Everything started while I was first readingthis interesting GB (and FL-mod) topic. As a newbie in flashlights I am (I started reading just a couple of days ago), plus not speaking english as native language, I couldn't understand which part called "a-b-c" corresponds to "x-y-z" picture. I had to google for every part name I was reading in order to see it's picture and understand. That's why I decided to find a picture of a flashlight, showing most of it's inner parts and simply add their names (terms) in the picture. Then I've realized that the flashlight in the topic (Brilyte B158) has some parts that are different from other flashlights. The main difference in the modding procedure is the pill and the driver. So I've added some more pics, showing a couple of pill & driver variations.
FL pic with main parts(2015-12-06 edit:djozz's pic)
Nit pick on the first image. Shouldn’t the part indicated by “tail cap” be the switch cover or boot and the threaded metal cover be the actual tail cap?
Ok, but that’s not the impression I get when I read about people taking tail cap measurements, disassembling or battery lockout by unscrewing the tail cap. This is what I typically expect.
I thought the bezel screwed on to the head, typically holding the lens down?
I was also under the impression that the tail cap is either the part the houses the switch or the entire tail switch assembly, with the rubber/metal cover being called a switch boot or switch cap.
It really helps, thanks for your valuable contribution to this topic! :)
Γεια σου κι εσένα φίλε μου! = Geia sou ki esena file mou! = Hello to you too my friend! :)
Thanks for the welcoming and the positive thinking for this topic. I could try to translate the flashlight parts in Greek if somebody's interested! :p
Well, I haven't got the slightest idea. Thanks for your kind words, I really hope this guide will help newbies understand easier what's what.
As I realize now, "tail cap" might be called just the rubber that covers the tail switch (as fasttech's search result in previous link), or the whole "tail" tube part of the flashlight (especially if there's no rubber at the tail, as in lots of flashlights).
Where in Greece are you KGB? And what is your name? I’m Paul. My wife used to live and work in Greece before we met. We have lots of Greek friends, mainly in Crete, some in Athens.
