Auction Ended Thanks Everyone.
I have discussed this with our Admin, in case anyone is wondering. I am testing the water by doing an Auction here at BLF, for the 3C Maglite I just finished.
Specs:
- 3C Maglite modded body, with File work and VHT paint
- DrJones programmed 14x7135 Driver modded to run with two 18650 cells in series. Initial modes are H/MH/M/ML and it has ramping as well as hidden blinky modes. See DrJones info for the rest of the story.
- Momentary switch put in the stock switch housing
- Polished Aluminum reflector
- Kaidomain plain glass lens
- MT-G2 led on 20mm star (Cutter 5000k)
- Aluminum heat sink
- PVC liner in battery tube to hold 18650 batteries (Batteries Not Included).
- Tail Cap spring has the low resistance mod, (copper braid mod)
- This light can be adjusted from flood to throw by turning the head in or out.
- Pulls 4.2 amps on High with good 10 amp hybrid cells.
Niggles:
It's a hand made light. It's not perfect, but it is bright as heck and a one of a kind. In order to focus the tightest spot, the head needs to be turned out past the "O" ring seal, so I added a second "O" ring further up to keep the head from wobbling. When you turn the head in, stop when you feel resistance, don't ham hand it and tighten it till it locks up, just "snug" will do. It gets hot Fast! The "C" sized heat sink is not huge, so it will heat up very fast on high.
Here's a link to the build thread Including Beam Shots.
Here's how the auction will be done:
It starts right now 09-08-2013 and it will end on Saturday 09-14-2013 at 11:00 AM CST
It is a "Sealed Bid" Auction of sorts. Do Not post your bid here. Post your bid via PM to me. ONLY BY PM to me.
I will maintain a reserved post (Post#1), where I will update the Highest Bid, so you know where you stand.
I will update the Highest bid only during the hours of 11:00AM - 2:00PM CST and Midnight - 2AM CST Daily, (more often if I have the time). I cannot update the Highest bid at night, as I work evenings and I do not have Internet Access there, any more.
I will only post the Highest current bid that I know of, not the actual bidder. Who you are is not for public knowledge, so only the Highest Current bid will be shown.
Since there are only a couple hours during each day that I can update the highest bid, please just be patient. I will do my best to keep it updated. I don't think it will be an issue, as I don't think there will be a ton of bids on this light. We will see.
You can bid more than once. If the highest bid showing is higher than yours, you can bid again.
MINIMUM: The minimun bid is $55 USD.
Auction Price includes shipping.
Question?? Please ask before bidding.
Thank you
Well, it is in Texas!!
I pretend I know..
