So it turned up a few days ago and I said I’d illustrate with some video if possible. Prepare to waste about 5 minutes of your life
…… I checked the Vapcell and screwed it back in, the odd behaviour continued. 3 clicks initiated battery check and it didn’t cycle, indicating the light is in simple UI.
4 clicks from off should have put it in lockout, instead the blue aux lights entered pulse mode. This is the same odd behaviour as before.
Unscrewed the head and held the switch, the light began its build up flickering until the flash, so reset complete.
4 clicks from off, back to the aux pulse again.
So, here is where things changed. I take out the Vapcell and put in the Wurkkos branded battery. Check the UI again and the battery check indicates simple UI. So I try 10H and it enters advanced UI and then behaves completely normally, 4 clicks to lockout, all good.
So I try the Vapcell again, back to the odd behaviour.
Back to the Wurkkos cell, and I do the reset as I screw it up. It enters turbo mode and button presses do nothing at all so I unscrew it. Replace the head, nothing. One completely dead light, kaput!
So, I clean the threads again, nothing. Then I try another factory reset, and it flickers up and enters simple UI. Try 4 clicks from off, back to aux pulse (Wurkkos cell).
Reset attempts are now going one of two ways. Either the light flickers and then becomes stuck in full turbo. Or it flickers up and gets stuck in the brighter of the static auxiliary modes. Only removing the head stops it.
Last one, it’s pretty obviously not working
But…for just a few minutes back then, it behaved absolutely perfectly, locking out, going into advanced UI, then back to the errors. It’s strange, but I’m getting bored
