The flashlight bug has hit again and I'm wondering what the best headlamp is... Budget of course, and ideally I'm looking for something that can be bright or dim, and that runs a long time on one battery.
Seems decent. Q5 XR-E is pretty old and inefficient compared to XP-G and XM-L. Magnet on the base is a nice feature. Some people run these on 14500 but I don't think it's supposed to be run on such a high voltage.
I did lots of research on the UF-H2 before I bought a Zebralight H51w. I paid $59.
It's a lot for a headlamp but I figure I get the most efficient circuit (long run time), many modes, awesome interface and excellent build quality for hiking/indoor use. If you want to buy a cheap headlamp for indoor use or modding get the Ultrafire. If you need one for mission critical situations or one that will last years get a Zebralight. I absolutely would buy this Zebralight again if I had to.
the efficiency difference of the emitters is negligible when you're using it at 60 lumens and below most of the time.
i would think that the biggest issue would be the bad PWM flicker on the UF-Hx models as has been noted in other threads. that could get distracting in prolonged use depending on your sensitivity.
I would say H2 is close to 80 lumens or about the same H51w puts out on High2.
for close-up work thats plenty. For throw with that wide angle beam, it’s going to give only say 15m.
Another vote for the H2. I use mine regularly but then again, I'm not sensitive to PWM. If long runtime wasn't a requirement, I'd suggest you also check out the TF Z1. From what I read, the H3 should be better than the H2 in just about every way (mine should be here any day now ).
There was a group buy a few weeks back. I just checked and at the moment, the H3 is $48 at DD so even with 20% off, MF still has a better price ($32). That also seems to be the going rate if you try ebay sellers that allow you to make an offer.
If it needs to be one battery I think you've limited the choice pretty much to Zebralight, Spark, or one of the UF models listed.
If you can use 3AAA then you can get a Princeton Tec EOS or maybe an older model of the Black Diamond Spot for about the same money.
I mention the last two since if someone asked me what I thought the best budget headlamp was I'd probably say the PT EOS.
I don't have the UF models, a lot of people on here do and seem to like them. They are all probably decent choices and the rest just depends on your personal preferences.
The Ultrafire uf-h3 is a fantastic light if you already have 18650s and a charger. Any light option, headlight or otherwise, with a 3 aaa configuration is so inefficient in terms of energy/ size as to deserve no consideration. 3 aaa batteries barely have more power than 1 aa. The h3, in a very compact form, provides over 200 lumens of pure flood for a couple hours, infinitely variable output and a magnetic base (especially useful for working on autos).
At $28.76, as mentioned above, this headlight has no competition at this time. Zebralight h600 will be a better light in nearly every way, but more than 3x as expensive.
Had my h3 stolen in a break-in, along with a lot of other items. The h3 was the first thing I ordered a replacement for. It's hard to explain just how good this light is, for the money. I've got an h51 Zebralight and I think the H3 is just as well built. Just works, every time.
I wouldn't really call it throw. It doesn't really have much of a spot but the overall beam is less than a pure flood. It's probably 60 degrees or something like that so it is useful to 100 feet rather than just to 20 feet.
I put some diffusion film over the optic on mine and it reduces the throw a bit and widens the beam as well (eliminates the hard outer edges).
It's a good multi-purpose light. If you never need a headlamp to go more than 20 feet it will throw a bit further than what you are looking for but if you want to go into your backyard at night and have plenty of light to see where you are going it would do that well.
So, that's why I said that it's personal preference at a certain point. All of the lights mentioned are reasonably floody in my opinion but not so floody as to not be useful for hiking for example. I don't know much about the UF lights. I think they may be too floody for hiking (others can comment on that).
I think the original models of the EOS were more geared for throw but that's not the case now IMO.
AA only have 10%* higher energy density than AAA. and using 3AAA has certain benefits, the number one being higher efficiency while using cheaper circuits. with the exception of Zebras and maybe Sparks, 1AA headlamps don't run as efficiently as 3AAA headlamps and give back their energy density advantage in the form of lower efficiency. if you were to compare 3AAA lamps and 1AA lamps on runtime to weight ratio, they would be about equal.
the only disadvantage i see for 3AAA headlamps is that after a while, dealing with 3 batteries at a time turns into a real hassle.
*for Eneloop batteries, the following calculation applies:
the Eos's only serious weakness is for area lighting inside of ten feet. the beam gets kind of narrow looking inside of ten feet. if you're going to use your light as an up close work light, i would advise against the Eos unless you don't mind adding scotch tape or some other form of heavy diffusion to the lens.
I agree with Robo, it's dealing with the 3 batteries that is more of a hassle (and much more expensive as well if you are using lithium primaries since AA and AAA cost about the same).
The only big difference (to me) is that a single AA headlamp is much more compact. It goes beyond the weight difference which is not always that great (plastic vs aluminum) but it's simply that most 3 AAA headlamps are bulkier by comparison...especially when you consider how they adjust the beam angle (hinged head vs simply twisting the AA body).
The main reason for considering 3 AAA lights (other than driver efficiency as Robo mentions) is that there are many traditional outdoor hiking/camping headlamps available with features you might like (dual beams, red LEDs, etc).
For my uses however, nothing works better than the Zebralight H51f.
I love my ufh2 on and ufh3. Ran my ufh2 on 14500 down to 2.6 v the other day until it stopped working. Works great on eneloops too. Hate 3 battery headlamps. I prefer the Ufh3 for night fishing due to it being brighter.
