFire UF-V3 and while it is an awesome little performer, it is way under driven (1.74A on high). Obviously I want to replace the driver but the pill in this light only takes 20mm drivers. This poses a problem as there are no 20mm drivers I know of that meet my needs. I first thought I could just place a 17mm driver inside behind the 20mm driver but the space inside the pill is only 4.5mm deep. Besides, being an all aluminum pill, soldering a good, dependable ground to the driver would be difficult. I brought out my bin of parts and figured a P60 pill might just fit inside of the original pill. I can work with that! Here is what I did…
Here you can see that a brass p60 pill will almost fit inside of the 20mm pill of the light. What we need to do is grind down the circumference of the brass pill a bit plus enlarge the inside diameter of the aluminum pill. Leave enough material so that they can be pressed/hammered together for a tight ground for the driver.
Here is a pic of the modded p60 pill compared to a stock version. I ground down the emitter side lip so that the brass pill will sit tight against the inside rear of the aluminum pill. I’ve also ground down the sides of the brass pill so that it can be pressed into the aluminum pill.
Using my rotary tool and cutting bit, I have cleaned up the inside of the pill and removed some of the inside wall to allow the brass p60 pill to be tightly press fitted.
A dab of fujik fills any air gaps between the top of the p60 pill and the back inside of the original pill.
Now that your brass insert is ground down and your pill opening is opened enough to allow a high pressure fit you can place the two in a vice and press seat the brass insert into the original pill. Optionally you can carefully tap them together using a block and hammer.
Onced pressed in by vice or hammered in with a block you will end up with an aluminum 20mm pill with a 17mm brass insert for your new driver that can easily be soldered to.
I’m quite sure this could be used in any light with a pill meant for a 20-21mm driver. Hope it helps some of you. ![]()
Johnny
