Do you know someone that works for a company that has an in-house IT department?
That's where I get mine, 40-50 packs per year. We have over 600 employees at my office and zero desktop computers. 70% of them bring them home each night or offsite to clients everyday so lots of wear on the batteries.
If you are in a high traffic area like a college you can make your own recycling box like they have at the home depots.
Or you could just steal a couple of those cardboard home depot recycling boxes....and recycle them by dropping off a new box (empty) and taking the old box (full) .
" What are you doing ?? "......
"just picking up the recycling ..here's your new box" .:P
if the push you just say green stuff like " Give a hoot ..Don't pollute " or .. quote Al Gore
What type is this battery, from a old Dell laptop (2005). I had two battery packs to the laptop, and the first one was 6 x US18650GR (Sony 2550 mAh). They have been in the Opus BT-C3100 with a charge test (charge - discharge - charge) and at 1A, they gave me a result of around 2500MaH (2480-2540) So it’s seems they work just fine.
The second battery pack had 6 x dark red batteries with a green rim at the top. They are only marked with a large D and then J18A. There are also a serial number on them (was sure that was the name of the battery, but soon discovered that the number was different on every cell.
Just started a charge test with them.
Is this type of batteries worth saving, or are new batteries better?
I took the advice and found someone that knows an IT guy. First pack was an old dell battery with six Samsung ICR18650-26FU… NICE… All were above 2.2V so I am checking them on the D4 now…
Sincerely appreciate the help, now I have to build an IT guy a flashlight to keep the packs coming…
so if you are in a battery junk yard use this way to find capacity of individual cell without having to google it.
to get a maximum mah rating battery look for a battery bank that has highest wh ratings.
an individual cell having WH rating above 9.5 means it at least is 2500mAH.
i hope somone good at andorid programing would code a little utility for this purpose ... dang i never worked with visual programing. all were console based.
Making new Friends and building new Flashlights is the “Intangible Benefit” of recycling laptop packs. That’s what I think, anyway. Be sure to remind him/her to get a good charger…
The real trick is New, Oem , Unused Packs w/ japanese or korean cells inside .
Use packs are really hit or miss . they are fun to play with but the yield will generally be about 20% ~30% of cells worth keeping.
once you go new unused packs you'll never go back ...ok every once in a while that recycling box will call your name . But at least then when the manger asks you "what the hell do you think you're doing ?"
You can look him in the eye and just say ....." It was talkin to me "
I found this pack in the recycle bin. 21.6V (25.2V fully charged) 1500mAh
It’s just 6 cells connected in series with at temperature monitoring sensor. No balancing circuits or low voltage cutoff
The cells tested out close to rated capacity at a 1A draw I should test them at 6A or so.
The white tops are 2,000mAh if I’m not mistaken. At least that is what they would be new, probably less than that now. Maybe 1800 or so. Purple tops are higher mAh than the white tops and from what I have read are also supposed to be higher amps as well. Probably not the super high amp “purple tops” though. They do make a purple top 20amp battery but it also has a very different top altogether. It has a larger top with only four or five legs. It’s a newer cell and I wouldn’t expect to find it in older laptop batteries.
The purple tops that you found are good batteries and I would keep them, the white ones I might keep depending on how they tested. But with either of them you should fully charge them and then go back and check them again a day later. If they don’t stay at least mostly charged after a day then they are pretty beat up already. In fact cells that are really beat up will drop a bunch of volts overnight. If they do that then recycle them for sure.
