Good question.
I think that not, because I do not know any 10180 in the market with low voltage protection.
(but if you see the runtime curves of some of them, is not a problem detect when is neccesary change the battery) http://forolinternas.com/viewtopic.php?f=5&t=8470
Any words on differences in lumens, tints and CRI between the 3 emitter options? Love the neutral Nichia 219, but if the G3 is neutral white and high CRI I´d probably like to try that….
K.
I pull the trigger on that one. Do you know where I can get a quality bead chain? I wish they offered the same from others similar 10180 lights (example ).
I’d be interested in this same info! The product page says “100 lumens” but doesn’t specify which emitter that’s from. One of the comments says it’s 6000-8000K, but again, doesn’t specify the emitter.
