Best I can tell, the lowest level in the tint-ramp config is 2/16383; this appears to be this way to allow both channels to be on at the same time with tint ramping as the channels can be split 1/1. Iâd love to have a 1/16383 mode as well as a 0/16383 moon mode.
By the way Iâm having trouble downloading the Anduril 2 code for some reason? Iâm getting a HTTP 500 error when trying to download the tarball directly, and an SSL error when using the Bazaar software on WindowsâŚ
Does anyone know how to fix this?
EDIT: Another idea would be to be able to set the button backlight brightness independently of the AUX LEDs. Iâm seeing them as two separate pins, so I think this should be possible?
I would love it if Simple UI could be changed so that batt check could be configured to use any strobe. This firmware is getting used on heaps of brands and many of my customers find it a pain in the butt for strobe access. Most want the Simple UI with bike flasher, tactical strobe etc. Set it to whatever is needed in the Simple config menu
Thatâs an interesting idea. Perhaps the simple UI could memorize the last-used 3C action in the advanced UI? I donât imagine Simple UI users would be jumping into advanced very often to configure settings, so the likelihood of it being changed back on accident is extremely low.
I created a basic code change to add a step in tint switching for middle of tint-ramp. I find the smooth a little too slow, but wanted to be able to be in the middle easily.
If interested, itâd be easy enough to make it a runtime config to have a number of steps, I think.
Updated to instead use 4H instead. Allows using it in smooth ramp, as well as bypassing it in tint switching for lights where it makes less sense (like throw/flood instead of tint).
Maybe it`s just me but every light I have (Emisar) that has anduril or anduril 2 is different. Some the secondaries are brighter, some of the color combinations of the secondaries are different (I`ve never been able to get yellow out of any of them).
One of them has the ramp up of secondaries as 2 different settings.
Would I be able to flash my Emisars from a Mac with the flashing cable?
Just got Wurkkos TS21 (finally Iâve found a successor to my Convoyâs S2 fleet), with Anduril 2. Awesome functionality, got around the manual pretty quickly.
I have an issue with adjusting the brightness of any momentary modes in Lockout mode. Based on manual & flasfhlightâs real functionality, we have two brightness options from lockout: 1C & 2H. Iâd like to have one of these options to be brighter (preferably 2H), but canât get my head around it. Note that Iâm using Simple UI most of the time & would like to keep it this way. I get how Advanced is working but just donât need itâs possibilities 99% of time.
Despite making adjustments to floor ramp level, it doesnât change anything in Lockout mode for me. What am I doing wrong?
To adjust the brightness of 2H from lockout, you need to set the bottom of one of your ramps (either smooth or stepped, doesnât matter) to the desired brightness level. Alternatively, you can use manual mode memory at the desired brightness level.
Thank you, jon_slider
Thank you, tactical_grizzly. He-he, nice to meet you here! Thanks for the info.
I managed to achieve what I need, though I would be glad if Anduril had an option to set up lockout mode brightness separate from global (simple/advanced) ramp/stepped floor brightness. What worked is setting it up in Advanced mode for floor ramp to be bright enough for Lockout 2H to me.
This gave me new floor brightness in Advanced UI ramp mode, though it didnât change floor brightness in Simple UI ramp mode, which is good enough. And, it surely worked and set 2H for Lockout mode to be as bright as Advanced UI new floor brightness in ramp mode.
is it possible to get a 4 group battery level during turn on for the sofirn model lamps. This for me would be make the UI perfect. Its a heavily used feature for me in Fenix lights. and with the dual color switch in the sc31, should fit perfectly in the UI, can be toggled for people who want it. Its a very used feature for me.
The moonlight seems to be very bright on my new d4v2 with tint ramping, even when only two emitters are used. I flashed the newest firmware already. I changed floor level so 1. 3 seems to be the even brighter default.
Is there anything I can do to lower the moon mode?
