Well I was having a chat with Jack via email who seems to be much more open to sending a sample but Celia has taken over all conversations saying she is in charge of this groupbuy so I think we need to look elsewhere.
Agree, keep it small please! There's only big throwers around and there's no reason at all for the performance a good thrower to be big (how much space does a single 18650 and a single led at 5A need at all?). You need the large reflector diameter and the rest can be made very compact and lightweight, even big fins are not needed for the performance, some modest finning is just fine.
“I think what we all want is a single 18650 stl-v6. Do we just need to design it in CAD?”
“All” of us?
Sure, I would like to have one of those too, but I also want a BLF - BIG-HEAD THROWER!
Not so Big that you would never use it… Maybe something around 70-90mm Head diameter, using 3 cells in series?
Yes - I think that you would have to design a “stl-v6”in CAD. - Please clue us in
Thanks,
-Chuck
EDIT: You said: “Tom was getting near 250 kcd with xml2-u2, so should be possible to get closer to 300 kcd if you were willing to go xpg2 or xpe2 for a super thrower”
XP-E? - Very true, but that is just the sort of thing that is done, just for fun. - Very small Hot Spot, so better figure in the cost of the Binoculars you are going to need to see anything:) Not a very satisfying beam profile. - Great stuff in a P60 size though, I would imagine.
A larger emitter, “XP-L HI” will do the same thing, with a much larger, more useable Hot Spot
The XP-L Hi or XM-L2 will not do the same thing, they do not have anywhere close to the surface brightness of a XP-E2 at 2.5A, and so will throw considerably less. A XP-G2 comes closer already but will still not equal the XP-E2. If you manage to get the XP-G2 at its maximum brightness (which is not possible with a single Li-ion cell) then it has almost the surface brightness of the XP-E2. The XM-L2 and XP-L will blow their bond wires before the maximum die brightness is reached.
I vote for single cell 26650. I believe its a good trade-off between performance, runtime & size. It also does not give the out of proportion look by putting a huge head on a 18650 tube size e.g. the Eagle Tac Turbo heads - it really just looks funny. Well, my opinion that is…
Should the preference be multi cell, I definitely prefer parallel please 3 or 4 x 18650. This allows for linear DD drivers on the common thrower type 3V LEDs (XM-L / XP-L / XP-G). Buck drivers are ‘complex’, expensive & has possible heat issues when driven hard. Parallel cells are obviously also good for voltage sag compared to single cell setups, but, my preference still is single cell.
Only reason I would go for multiple cells in series is to run XHP-35, that is 4 x 18650, direct driven.
I just want to clarify. Are you saying that XP-E2 at 2.5 amps will throw further in a big thrower head than any of the XP or XM leds @ max amps in single cell setup?
“The XP-L Hi or XM-L2 will not do the same thing, they do not have anywhere close to the surface brightness of a XP-E2 at 2.5A, and so will throw considerably less.”
Correct! - Why did I not see this coming?
We are of course going to drive the XML size die at far More than 2.5A, and even if the surface brightness does not match the XP-E2 (that’s a given - it will not), is the beam from the XP-E2 really useful to you, or can you just say that you did throw it that far?
A Laser will throw even further, but even if it were NW/CW CCT, how satisfying would the beam profile be for you?
I for one, want to see something besides just a little spot lit up. - A XP-E2 in a 70mm reflector will be a Pencil Beam, not satisfying to most people.
I agree a pencil beam is not practical, but, its still interesting - I was not aware that a XP-E2 will out throw e.g. a XP-L V6. And, for that matter, to rephrase, I was not aware that a dedomed XP-E2 at 2.5 amps will out throw a XP-L Hi V3 at max single cell amps… hard to believe
I have a BLF X6 with dedomed XP-E2 running at about 2A. It’s one of my favorite lights, because it really throws and is small enough for me to call it pocketable. Maybe my Yezl Y3 with XP-L HI running at 5A (LD-1) reaches a little further, but it’s not what I call a pocket-thrower. That beeing said, if you carry these throwy type of lights you’ll always want to bring a floody type of light along. For me this X6 with XP-E2 dedomed and a X6 triple XP-L or triple Nichia is just about the perfect combo. And these X6’s are simply beautiful lights if you ask me.
I’m with Chuck in a big head, multiple 18650 cell thrower.
I think there are two tracks here… those that want the pocket thrower, single cell light; and those like Chuck and I who want a pre-modded Courui D01 style light with a huge reflector and multiple cells.
So then there is need for two BLF throwers, as far apart as something called 'thrower' can be :-) , so that not a lame compromise is achieved but two extreme performing lights in their own class.
