I know, I know there are many many bike light reviews and conversations on this site and others (MTBR). I have read many of these but still cannot make my mind up and seem more confused about what to look for.
I currently own a Shadow JM07 (on the bars) and Convoy S2 (on the helmet). I have had these for a while and find them to work well. I am using 2 fish style mounts which I find a little annoying on rough tracks and jumps.
Now I am chasing another setup for my 5yr old son, who will be coming along with me. We will be riding single tracks/ cross country and dirt roads.
Can you please give me an idea of what is currently available (that is decent), that doesn’t need modding, and is ready to go off the shelf. It can either be a flashlight/torch as I already have or single-purpose bike style light.
this yinding light is getting great reviews, I think it was developed with help of some mtbr forums
http://www.gearbest.com/led-flashlights/pp_133573.html (there are other options for the same light)
there was a sale lately, try to search it in the search box (or ask gearbest via PM)
you also need a battery box and a couple batteries, or four if you need huge runtime
I use flashlights on both the bar and helmet for mountain biking.
The Fenix ALB-10 bar mount is excellent, solid vibration free. Only downside is that it can only accommodate 18650 lights, not likely to fit larger than 30mm battery tube. $14 from Banggood.
For the helmet, just 2 longer strips of velcro to fasten to the helmet. Super secure assuming your helmet has vents, center and on top.
As for which lights… I have Franken-Dale modded triple and quad emitter lights but have also used the Eagle Eye X6 (XM-L2, also modded for more output). The X6 is great for the helmet, altho at high output the hotspot is a tad intense but perfect for the faster downhill run. You might want to try some DC Fix to diffuse for the bar (if you want 180* spill). I prefer the wide spill for my bar light.
I think the Group Buy Eagle Eye A6 will likely make an excellent helmet light, I’m on the group buy for 2. Smaller/lighter than X6, will see what the beam profile is like…
But the Zeusray is pretty decent for $8 for either application.
fruit flier, I’m a cyclist and use a neutral white or warm white Convoy S2 on my helmet. It has an 8x7135 / 3.04A driver. (Qlite to be specific). Unlike yours, I’ve zip tied mine down and cut a little groove in the helmet so it doesn’t move about at all.
I don’t have a twofish so don’t know the construction. Do you put the light on top of or below the handlebar? Would a little piece of bicycle tube between the twofish and handlbar help?
I ride exclusively off road, fire roads and single track around So Cal. This is my favorite bar mounted light. I have a lot of the inexpensive clones and I’ve tried several of the dual emitter lights. For around $50.00 this is the best I’ve found. This is for just the light, no battery.
When I bought mine there was a bar mounted switch option that they were offering. It was well worth the extra few dollars, but I don’t see it listed anymore.
I’m still messing around with the right helmet light, I have some that are plenty bright enough, but too heavy to wear comfortably and I find my 18650 flashlights are too hard to mount and too heavy. I’m about to modify a very small, lightweight light to use as my helmet light.
I’ve bought several things from Action-LED and I’ve had a very good experience every time. You can call and ask questions it’s a one man operation and he is knowledgeable and helpful, it’s all shipped from the US and he offers a warranty on the stuff he sells.
I will try and answer the questions that have been asked. Do I use the flashlight (Shadow JM07) mounted above or below the bats? I currently use it above the bars.
Regarding using an inner tube to secure the 2 fish mount. I will give this a go and also try to use cable ties instead of velcro to attach it to the bars.
Is my price range including batteries, packs, charger? I currently have a good charger and batteries (18650 and 26650s), however i do not have have a battery pack. So the price of $50 would need to include lamp head and pack.
I am liking the idea of the flash lights and maybe picking up another Convoy S2. I also like the look of the MJ808 and also the Yinding lights. The yinding seems like good value and I am guessing it would get longer run time than flash lights.
Eebowler i would be interested to know what you are using on your handle bars.
Thanks itsonlyme for the link to Garry’s post I’ll look out for the final product. It sounds like it could be a ripper.
Anyone have any more ideas for a small flash light (18650) that is a good thrower? I find my Convoy S2 just a bit floody and would like something with a bit more spot light.
Not to knock any bike light method, I personally have had much better luck with burn times and mounts using purpose built bike lights and battery packs vs. flashlights and the various mounts I’ve tried including the twofish. I think it’s because with an external battery pack there is less weight and leverage on the mount. Also, obviously, more than one battery should last longer.
There are a lot of the MJ-808 clones around from all the usual vendors. A buddy of mine got one of these you or maybe this one could get 2 of these with batteries and mounts for your $50.00 limit.
It is close to the MJ-808 but with more of a hot spot. Even the inexpensive battery pack seems to last him an entire 2~ish hour ride switching between Med and Hi, he has never run out before the end of a normal night ride. The modes are annoying on the clones though. No memory, un-hidden flash.
I know the O-ring mount looks flimsy, but it works for me and stays put.
All that said, I must admit that Yinding looks like it could be good too.
The Yinding is a great light, esp. combined with the KD programmable driver (direct swap in). It's not much of a thrower though. I think we estimated it to have 15 degree TIR's in stock form, so even going to 10 degrees isn't going to gain you much.
I've not modded mine and I am not aware of any postings with pics. I believe it was MTBR user Ofroad'bent who replaced his Yinding driver with the KD driver and said it fits without any modifications. You just have to desolder the power and led wire from the old board and resolder them to the new board. He posted about it in the gigantic Yinding thread over at MTBR somewhere. The KD driver with emitter board is $8 here or with added neutral white emitters for $12.59 here (cool white also available). If you post over in the MTBR thread I bet someone can post pics showing how easy it is (if you still want to see pics). Oh, if I remember correctly, there is a need to trim down the nub of the momentary switch on the KD driver (or perhaps trim the inside of the switch boot on the Yinding case).
I saw some pics and info on the driver swap in that MTBR thread it’s on page 53. It is not a comprehensive how to.
I wish someone would summarize that thread, I wound up just reading the posts with pictures, but I’m sure there’s other useful (and useless) stuff in there I just don’t have the patience to read it all.
Brandan, I don’t use a bar light. Other than an occassional heavy downpour, a helmet mounted light doesn’t hinder vision too much. Given the choice, I’d choose one with a wide-ish beam
