back to Amazon….
clip the coupon so you can get
6 for $25 (that means free shipping):
Energizer LED Rechargeable Plug-in Flashlights, Safety Plug-in Power Outage Lights
It’s fairly cheap construction, the emitter sits on a thin alumnium mcpcb attached to ~1mm wall with a huge empty cavity. Poor thermals. The UI is okay; memory mode but has decent spaced output levels. mechanical lockout is possible if you turn the head 1/4 on driver side. An emitter swap is tricky. I wasn’t unable to get access to the emitter without scuffing up the optic thanks to the lazy press fit design. nothing is glued.
To get the switch and subsequently access the driver I place a flat screwdriver where where charger is attached and pushed the press fit bezel upwards. Now desolder the 4 wires of the switch and remove the metal clip that holds the driver in place and push the driver downwards, it’s attached to the mpcbc.
To get the the mcpcb, It’s possible to push on mcpcb to get the bezel but I didn’t have enough leverage. I placed the head in a vice put some tape on the optic and between the optic and optic bezel I use a small flat screw driver as wedge to lift the press fit bezel. viola
Yeah, some of these names are really silly. I’d gladly pay a few more bucks not to have some dumb name on the front. A logo is fine, but stupid-sounding names not so much.
How do you know if you have powerbank functionality? I didn’t see it in the manual but could have missed it. I spent more time searching for reasons for the various blue, purple and amber lights flashing seemingly indiscriminately. Just got it yesterday so maybe with time they will make more sense. Pretty good little hotrod I must say for 25 bucks.
It's not listed in the manual I received either, but if your TS21 uses Anduril-2 and has the "Amber Switch LED" then you most likely also have the "Power Bank" feature. I verified mine had it by connecting to an in-line USB meter and then charging other devices.
It's a known bug/feature.
Also be aware from: https://budgetlightforum.com/t/-/66841/275
