First thing I do when I get a new flashlight is to shine the light on my skin. From my experience, shining the light on my skin gives me a pretty good idea of the quality of the light.
Now that I have somewhat usable measuring instrument for lights, I have become a little more confident of my testing method. I think it would be useful for community members, so I decided to share it with the community. I used Opple Light Master Pro (G3) to measure CRI and calculated DUV from waveformlighting.com. The photos are taken with my phone Samsung Galaxy Note 20 Ultra. I used Pro mode in the camera app.
Testing method
- Shine your flashlight on your skin. I use low output levels.
- You can easily compare the skin tones of multiple flashlights by alternating between two or more flashlights.
- Low CRI or low R9 LEDs tend to show more of green and yellow tone. High CRI LEDs with high R9 show more red tone.
Why skin?
Humans have excellent sense of distinguishing skin tones. Also, red color of your blood shows how well your flashlight shows red.
Results
First, here is the reference photo. The photo was taken indoors with overcast daylight. Camera WB showed 5000K and since the window was mostly covered with blinds there were relatively small amount of light. I think it represent my skin tone quite well. My ethnicity is east Asian.
Figure 1. Reference photo. Overcast daylight.
I took several photos of my hand using 9 flashlights at the same spot using the same camera setting. I used low output through out this article because high output tended to confuse the camera and sometimes ended up with random and weird representation of my skin. Which one do you like?
Figure 2.Which one do you like? (manual WB 5000K)
Here are the same photos with the names of the flashlights and LEDs.
Figure 3. Main result (manual WB 5000K)
The following are what I observed:
Known low R9 LED shows more green and yellow.
Low CRI LED shows a lot of green and yellow.
You may think fixing the white balance to 5000K is not fair despite the fact that most of lights used in this testing is in the range from 4500K to 5800K. To address this concern, I manually set WB to nominal CCT of the LEDs. For example, I set WB to 4500K when taking photo using E21A 4500K LED. This exaggerated reds in my sample.
Figure 4. Manual WB, set to nominal CCT of LEDs
I use auto white balance setting and took the photos again. This made all of the photos to show more pale skin and the difference between samples is a lot smaller. However, you can easily pick the best LEDs in terms of color representation.
Figure 5. Auto WB
Here are the Oppple Light Master Pro (G3) measurements.
Figure 6. Opple Light Master G3 measurements
Here are the list of lights used.
- Wurkkos TS10 Latticepower 5800K
- Sofirn SP10 Pro Samsung LH351D 5000K
- Convoy T3 Nichia 519A 5000K
- Lumintop FW3A CREE XPL Hi 5000K
- Emisar D4V2 Nichia 219C 5000K LCRI
- Noctigon KR4 Nichia E21A 5000K R9080
- Fireflies NOV-MU Nichia E21A 4500K R9080
- Nitecore MT06MD Nichia 219B 5000K HCRI
- Fireflies E07X Nichia 219B 4500K R9080
Figure 7. List of flashlights
