Hi, I found a bug in the build for D11 B35AM (stock, I haven’t reflash it yet). If I recall correctly, there was similar thing discovered some time ago. I locked the flashlight, configured aux to blinking and white. After couple minutes it unlocked itself.
From Hank’s thread a little while back. TK, have you seen this stepped ramp idea? I would love that on my tint ramping D4V2, as I only ever use mid-ramp, one channel, or the other channel.
Also, would it be possible for you to add jump-start functionality to K1 SBT’s firmware?
Thank you for all your hard work. I know you are super busy.
Would it be possible to have a timekeeping feature in Anduril 2? It’d be great to have tint ramping lights automatically adjust CCT based on time of day.
(Tint ramping is a misuse of terms, it is actually Color Temperature Blending, so I edited out the word Tint and replaced it with CCT in the above quote from the manual)
”Tint” is not used in lighting standards, it’s a colloquial term, there is no official definition, just the one people use.
In standards they speak of light chromacity (color of the light), expressed by x,y coordinates in CIE 1931 color space for example, but also CCT and duv for white light because it’s more intuitive. ”above” ”on” and ”below the Planckian locus” are terms often used when talking about duv.
In my opinion tint in general refer more to CCT, as in ”I like warm tints”, while talking about tint for a certain CCT means duv, as in ”this 3500K LED has a good tint”.
Also AFAIK there is no mention of ”pure white”, maybe that’s a thing in the printing or other industries, but not in lighting.
I’ve been interested in a sunrise mode, where you tap the number of hours and tens of minutes that you want to sleep, then it slowly ramps up in the morning.
Each flashlight would require calibrating on first use (eg teach it how long 60 seconds is). I would have thought it would be accurate once calibrated to at least 5% (30 minutes overnight) but I haven’t tried it yet.
I haven’t measured it, but it depends on temperature, voltage and maybe some random factors. I guess you could achieve ±1 h/d after a proper calibration (factory is ±10, after user calibration up to ±1 with fixed voltage and temperature per datasheet).
I don’t think there is one, singular definition of tint for lighting, but most frequently when used in the flashlight community, we’re referring to DUV. I’ve seen it used inconsistently by lighting manufacturers, sometimes referring to DUV, but probably just as often referring to any sense of non-white.
CCT of light isn’t really treated as a deviation from white, per se, as there is no color temperature defined as pure white. This is significant since our color perception has a relative component. 5700K may look pure white in one setting, while 3000K may in another. Of course, go much lower than 3000K, and there is almost no situation where the light looks pure white, so there are limits to this viewpoint.
Color theory can get really complicated, and numerous different color models have come into use over the last 100+ years as a result.
Rather than get too deeply into all of that, I prefer to just continue as we have been, informally using the CIE chromaticity diagram, and describing color temperature as one variable, and DUV or “tint” as another.
What’s the difference between the different curves (cube, fifth, 5.01, etc) in level_calc.py, and how are they chosen for the different flashlight configs? I’m thinking of adjusting the pwm’s for a 9a d4v2 and a kr1 with sbt90 to make the ramping visually linear.
