What happens if I set memory timer larger than autolock timer? I think autolock should reset level to memorised, but what happens when memory timer time is up? Level will be reseted once again?
I was pretty intimidated early on by this, too. When I created my fork and put it on github (GitHub - mkong1/anduril), i wrote a couple quick bash scripts to simplify the build, and flashing. I only have Emisar/Noctigon lights, so the `flash_light.sh` only has a couple preconfigured Emisar/Noctigon lights, and currently hard-codes `-p t1634`, but the goal was to make it a bit more approachable to anyone on a Mac.
Would love any feedback that could improve upon it!
Iāll also say i have never used Bazaar for anything else, and i have a basic config option that i think would be useful to allow compile-time option to unlock to off state, but i spent 5 minutes try to suggest a merge, and definitely did it wrong twice. ~mkong1/flashlight-firmware/anduril2 : revision 580
Sorry, haven't checked this thread for a while. K - that's my new master Anduril2. I kind of have to meld in these updates with all my special cfg and hwdef files.
I have a problem, itās a ME problem. I have become very used to Anduril, and all of the functions I use on a normal basis(ramping, stepped mode, battery check, thermal setup, and maybe a couple of others).
I am a little afraid of learning Anduril 2.
And it is inevitable because I have two new Hank lights and I think they have Anduril 2, but never the less I will order more lights with it. I know my all copper kr1 doesnāt respond to some commands the same as my other Anduril lights.
I have tried to follow this thread but it is obviously lengthy and I donāt know where to startā¦
Can some one suggest a diagram that has been made that shows Anduril 2 in somewhat of a simple or straight forward way. I just feel like with the two options for basic and advanced, and I donāt even know what changes have been made, I am going to get lost in Anduril 2. Anduril ā1ā took me a whole 3 days to figure out enough to be happy when I was green to this stuff last February, is Anduril 2 as āstraightforwardā? I am just worried because now I am forced to learn it and everything new is, well⦠new. And sometimes intimidating for boneheads like me.
To me, itās pretty similar in itās day-to-day usage as V1. A few notable differences:
Simple UI is enabled by default. If you want to get into config menus, access Turbo, or use blinky modes, youāll need to switch to the Advanced UI.
While the main sequences (on, off, ramp up, ramp down, lockout, etc) are all the same, accessing Turbo is different by default unless configured differently at compile time. Momentary Turbo is a 2H from Off. āNormalā Turbo mode is access by getting to the top of the ramp and doing a 2C. But like I said, when compiling the code, you can enable ā2C Turboā in which case itāll act pretty similar to Anduril V1⦠so this may vary by manufacturer according to their requests.
Blinky/utility modes have been reorganized: sunset mode has moved, Temp Check now follows Batt Check
Button press sequences for config options have changed
You can also access momentary turbo directly from on with 3H, provided the light doesnāt have tint ramping or two channels (like the K9.3), as that also uses 3H.
Lux-Perpetua - thank you, that is perfect! I will study it. I didnāt see in the advanced UI the commands for basic on/off ramping, etc. Is that explained up too in the āsimple uiā section, in light gray?
GChart- thank you as always, I appreciate the highlights and that will be a good starting point for 90% of my use. Only thing that kinda is a bummer is accessing turbo⦠outside it is often nice to go from āmidrampā or so to turbo and back easily. Not a huge problem, just not ideal I guess. Especially since I have no knowledge whatsoever on how to compile files and honestly I donāt know what that meansā¦
I finally flashed one of my FW3As to Anduril 2, and Iām really liking it, other than the fact I canāt access turbo in simple mode. It seems like this should be a flag in the ramp config rather than permanently locked out, especially since you can still set the ramp ceiling to full turbo. Simple mode is almost exactly what Iāve always wanted Anduril to be from the beginning: a fully functional light with all the extras and config menus hidden in a way you will never access by accident. I just really wish I could set the ramp behaviour to be exactly the same as advanced mode. Has anyone tried a build like this? Reviewing the code, it seems relatively simple, but adding the extra flag to the menu would be more work.
Yes, the UI section in the top part displays both SIMPLE UI and ADVANCED UI. The light gray lines represent the access to turbo that is restricted to ADVANCED UI only. I am still working on a nicer chart in a scalable vector graphics file format (SVG). This one will probably divide SIMPLE UI and ADVANCED UI, hence hopefully it will be easier to read and understand (fingers crossed). I also try to emphasize how to handle configuration menus as it differs from AndĆŗril 1.0, e.g. thermal configuration.
Just wondering why thereās no setting to enable turbo in the Simple UI?
It makes zero sense to be able to change the max ramp to turbo and leave out a setting to just enable the regular turbo. Having to do this then eliminates lending the light to a muggle without having to reconfigure the max ramp.
Thereās a heap of people that want to be able to use a flashlight in Simple mode and not lose max output, myself included.
Please consider allowing one to just enable the regular turbo
The code fix is very simple. I have described here:
Now I want to find the settings of the default values so that auto-lock, floor and ceiling levels are set and enabled after the reset.
Another thing to do is set the blink to any level. I want to check the optimal light level for each flashlight, the one in which there will be a constant light without the temperature regulation. A wink would indicate this level.
Gabe: I updated my Anduril 2 installation to your version, link above. Problem is it seemed to be missing the Mateminco/Astrolux FET+1 support that has SammysHP fix for the 7135 on pin #3. Just downloaded Anduril 2 to a Mateminco MT01 (same as EA01) and the 7135 channel doesn't work.
I don't know, can't recall exactly what I did, but apparently I had SammyHP's version of fsm-main.c, or had my own custom version, and lost it. Strange because I usually make a backup, but might have deleted it thinking all was working well with the first couple lights I used it on.
History on this issue:
Mateminco apparently likes doing things their own way and is using an oddball pin assignment for FET+1 drivers. So instead of having the AUX LED on pin #3, they put the 7135 on pin #3 and the AUX LED on pin #7 (FET on pin #5), leaving pin #6 unused.
The lights I know of using this pinout config is S42, FT03 (think so anyway), FT02S, Mateminco MT01/Astrolux EA01. There's probably more, not sure.
NarsilM supported this configuration way back because of my working with TA on the drivers for the Astrolux S42 (S42_PINS). I think TA was objecting to this too, but Mateminco already committed to the layout.
standard Anduril, and I guess Anduril2, never supported this. The driver and pin assignment support was hard coded for certain usage
Hey Tom, the thing is⦠My branch is a copy of TKās, just with 1-Series support. I could probably merge SammyHPās fix in there too though next time Iām in front of the computer. You (or someone) might need to verify it though. I have to see if I have any lights with their layout.
