Wait…one of the reviews is saying that this always defaults to high when activated with the tailswitch. That would not work. This would be used by being repeatedly activated in a low mode in a momentary fashion. I can’t click it down to low every time.
I have that light. It’s great, but it won’t work for bag checks because I need TRUE MODE MEMORY, which means the tail switch, when tapped, must turn the light on in the SAME mode it was set to before and not default back to high. There seem to be few lights like that, which is just stunning.
Have you looked at the Jetbeam 3M Pro? XP-L 1100 lumens, built like a tank. Single tail switch with two different mode sets. One is turbo only and strobe available, the second is 5 modes with mode memory. If the head is tight you are in “Tactical” mode and with the head loosened just a touch you are in General mode with mode memory. If you switch to tactical and then back to general it will restart in the same mode you left it in.
Nice light. Don’t know if that would work for you.
The Sofirn SP31 V2.0 has mode memory as you require (tailswitch controls only on/off, side button cycles modes), and has decent throw on account of it having an XP-L HI.
I’m not sure it checks off all your other boxes though, and probably doesn’t offer anything more than your current light (other than being more pocketable).
This is BLF. This place is all about having a light exactly the way you want it.
For OP, would you be satisfied with a light that started always in low? There are many that way.
I believe the Sofirn SP70 starts in the last-used mode, with some minor exceptions (I don't think it remembers moonlight or turbo, but it will remember bottom or top of ramp), but that's a rather large light. Might be worth investigating other Sofirns, though.
